Viewsonic VX2235WM-3 (M220EW01 V0 Panel)
  • k3wf3w
    • May 2012
    • 33
    Hey guys, same problem as here
    Monitor turns on, but white screen.
    F1 is blown, replaced it, and it immediately blew again.
    Have done some testing, not really too sure what I am looking for. From what I gather from reading other posts about this problem is there is most likely a short.
    So I tested the surrounding caps and the one diode, I made notes on the picture itself, I tested the caps on both the ohm setting and the diode setting (don't know if that helps diagnose the problem or not).
    Thanks in advance for any help.
  • jetadm123
    • 2169
    Re: Viewsonic VX2235WM-3 (M220EW01 V0 Panel)
    The fuse blowing is most likely due to a short. Looking at your readings, you measuring 1.2 ohms across a a few of the caps. That would indicate a potential short. However, other components in the circuit could affect the readings. All those caps on the right side of your photo showing 1.2 ohms appear to be connected in parallel. The sure fire method of checking the caps would be to unsolder/remove them one at a time and recheck their resistance reading to see if they still read 1.2 ohm. Also check C89. That's four caps total you need to recheck.
    • Duncanbest
      • Jul 2012
      • 81
      • Taiwan
      If you have a power supply with current limited function.
      Like this
      http://www.elexp.com/tst_3003.htm
      Set current 0.1A & voltage 5V , connect to F1 for a while ,the NG part will perform like hot device with finger touch (or using temperature sensor ).
      • k3wf3w
        • May 2012
        • 33
        Like this
        Hey, now that is a good idea. But I don't have such a power supply. How important is the Amperage? I have lots of computer power supplies that would provide 5V...
        • k3wf3w
          • May 2012
          • 33
          ok, took off C89 and it is infinite resistance...
          also with it removed the other 3 capacitors mentioned all read 0.9 ohms.
          Should I continue removing and testing the other 3?
          Thanks for your help.
          • k3wf3w
            • May 2012
            • 33
            Ok, got bored, so I removed the other 3 caps that were in parallel and guess what, one of them read 0.9 ohms, and the other 2 were infinite. So do you think that was maybe the short?
            • Duncanbest
              • Jul 2012
              • 81
              • Taiwan
              Too much current -->maybe destroy other part,like burning print circuit copper or something.
              • jetadm123
                • 2169
                Not sure what "other 3" you're talking about. Those caps reading .9 ohm appear to be shorted and should be replaced. I would leave them off the board and check all the other caps (there are quite a few of them) on the board for shorts. Make sure you record the location of any other caps that you remove for additional checking.
                • k3wf3w
                  • May 2012
                  • 33
                  Oh, the other 2 caps were fine, not other 3. So one of the 3 in parallel were shorted.
                  I Checked all the other caps in the vicinity and they all read infinite. I also checked all the other caps on the entire board and there were 3 of the larger ones on the far left hand side of the board (not pictured) that read like they might be shorted, but when I removed them from the board and tested them they were fine. There was also another larger one on the far right hand of the board (also not pictured) that read like it might be shorted but that one was fine as well after desoldering and testing it.
                  So how do I figure out what to replace the bad cap with? Is it by size and color? or do we need a schematic?
                  • k3wf3w
                    • May 2012
                    • 33
                    That makes sense, I might get a power supply like you mentioned to make future troubleshooting easier.
                    • jetadm123
                      • 2169
                      There are three ways to determine the value, by schematic, scientific method and Wild Ass Guess (WAG) method:
                      1) schematics are hard to come by for these panels, but you can still try looking for one. You can try looking up the spec sheet for the multi-legged, U4?, chip on the far right of your photo. The manufacturer may have have an applications schematic that might give some insight into the cap values.
                      2) scientific method: since the caps were in parallel, they're probably all the same value. If you have a capacitance measurement capability on your meter, then all you would need to do is measure the value of a good cap.
                      3) WAG method: another member has suggested using a cap that's the same physical size as the shorted one.
                      • k3wf3w
                        • May 2012
                        • 33
                        hrm, no capacitance capability, there was mention of a schematic on the other thread... I will see if I can find one. Otherwise, WAG will be my only choice. Would it be alright to put in a capacitor that is one size larger (assuming it will fit)? or should I just make sure it is the same size?
                        Thanks so much for your time. I think I can figure the rest out from here.
                        • jetadm123
                          • 2169
                          I think I mentioned U4 in my previous post. You can try looking up the spec shet for U4 in the hope that it contains an applications schematic that might give you a clue regarding cap value.
                          As for using a physically larger cap, it will probably be the wrong value, but please let us know your progress/results. Good Luck!
                            If they are in parallel with other 3 caps, they will more likely to be the same value, they have to use a bunch of them due to space limitation. You just have to measure one good cap, more likely to be MLCC around 10uf 16~25V rating, becareful when install these MLCC, they are easily cracked and easily damaged.
                            • Duncanbest
                              • Jul 2012
                              • 81
                              • Taiwan
                              U4
                              https://www.google.com/search?client...hannel=suggest
                              boost function -->from 5V to ?? V (you can measure by meter)
                              then choose the 0805 MLCC voltage rating
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                Now, I wonder who that is
                                Yes, I've been using the WAG method for a while now, with high success rate. Had 2 monitors that had this problem about 2 years ago. Both are still working fine after I fixed them. Chances are, your monitor will work even with that shorted cap removed and nothing in its place. However, it's better to add a cap in there anyways. I see another free spot (labeled C27). You can install even an additional cap in there.
                                At least in my observation, those t-con inverter circuits aren't really all that picky about the caps. As long as nothing is shorted, they will work fine.
                                If none of the other caps are shorted, just change that shorted cap, put a new fuse, and all should be fine.
                                • k3wf3w
                                  • May 2012
                                  • 33
                                  Wow, thanks for all the help everyone. I will see what I can figure out. I have a new fuse in and have soldered back in all the caps that were good. I like the idea of putting in an additional cap at C27. It looks like C27 is in parallel with C24, and both C27 and C24 are in series with C23,25,26.
                                  I will keep you all posted.
                                  • k3wf3w
                                    • May 2012
                                    • 33
                                    Here is U4 for those that were interested...
                                    • k3wf3w
                                      • May 2012
                                      • 33
                                      Bad picture, but you get the idea...
                                      So I used caps off a broken motherboard, and I put an extra cap in C27, just because.
                                      Thanks again everyone for all your help. It seems like this is quite a common problem with this particular panel, so I hope this helps others.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        Actually all are in parallel.
                                        But who cares about the details at this point - the monitor is working . Congrats!
                                        • howardc64
                                          LG 49UJ6500 LCD panel lighter band that goes away
                                          by howardc64
                                          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                          02-19-2023, 12:13 AM
                                        • Storyteller12
                                          QN55Q60R Service Menu Panel Help
                                          by Storyteller12
                                          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                          01-13-2024, 01:57 PM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                        • KYBOSH
                                          Samsung UN50TU8000 - Dead Panel Forensic Questions
                                          by KYBOSH
                                          I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                                          When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                                          When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                                          Later I checked for shorts on the panel PCB boards but could not find anything.
                                          When I took a look with the FLIR i noticed the 2 resistors...
                                          08-10-2024, 08:39 AM
