Samsung P2370 Syncmaster, no power
  • Karthanon
    • May 2012
    • 6
    Good day, all. Been lurking for a week, trying to figure out what may be wrong with a friends P2370 monitor, but I thought I'd finally ask for assistance.
    It was working fine, until one day last week he turned on his computer and the monitor powered up, but no screen appears - neither a test screen (when no DVI cable is plugged in), nor a screen from my laptop (the Samsung does get detected fine by Win7, and I can clone/extend my desktop to it, but nothing ever appears). The flashlight test doesn't show any picture at all, so it's not just a problem with the backlight (although based on other statements made here that may or may not work all the time)...
    I'm not seeing any issues with caps (ie. bursting/leaking), and the fuse (F301, a 5A Littelfuse if their datasheets are correct) shows okay (a continuity test comes up ok, multimeter set to 200 Ohm comes up with 0, not infinity) from what I can tell.
    What else do I need to check? This monitor has it's transformer external to the monitor on the power brick, so at least it cleans up the guts of the monitor a bit...
    I can tell that 12V is coming across to the inverter section, so it is getting power - I guess I can check if the CCFL's are broken/dead, but that requires ripping apart the monitor even further, eep!
    I will put up some pictures tomorrow, if that's okay.
    Thanks!
    Regards,
    Karth
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung P2370 Syncmaster, no power
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    It will be useful if you can say a bit about yourself - skills tools etc.
    • Rtech
      • Jul 2010
      • 1095
      On the inverter input plug ,where you measured the 12v power,there is always a ground, and normally two more inputs ,,one for Dim/Bri/Adjust, and one which should switch the inverter on WHEN a signal is present from the PC,this should be in in the order of 2-4 volts DC,so you can measure that as well,and if it is there,When the PC signal is ON, then the problem is definitely the Inverter Board OR the backlights,the latter you can eliminate by using good test ones if you have them
      • selldoor
        Slow Learner
        • 7870
        Did you try reseating the cable to the panel -lvds - both ends. If it is a flat cable clean the ends as well.
        • soopacrucial
          by soopacrucial
          Hi folks,
          10-29-2024, 02:40 PM
        • mrtek
          Samsung UN43NU6950FXZA No power
          by mrtek
          Hi
          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
          Main fuse = OK
          Back light LED = OK. Power them with aux power source
          LED output = OK 156V
          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
          07-20-2025, 08:06 PM
        • khelane
          test active pfc power with lamp test
          by khelane
          Hello
          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
          Is there a way...
          06-03-2025, 01:00 AM
        • Journey11
          Samsung TV won't turn on ... keeps cycling the power relay on & off
          by Journey11
          Hi All,
          First time posting here ... my name is Kevin but my friends call me Journey.
          I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
          After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
          It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
          07-04-2024, 02:44 PM
