BenQ FP91G+ wont stay on
  • mattch
    • Mar 2010
    • 121
    Hello crowd!
    I have come for suggestions about a BenQ FP91G+ LCD.
    I know only enough about electrical components (board level) to be dangerous however Im a wizard at using them. I do learn and understand fast With that said i dont know where to begin and would appreciate a nudge in the right direction.
    when i plug the LCD in and press the power button, the power LED comes on green then turns off right away
    The inverted MAY be fried, but at this point i believe that is irrelevent since the power LED wont even stay on.
    i have a few ideas but would like to throw those out there:
    -Do LCDs use same voltages as regular computer? 3.3, 5, 12?
    My thinking is that if they do, use a bench power supply to test the LCD, if that works then i know the LCD power supply is bad. For some reason i dont think its going to be that cut and dry.......
    -short?
    -something fried like a fuse?
    I have a multimeter and acceptance that i will get shocked again one day (good thing usa uses 110v)
    Re: BenQ FP91G+ wont stay on
    Please post good clear pictures of all the board using advanced function for file attachment.
    If the inverter has shorted circuits, it will cause the main power supply to shutdown to protect itself.
    • selldoor
      Slow Learner
      • 7870
      Thought you were a noob when there are no pics to accompany your story.
      Here is a thread that sets out the main problems with this monitor
      (no pics there either!)
      https://www.badcaps.net/forum/showth...ighlight=FP91G
      The inverted MAY be fried, but at this point i believe that is irrelevent since the power LED wont even stay on. - Correct
      -Do LCDs use same voltages as regular computer? 3.3, 5, 12? -Quite often
      My thinking is that if they do, use a bench power supply to test the LCD, if that works then i know the LCD power supply is bad. Yes but as you say
      There was a post recently telling how to do this - I will find it and add as an edit.
      -short? Possibly
      -something fried like a fuse? - possibly For some reason i dont think its going to be that cut and dry.......
      Did you have the board and it stopped working - found it on the pavement?
      We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...1&d=1290283049
      https://www.badcaps.net/forum/attach...7&d=1280167246
      When you open it up you will probably find the voltages printed near the connectors.
      EDIT https://www.badcaps.net/forum/showpo...9&postcount=15
      • mattch
        • Mar 2010
        • 121
        Great, thanks. I will get pictures sometime today
        apparently my google foo needs some rework, i tried searching (for similar posts) befor i poseted but came up dry (site:*.badcaps.net)
        As for this monitor, I help a a few people with their computers, one of those people called me about this one, we had already replaced it and they just wanted to trash it. This one was working friday, came back monday and it stops working. my goal is fix it and replace an old crt i have on the bench.
        • 999999999
          • Sep 2006
          • 774
          The first thing to do is always to open the unit and examine it. The shut down is consistent with the problem my FP91G had, bad caps. They were obviously (visually easy to see that they were) vented and swapping in good caps solved the problem.
          Definitely not a fuse, it wouldn't come on at all if that were the problem, would seem 100% dead. If you see vented caps I wouldn't even bother with any other testing before replacing them and trying to power it on.
          • mattch
            • Mar 2010
            • 121
            I have pics, my camera is not the best quality...
            After looking at it, right away i see 8 bad craps (bulging) on the power supply, one of them oozing.
            I will take your suggestion 9x9, replace those and go from there. Im almost certain it will fix this problem.
            2x Jamicon?10v 1000uf
            6x elite 35v 470uf
            Is there a rule of thumb for capacitors replacement can go by as i dont have exact ones? I have various ones laying around but different voltages and capacitance.
            edit: i only have some (new) rubicon 6.3v 2200 uf, i suppose i cant use those. rest are ones i pulled off other parts.
            • selldoor
              Slow Learner
              • 7870
              Hi - no you cant use the 6.3v ones - here is a guide
              http://www.niccomp.com/help/capsubguide.asp
              Sometimes it is good to increase the voltage by one notch but the uf value should be maintained unless you know what your doing.
              Using old ones - unless you can test with an esr meter may not be a good idea if bad they could cause knock on damage to components more expensive and more difficult to replace.
              Some members would recommend replacing all capacitors of same makes that have gone.
              Retiredcaps has an insert he uses s - I will add if I can find it.
              EDIT
              https://www.badcaps.net/forum/showpo...84&postcount=3
              • mattch
                • Mar 2010
                • 121
                Thanks, that website is great.
                as a matter of fact all of the elite and jamicon ones are bulged (hard to see from pic) so all will replaced. But that makes perfect sense as to why i would replace all of the same ones even if they otherwise look ok.
                Being as impatient as i am, i would like to run out and pick up replacments today.
                Is radioshack a bad idea? seems they are all NTE brand
                • selldoor
                  Slow Learner
                  • 7870
                  Not a great idea - I am not saying they wont work but you may have to replace in a few weeks time - again if they go they can take other components with them.
                  They are just not good for this application, obviously its your choice but not recommended.
                  • 999999999
                    • Sep 2006
                    • 774
                    Avoid radio shack caps, every now and then they have sold some Nichicons (PW or PM series, I forget which) in the assorted cap packs that were close to what you'd want (105C temp, very low ESR) in type but not the right values and sizes.
                    For your needs Digikey is the best bet. With a small order like this (under 8 oz.) they can ship it USPS for around $2 and it'll arrive in 2 or 3 days (average).
                    • mattch
                      • Mar 2010
                      • 121
                      got it. i will order those, i think ill checkout the badcaps store since i have to wait either way.
                      many thanks for all the suggestions, once i get the caps i will post results. Then probably open a few more bad lcds i have laying around =D.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        RadioShack is unlikely to stock or sell low ESR caps which are required for the power supply (SMPS application). They are likely to carry general purpose caps which have different characteristics than low ESR caps and not suitable for SMPS application.
                        --- begin sig file ---
                        --- end sig file ---
                        • tamerelapute
                          [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                          by tamerelapute
                          I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                          Except the cpu, I cant feel anything getting warmer.
                          I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                          I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                          I believe that if the cpu was fried,...
                          07-08-2024, 03:28 PM
                        • seppde
                          Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                          by seppde
                          I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                          ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                          The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                          In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                          02-09-2024, 05:19 AM
                        • Malcolma172
                          Philips 42pfl6008s/12 red led comes on for a second and then goes away but 3.49v stay active
                          by Malcolma172
                          I was trying to repair my tv wich previously had a blinking red led 2 times and it kept going. After shorting the sdm the blinking led changed 5 slow blinks and 3 fast ones wich in the service manual meant error 53 / the fusion chip.
                          After I heated the fusion chip with a hairdryer for 5 minutes it started working perfectly but after a day it stopped this time no led blinks even in sdm mode.
                          After probing the psu I have 3.49v and for 1 second I have at least 2 12.3v lines active the fusion chip gets warm in that second the led turns on and then the 12v lines start losing power...
                          Yesterday, 01:20 PM
                        • Lapsmith
                          Fried capacitor on Dell-5520. Guilty as charged.
                          by Lapsmith
                          While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                          07-06-2025, 11:08 PM
                        • ChatBTC
                          Benq EX3501R
                          by ChatBTC
                          Hi!
                          I am new to this site, and found it via LLM ChatGPT.
                          I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                          01-24-2025, 08:49 PM
