Sceptre X9G NagaV - does not power on
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Sceptre X9G NagaV - does not power on
    Ok but can you still test the voltage at the big cap?
    Did you test the resistances budm asked for?
    • sirswears
      • Nov 2014
      • 10
      • US
      G & S idles around 87
      G & D continually goes up
      D & S starts out negative then goes positive and up continually
      set multimeter to 2000k ohms i don't really know if i'm doing this right
      • sirswears
        • Nov 2014
        • 10
        • US
        G & S idles at 87
        D & S starts out negative turns positives and continually goes up
        set multimeter to 2000k ohms not sure if i did it right
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
          by momaka
          03-15-2023, 10:17 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
