Samsung SyncMaster 225bw - Can I replace my 'REV0.1 Power Board' with a 'REV0.2' one?
  • pebull2009
    • Jul 2012
    • England (UK)
    Hi there,
    I've stripped my Samsung SyncMaster 225bw and found a variety of faulty capacitors. My monitor uses the power board IP-45130A (REV0.1). I was just wondering whether I can replace it with IP-45130A (REV0.2) power boards which are available on ebay?
    I've looked at all of the electrical INPUT and OUTPUT details for both boards and they are the same. The other alternative is to buy a REV0.1 Capacitor Repair Kit.
    Any help would be really appreciated :-)
    Many thanks!
    Pete
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung SyncMaster 225bw - Can I replace my 'REV0.1 Power Board' with a 'REV0.2'
    Hi - You will need to be careful if buying caps on ebay as many are fakes. For the power supply board you need low esr caps - good make like panasonic rubycon etc.
    New board or kit is not the only alternative you could buy a set of caps from RS Electronics or CPC or Digikey or Farnell. Make a list and price them up you can ofetn replace all the caps for the same price as the kit which only covers some of the caps. It is unlikely that you will need the BIG cap.
    If you buy a replacement board it could still need recapping before to long.
    It does of course depend on whether you have the equipment and skills to replace the caps.
    In answer to your main question - I am sorry I do not know if the boards are compatible - perhaps the seller would advise or be prepared to take the board back if it was not?
    You dont say if you have searched the forums for info on the 225bw here is one
    which might give you some ideas
    https://www.badcaps.net/forum/showth...5bw#post248639
    • pebull2009
      • Jul 2012
      • England (UK)
      Hi selldoor,
      Many thanks for your reply. I am an electronics teacher so ordering the capacitors shouldn't be a problem. I was just wondering if anyone knew any differences in architecture between REV0.1 and REV0.2 that would affect the various other PCBs/components in the monitor. From looking at it, it seems as though it shouldn't be a problem.
      Have you fixed a 225bw before? What caps did you use?
      A huge thank you for replying! It's really appreciated :-)
      Pete
      • selldoor
        Slow Learner
        • 7870
        No I have not fixed a 225bw - Id guess all the info you could ever need will be in the
        post I suggested. If you just read the last page it lists the caps others replaced and one member says the 2 version board is good.
        • Rtech
          • Jul 2010
          • 1095
          It is quite common for power supplies,to be the same electronically ie same I/Ps and O/Ps, to have fixing holes in the same place, but have different components,it basically depends on who makes them, what Version etc. So provided you are happy that it will fit exactly, and it is electronically the same, then there should not be a problem.
          • jdfnnl
            Syncmaster 225BW Repair
            by jdfnnl
            I am working on repairing this Syncmaster 225BW for the second time. I don't remember if the symptoms were the same, but the first repair was replacing the caps of course. This time the monitor turns on for a couple seconds then goes black, but think I can still see a faint image. The power button does not seem to work, it just stays lit. Took out the power / inverter board and the tops of the caps seem completely flat. I do not have intuition about testing with a multimeter so was thinking of just replacing a part. I read somewhere that when the screen is on without being backlit, the inverter...
            Yesterday, 02:45 PM
          • soopacrucial
            by soopacrucial
            Hi folks,
            10-29-2024, 02:40 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • RetroComputingGrotto
            Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
            by RetroComputingGrotto
            I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
            As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
            What is your advice/opinion on whether or not on old(er)...
            04-03-2024, 08:30 AM
          • bembeno
            Need help in replace io Lenovo NM-C911 Rev: 1.0 GY550
            by bembeno
            I have to replace Io lenovo it 8227E so i want to know will it need to write ec firmware...
            10-22-2025, 12:04 AM
