BenQ G2420HDB 2STB
  • wm009
    • May 2012
    BenQ G2420HDB 2STB
    I appreciate having this available. I have a BenQ G2420HDB 24 inch monitor and I was getting the two seconds and then black.
    I opened it up and took a lot at the capacitors and they looked fine. I had out my multimeter testing what I could. It all looked fine, so I didn't want to take it any further. Honestly, I don't want to spend the time to go through the CFLs.
    Anyway, I put it back together and gave it one last test. Except this time it was good for two seconds and then it greatly dimmed. The screen is still there and I can see my desktop, it's just very dark.
    Maybe with what is happening now I can at least pin point what is going wrong? Does anyone know?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: BenQ G2420HDB 2STB
    Moved from the 2 seconds to black thread.
    sigpic
    (Insert witty quote here)
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Honestly, I don't want to spend the time to go through the CFLs..
      You have read the 2 sec to black so you know what is involved either you want to try fix it or you cant spare the time- which is it.
      • wm009
        • May 2012
        It isn't one or the other. If my car wasn't working, I wouldn't rebuild my engine because I simply don't have the time, but I do have the time to switch out spark plugs, redo wiring, etc.
        The point I was making is that when I put the monitor back together it BEHAVED differently than when I took it apart. Instead of going black, it went to a dark dim. So my question wasn't about fixing it, but whether this shed light on a particular problem area. If the dimming (instead of black) means that it's probably the CFLs, I'll simply leave the monitor by the trash. If it signals a loose capacitor or transistor connection, I'd probably open it up.
        I hope this illustrates my intentions with the question I asked.
        • retiredcaps
          • Apr 2010
          • 9271
          Originally posted by wm009
          IIf the dimming (instead of black) means that it's probably the CFLs, I'll simply leave the monitor by the trash.
          If you are going to trash it, PM me. I'll have a friend who lives in Calgary pick it up.
          Now having said that, 2 seconds to black can be
          a) bad caps
          b) bad ccfls
          c) bad ccfl wiring (especially the return wiring)
          d) bad secondary windings on the inverter transformer
          More details starting with post #19 at
          https://www.badcaps.net/forum/showthread.php?t=10419
          Also, see budm's Inverter tester using old CFL
          https://www.badcaps.net/forum/showthread.php?t=19987
          --- begin sig file ---
          --- end sig file ---
          • kalemaroni
            BenQ 3501R turns off after 1-2 seconds
            by kalemaroni
            The capacitor on the board was slightly bulged at the top so I replaced. Unfortunately the cap I bought on eBay was much thinner than the original, even though the spec was the same (4.7uf 100v). The problem persists. Would the thickness of the cap actually make a difference - is it worth trying to find the correct one?
            11-19-2024, 11:55 AM
          • twonk9098
            Lenovo Legion 5 high fan spin turns off after 34 seconds
            by twonk9098
            I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
            I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
            I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
            I have tried a few new bios but exactly...
            07-14-2024, 11:19 AM
          • liquidzorch
            Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
            by liquidzorch
            Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
            10-18-2024, 05:19 PM
          • Rick_1234
            by Rick_1234
            Good evening, gentlemen.
            Things I tried
            06-22-2024, 04:44 PM
          • PowellSkier
            Harman/Kardon AVR 645 returning to stand-by after a few seconds.
            by PowellSkier
            A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
            06-17-2024, 11:43 AM
