AOC 22LVWk only turns on with 3 lamps connected
    Re: AOC 22LVWk only turns on with 3 lamps connected
    From what I see on this power/inverter board, the power supply is an always on power supply, it runs the minute you plug it into an AC outlet, so I do not think it has PS_ON signal, it does have BL_ON (Backlights ON) signal from main board which must be working since the lamps did flash on.
      master hoarder
      • May 2008
      • 12170
      Indeed.
      Using the provided pictures, this is what I have decoded so far...
      Using this picture as a reference:
      https://www.badcaps.net/forum/attach...5&d=1348431519
      find the connector with the colored wires on the right. Let's call the red wire on one end Pin 1, the blue wire next to it Pin 2, and so on.
      Then you have the following pinout:
      Pin 1: ground
      Pin 2: 5V
      Pin 3: ground
      Pin 4: ground
      Pin 5: 5V
      Pin 6: 5V
      Pin 7: backlight ON signal or backlight dim signal
      Pin 8: backlight ON signal or backlight dim signal (if Pin 7 above is one of these, then this pin is the other thing).
      Pin 9: unused??
      Now, as far as the original problem, I'm not exactly sure what could be wrong.
      Do the following test:
      Hook the monitor to a computer and turn ON the computer.
      Does the power LED on the monitor stay ON when you turn the monitor ON with 4 CCFLs? What about when you have 3 CCFLs?
      If it doesn't stay ON with both 3 and 4 CCFLs, remove jumper wires L901 and L902. They are located next to those 4 Nichicon caps. Then try powering the monitor ON when it's connected to a running computer. It should stay turned ON this time. Jumper wires L901 and L902 remove power from the inverter, so if there is a fault, it wouldn't affect the rest of the monitor. You just won't get any backlight at all.
      • roxboy1984
        Dell Inspiron 15 AC adapter turns off as soon as connected (MB Short)
        by roxboy1984
        Please can someone help me, im trying to find the shorted component as i have a donor board that i can swop components from.
        If i inject 2V/2A on DC in PU4201 gets really hot. ive changed out PU4201 from another board as well as a couple other Mosfets but PU4201 still gets crazy hot when i inject. Any ideas? im still a noob so am learning....
        11-20-2024, 10:59 AM
      • Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
        by Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
        03-15-2024, 09:37 AM
      • dit3
        HP ProBook 455 G7(DA0X9MMB8F0), fixed bad RAM power rail, laptop works, but now automatically turns on after AC is connected
        by dit3
        Hello everybody,
        I got HP ProBook 455 G7 which originally turned on partially(fans on 100%) and hen off after 8 seconds, with AC diode flashing orange and last flash white. This behaviour stayed for a while, but before I realised that there is power delivery issue and not BIOS problem, laptop started to automatically turn on after 2 seconds when in turned off, kept power cycling. So after I fixed shorted cap and burned ferrite bead, laptop turned on fine and booted to windows.
        Now, laptop can be turned off and it stays like that... unless you plug adapter again, which triggers...
        01-06-2024, 04:44 PM
      • Egidio85
        Samsung UE55F8000SZ Turns on and off immediately
        by Egidio85
        good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
        This defect happens continuously, hearing the classic click of the relay every time.
        Power supply board BN44-00636B
        disconnecting the mains and lamps from the power board always causes the same problem.
        Is it normal that without anything connected this power supply turns on and off cyclically?
        any suggestions on what to check?
        thanks in advance
        03-11-2025, 12:45 PM
      • www
        LG L192WS-BN backlight turns off after 1 second
        by www
        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
        03-24-2024, 05:26 PM
