Another SAMSUNG 2493HM !
Re: Another SAMSUNG 2493HM !
The cap was measured and checked out to be correct.
I am however worried as I am getting a reading of 294VDC across the big cap - the testing point there indicates that it should be 380V, with nothing but the AC cable connected. Am I correct in assuming the problem appears to be on the Hot side? Which components should I check out?
Ok, I connected all but the inverter board and measured 380V on the big cap, but still no 24V...
Where should I go from here?Last edited by Leonrsa; 03-29-2014, 03:50 AM.Comment
Yep and it does not seem you even have low-ESR caps. What series are they?
It is not with low output so if there is some preventing the main PSU turning on, the PFC boost is not active, rendering aprox. 315 V rectified. When the PSU turns on the boost turns on as well. Possibly low input voltage, in the range of 220 V AC?Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Have you also replaced the small capacitors? Usually you have to be very carefoul, sometimes changing low-ESR for GP and vice versa breaks the circuit operation. If you did, I can have a look at my board what caps are in each position.Less jewellery, more gold into electrotech industry!
Check the DC voltage on PS_ON pin on the power supply when you toggle the power switch, it should toggle between <1 and > 2V. hat is your AC line voltage feeding the unit? at 220VAC, the voltage on the main filter cap should be around 310VDC when monitor is OFF.
BTW, you have to have the monitor connected to running PC, otherwise it will go into standby mode in a few seconds if it does not see the video signal.Last edited by budm; 03-29-2014, 07:43 PM.Never stop learning
I did replace all the small caps about 3 moths ago, but it seems that the caps were GP Hitano. The salesman assured me that they were the correct type for the job...
I was under the impression that all the electrolytics had to be low-ESR?
This is the list I obtained of caps to be replaced:
Qty (2) 1000uf 35v
Qty (1) 2200uf 10v
Qty (1) 470uf 35v
Qty (1) 1000uf 10v
Qty (2) 10uf 50v
Qty (1) 2.2uf 50v
Qty (3) 47uf 50v
Qty (1) 22uf 50v
I will try and find caps of the make as listed on this thread:
https://www.badcaps.net/forum/showthread.php?t=2280
thanks for the help so farComment
So what DC voltage do you have at PSON pin?Never stop learning
Hi budm, I am afraid I did not measure the voltage on PSON as I have put the monitor aside until new caps arrive. I was informed that the caps I used (Hitano) as replacements 3 months ago were bad and not ESR. I have ordered the best (in South Africa) low-ESR caps I could find, being Rubycon YXF series, and will report back on progress.Comment
I got first sucessfull pacient, this tiem only caps were bloated. Still got two with blown primary, unable to bring them back to life
You have PS_ON bu the PFC Voltage booster is still not working, PFC circuit section will need to troubleshoot next.Last edited by budm; 04-01-2014, 11:12 AM.Never stop learning
Budm you sure? The booster is off when only SB supply runs, with aprox. 315 V DC rectified.Less jewellery, more gold into electrotech industry!
In standby mode with 220VAC input, the VDC on the filter cap is about 220VAC X 1.414 = 311VDC. When PS_ON is applied, the PFC Voltage booster will kick in to boot the voltage to about 360~400VDC range. He indicated that he has 292VDC on the cap which lower than it should be unless his line voltage is <220VAC.Last edited by budm; 04-01-2014, 11:53 AM.Never stop learning
What else than some undervoltage may that be? Where else would the power go when the boost is not active? It would have to be burned somewhere, he did not indicated somethig is heating in it…Less jewellery, more gold into electrotech industry!
The only load it has is the standby power supply. He needs to find out first what is his AC voltage is, if it is 220VAC, then next place to check will be that main filter cap, check it capacitance and the AC ripple on it.Never stop learning
Oh yeah, good point with the capacitance, non-true RMS voltmeters won't read amplitude
I use FLUKE with T.R.M.S.Never stop learning
On the other hand it won't tell you capacitor may be bad if you don't have ESR meter…while El Cheapo meter would at least indicate.Less jewellery, more gold into electrotech industry!
I found the following...In standby mode with 220VAC input, the VDC on the filter cap is about 220VAC X 1.414 = 311VDC. When PS_ON is applied, the PFC Voltage booster will kick in to boot the voltage to about 360~400VDC range. He indicated that he has 292VDC on the cap which lower than it should be unless his line voltage is <220VAC.
Line voltage - 205VAC
450V Cap - Standby - 290VDC
- On - 390VDC
Seems to be OK
by narfhi all,
first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
what i've found so far:
- the PSU does its job and supplies 12V to the mainboard via the connector.
- shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
- not far away, there's the first cap with a resistance of 0.7 ohms.... -
by madyoyoHI.
I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming.... -
by nick3092I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
by multimesutHello friends,
A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....1 Photo-
11-13-2024, 07:00 AM -
by Big PookaHello all,
I just picked up a LG OLED65E6P off of Craigslist (it was practically free). It functions flawlessly in all aspects except it renders yellows as greens. It does so regardless if the source comes through an HDMI port, or streams in through onboard services such as Netflix.
I've factory reset all the color options, cleared the panel noise via the onboard option, and waisted half an hour talking to LG customer service.
Have any of your dealt with this situation?
I understand OLED's are susceptible to burn-in, and looking at the... - Loading...
