Viewsonic VX2235WM-3 (M220EW01 V0 Panel)
  • jetadm123
    • 2169
    Re: Viewsonic VX2235WM-3 (M220EW01 V0 Panel)
    Great work! Chaulk up another win for the WAG method!
    • howardc64
      LG 49UJ6500 LCD panel lighter band that goes away
      by howardc64
      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
      02-19-2023, 12:13 AM
    • Storyteller12
      QN55Q60R Service Menu Panel Help
      by Storyteller12
      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
      01-13-2024, 01:57 PM
    • maneatingmonkey
      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
      by maneatingmonkey
      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
      03-27-2024, 07:17 AM
    • KYBOSH
      Samsung UN50TU8000 - Dead Panel Forensic Questions
      by KYBOSH
      I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
      When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
      When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
      Later I checked for shorts on the panel PCB boards but could not find anything.
      When I took a look with the FLIR i noticed the 2 resistors...
      08-10-2024, 08:39 AM
    • NolesFan
      Can LED panels be used from different TV's ( or the internals to the panel )?
      by NolesFan
      I have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you
      06-23-2025, 09:19 AM
