Broken Trace
Re: Broken Trace
If you at the picture, the bottom right is pin 1, bottom left is pin 8. So pin 2 is the second pin up, if you use an Ohm meter and measure pin 2 and the ground trace, it should read 0 Ohm.Never stop learning
by chth96When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
cutting tiny trace.
This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging... -
by Friend4CapIf anyone can help it will be very appreciate!!
Motherboard - (TUF GAMING B550-PRO) client connected Floppy Drive 4-Pin Power Connector to RGB_Header_1 +12V G . R . B and Burn one N6V8 and Damage all circuit trace, please check pictures, Motherboard not turning on & everything check ok, no short to ground, I need to repair all circuit trace and replace burn N6V8 but don't know where this 5 circuit trace connect to N6V8. If anyone with TUF GAMING B550-PRO can check. “Thank you in advance”...05-07-2023, 05:38 PM -
by AstonishedHi friends of electronics
What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
Please help me fix this circuit.
(the datasheet of the IC: https://pdf.datasheet.live/28... -
by eeneeHello guys. I got this motherboard that had liquid damage. The motherboard's type-c controller IC got shorted which resulted in main power rail failing to be produced and after replacement of the IC the main power rail returned. But the board is turning on and off. The current consumption is around 0.120Amps@20volts. After like 10 seconds it turns off and on endlessly. Checking the voltages on the coils:
pl701-9.04 volts
plpl101-5.1 volts
pl201-1.2 volts
LT1-0(0.685kohms)
pl301-1.05 volts
pl100-3.3 volts
pl614-1.04 volts
pl402-0.9 volts
pl613-0...03-21-2024, 05:49 AM -
by EasyGoing1I don't know the first thing about where to even start looking for the result I'm looking for ... but what I want, is a circuit ... or maybe a certain transistor ... that will remain "closed" when the voltage at the base is 5 volts, but when that voltage gets to 4 volts or less, I need that transistor to turn on - preferably with maximum saturation. I would prefer that it also does not even turn on a little as the voltage approaches 4 volts, but remains closed until that voltage hits 4 volts.
Now, it would be OK if it had some kind of marginal transition from zero saturation... - Loading...
