Re: Dell 2007FPB teardown
It's burned too close to the ground, replacing won't fix that. Besides, there is almost nothing left from the copper pad, where would you like to solder it??
buy a new connector - and sand away all the carbon on the board.Leave a comment:
That's not safe to use any longer. I am afraid you will have to remove the inlet, clean as much as you can, drill out the burned stuff and solder IEC C14 cable in the two good positions and somewhere further on the single bad position (maybe on the fuse directly). Than somehow firm it in position so nobody tears it off.
Or you can cut piece of the board out and than place a new one in there with some epoxy, but that's too much of a work if you ask me and I am still not entirely sure it would be safe on full AC input voltageā¦Leave a comment:
Behemot, it sounds like you need to start a new thread. If you have some time, you could start a FAQ on troubleshooting lack of one rail when the others are working.Leave a comment:
Still have not found anything. All the resistors check fine and have same value as resistors in the same position of the second PWM controller which works fine providing both +3.3 and +5 V. But the +12 V is jsut still not there. Something is making the PWM go into 0 % switching mode.Leave a comment:
I just did the most grimy 2.7k fix, I should have taken pictures.
Used an enormous leaded resistor lol
Works perfect nowLeave a comment:
So the DTC for the +12V part of the TL1451 is at 2.44 V which means it is at 0 duty cycle. I think the problem is here.
I have checked all the corresponding SMD resistors and tiny SMD transistors around other TL1451s and all of the values are the same. So it seems those are OK. That really leaves me with bad TL1451 only?
Replaced TL1451 from scrapped display, no change! Bloody hell this PoS.Last edited by Behemot; 05-14-2015, 12:46 PM.Leave a comment:
I've replaced the mosfet with another 2SJ598 with no change. Tested all the 272 resistors and they seem to be very well in spec.
ADD// Eh, guys, did these displays came in pairs? I opened the other one and everything is mirrored in there. What was right is left and vice versa. The USB board has all four channels with four DC-DC modules.Last edited by Behemot; 05-14-2015, 10:52 AM.Leave a comment:
Got a problem too with these. The owner plugged the speaker bar into runnign display, boom and monitor was not turning on since. He tried another one, plugged while off, turned on and the same.
I opened one, the 3A fuse was burned. Replaced it and I got image with +3.3 and +5 V rails, but the +12 V feeding the speaker is not there. Transistor is not shorted, however, it has 19 V on both source and gate, also there is 19 V on those small SMD transistors nearby the side USB connectors. Should I try to replace the FET or something else?
Speaker does not seem to be bad however, I hooked it to old AT supply and it seems to be working normally, drawing like 0.01 A while playing nothing.Last edited by Behemot; 05-07-2015, 07:21 AM.Leave a comment:
I also want to thank everyone here who troubleshooted the Dell 2007fpb power problem and about the solution with the resistor 2.7k fix. Worked like a charm for me!Leave a comment:
iw4egx please start a new thread - this thread is meant to be for
reference onlyLeave a comment:
Hello to everyone, i'm new in this forum and have a dell 2007fpb that will not power on, i've used for 3 years without problam, a day...died.
I've opened it and have the 4 boards blacklight, power supply, control board and 12v board.
For check the PSU voltage where i have to test voltage and between what pins?Leave a comment:
Another fix changing the resistor under the white glue. My second monitor failed in the same way as the first. So now they have both had the same fix about 3 months apart.
AC21 you're a real star ! Thanks also to KALMARA.
So if you're not working. First place to look is under that glue. 2 for 2......Leave a comment:
HI FRIENDS!!
I'd like to mention that replacing the 272 resister with another 2.7K worked a treat. I can now check sites!
I wonder if there was a bad batch of resisters or maybe a cold solder joint? I spoke with a friend who has much more electronics knowledge and he mentioned that he rarely sees resisters fail, and when they do they usually burn up.
Thanks to all who did the grunt work on this!Leave a comment:
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by ckom26Hello, folks.
Please, forgive this dumb question but I own a 2007FPb whose logic board is FUBAR (really). Obtaining a replacement is not easy any more (or unreasonably expensive) so I was wondering if replacing the logic board with one from the same line (e.g. 1708FP or 1907FP) would bring it back to life. Are the resolution capabilities for each one "hardcoded" into the main GENESIS chip or auto-sensed and applied? Has anyone tried something similar?-
Hi All, I need help identifying a replacement for D1 (same as D2 through D5) on the Dell 2007FPB board please? The board ID is an LG Philips LM201W01-SLC1-F11. Thank you for any help! It popped under power while troubleshooting, oops!2 Photos
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... -
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos - Loading...
