Need advice on this Dell 2007FP
  • abced123
    • Jul 2011
    • 10
    A local wanna sell this LCD, but it has a problem - yellow dot/area at top left corner as shown in pix . Is this fixable or a sign of dying soon ? Also, any bad history with this model. Thanks
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Need advice on this Dell 2007FP
    That's a panel failure, unfixable. However, a failure of that kind does not expand. I know of a 21" Fujitsu LCD which has had the exact same yellow corner for the past 3 years, and hasn't developed any other issues.
    A working TV? How boring!
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • multimesut
      Dell 2007FPB Yellow Light Problem
      by multimesut
      Hello friends,
      A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
      11-13-2024, 07:00 AM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • Big Pooka
      Lg OLED rendering yellow as green, I could use your advice.
      by Big Pooka
      Hello all,
      I just picked up a LG OLED65E6P off of Craigslist (it was practically free). It functions flawlessly in all aspects except it renders yellows as greens. It does so regardless if the source comes through an HDMI port, or streams in through onboard services such as Netflix.
      I've factory reset all the color options, cleared the panel noise via the onboard option, and waisted half an hour talking to LG customer service.
      Have any of your dealt with this situation?
      I understand OLED's are susceptible to burn-in, and looking at the...
      06-11-2023, 02:39 PM
    • diamon
      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
      by diamon
      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
      Pictures of these boards:
      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
      Dell...
      02-28-2024, 12:51 PM
