Re: Dell 2007FPB teardown
I got another piece of this display and unlike the previous two (or was it three?), I do not think this one ever saw the sound bar. However, there was no +12 V anyway. Is it actually supposed to be on all the time, or is it activated only when the bar is plugged in??
I had a 2007wpb that wouldn't turn on at all unless i let it sit plugged in for a few hours..then it would turn on long enough for the "no signal message to come on" then die again it would repeat this randomly.
After reading kalmara's post i checked the row of resisters under the "white blob of dielectric" on the usb board .. the first one is a 2.7k (printed on it 272) i first jumped a resister of unknown value across it and the monitor started working.then i desoldered the SMD and soldered in a regular 2.2k resister and put it back together ..everything is working great so far.
I read a bunch of post here and there but couldn't figure it out so i made this post so people in the same situation can do the same but maybe you should replace it with the right resister
here are some pictures of the location on the resister thanks to budm.
After re-trying, it appeared that those strange problems were induce because I applied ground on the screw hole. When applying GND on the pin header (pins 5-6 from left) they disapeared.
Then I could see the problem : only 5V was working, 3.3V and 12V are off.
In the end I found the problem it was 3 SMD resistors that were out of specs (153, 010 and 473) in the row of SMD under the white dielectric blob. Just upside the right PWM IC on my picture.
I found out comparing the resistances values read with ohm-meter between the 3.3V PWM circuit (that was not working) with the 5V PWM circuit (working).
- 153 (15k) and 010 (10k) were clearly open circuit
- 753 and 473 did not read the same values between 5V PWM and 3.3V PWM.
So I unsoldered all that were not the same as on the 5V to check them. Result was 753 was ok (75k), 153 010 and 473 were open-circuit. (473 should be 47k ohm)
I replaced them with new SMD resistor and the 3.3V came back.
I did not fix the 12V as I don't need it. Although I tried but I saw no differences in the SMD resistors of the PWM (with 5V PWM) so I did not knew what else to do.
Hope this might help someone sometimeLeave a comment:
I have one of these LCD and it does not turn on.
Reading through those pages I tried to find the error, but no luck so far.
I looked for exploded caps on all boards but nothing obvious. Then I focused on the USB board as all errors on this topic seems to come from there.
I tested the resistors under the white bulb, but none is deffective. 3A fuse is not blown. Zener I am not sure how to test them. When I use diode on my multimeter I read 0.160 and all paralleles pairs of diodes read the same.
I wanted to test voltage output without having the 220V plugged in so I used my laboratory powersupply and tried to apply 19V directly on the board input (before the fuse) in order to check 5V and 3.V
Something quite strange happens:
- first time I did it there had been a shortcut appeared between 19V and GND, so my laboratory powersupply voltage droped. I unconnected. Then I could still measure the shortcut between ground and 19V. Few minutes after the shortcut was gone.
- second (and other) time I plug in 19V when my 19V electrod come close there is a strong spark, but after the spark it seems normal. The voltage do not drop as first time. And I do not have a shortcut between 19V and GND anymore...
But on all converter bucks Q6 Q9 and Q14 I read 19V both on the input and the output
Should'nt I be reading 5V 3V and 12V on the converter output?
I am not very good yet with debugging electronics so maybe I'm missing something big! Please let me know if this gives you any idea.Leave a comment:
Hey, guys!
Thanks for "272" resistor hint.
Dell 2007FP (2008 year) didn't turn on since few days ago. Now works as new!
Official Dell service in Kyiv, Ukraine: won't fix (read as "go buy newer one").
ac21 and others
https://www.badcaps.net/forum/showpo...3&postcount=12Leave a comment:
Thank you very much for this informative teardown! Thanks to this I was able to fix my friends 2007WPb with the "no power at all" symptom. The cause was an defective 47K smd resistor at R52 under the white thermal glue on the USB board.Leave a comment:
Thank you very much for this informative teardown! Thanks to this I was able to fix my friends 2007WPb. The cause was an defective 47K smd resistor at R52 under the white thermal glue on the USB board.Leave a comment:
The 2.7K resistor on the bottom is testing good on my unit but there is a 15k marked 153 that is open. So be sure to test the rest!Leave a comment:
Hi, thank you for this thread. I successfully fixed my Dell 2007FPB with a 2,2K resistor taken from a graphic card. It works so far but I have not tested it during a long time so I do not know if this reparation will last.Leave a comment:
I replaced the 272 resister but still now power button light. Has anyone found any other likely suspects for this monitor? Mine is the 2007wfpb. Thanks.Leave a comment:
I just wanted to thank all involved for this post.
I was after an old monitor to use on a CCTV system. Being a cheapskate (as I am), rather than buy one, I popped to my local waste & recycling centre and found one of these babies on the scrap pile. As it looked in good nick, I whipped it onto the van, but on getting it home found it wouldn't power up.
I popped her open to check internal fuses and PSU caps all to no avail, then I came across this thread. Sure enough, that 2.7k resistor was open circuit, but I found a suitable candidate on a scrap PIR sensor.
Seems funny that something so small should bring the whole thing to its knees. I assumed it would be a PSU fault and never imagined it would be a resistor hidden under a glob on the USB board.
Still, I'm an electrican by trade, not an electrical engineer, so 230v cables and nuisance tripping RCD's are my cup of tea. I doff my hat to you chaps though; you really know your bananas!
Cheers,
David.Leave a comment:
Thank you all, Could not have done it without you
Yesterday afternoon and half a night was well spent. Ordered power supply from eBay for my 2007FPb 1200x1600 monitor, but that was a $40 bust. That was not it. Combing internet and
Finding Badcaps, measuring values on four boards components, I came across the defective resistor. Found 2.7K resistor in my parts supply and soldered it in. not the prettiest soldering job, but guess what it works.
Cheers,
Radek
capacitors
Budm, you made a post #129 abought samsung capacitors for ln52a550 tv the capcitors look the same but have different part numbers so witch one goes on top and witch one goes on the bottom I CHECKED AND ONE IS 35-OHM AND THE OUTHER IS 70-OHM ??thanks,johnLast edited by johnz16; 02-09-2016, 09:32 PM.Leave a comment:
Might as well resolder those 3 post so it will not fail like the original one, the AC inlet is not well mounted and supported so plugging and unplugging the power cord at the inlet will weaken the joints seen too many of them failed.Leave a comment:
Kinda expensive, new connector should cost like a buck and than it only needs some soldering and silicone tricks (or something similar)
BTW recently I've been disassembling the speakers I got which blew the +12 V rail. I think the reason is obvious…all caps were like 99 baloons. So next time before you connect those Dell speakers to your expensive display, always recap that thing first! You'll save yourself lot of troubles. And test them with external +12 V source lolLast edited by Behemot; 02-09-2016, 04:14 PM.Leave a comment:
Thanks everyone for the advice. I found a new OEM power board on eBay for $25. Popped it in and my display is like new.Leave a comment:
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by ckom26Hello, folks.
Please, forgive this dumb question but I own a 2007FPb whose logic board is FUBAR (really). Obtaining a replacement is not easy any more (or unreasonably expensive) so I was wondering if replacing the logic board with one from the same line (e.g. 1708FP or 1907FP) would bring it back to life. Are the resolution capabilities for each one "hardcoded" into the main GENESIS chip or auto-sensed and applied? Has anyone tried something similar?-
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
Hi All, I need help identifying a replacement for D1 (same as D2 through D5) on the Dell 2007FPB board please? The board ID is an LG Philips LM201W01-SLC1-F11. Thank you for any help! It popped under power while troubleshooting, oops!2 Photos
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... - Loading...
