Dell E173fpf - No led coming on
  • quattro alex
    • Mar 2012
    • 92
    Model: Dell E173fpf
    Fault: No power led comes on and nothing is displayed on the screen at all.
    Observations: constant ticking noise heard from T850 and I get a constant 131v from the primary capacitor (using mains earthing point)
    I have changed cap C506 (4.7uf 16v) as the ESR was slightly high - 2.1
    I have also changed D854 (SRF 10-10) as I had seen on another post that this part was faulty and before I replaced it the solder points looked slightly different compared to the rest, maybe due to it running hot?.
    I have checked the board and cannot see any burn mark at all. I have checked the larger resisters and these are fine. D850 which I think is known as a bridge rectifier tested fine.
    Questions: If I put my negative lead only from the DMM on the primary negative I get some fluctuations in voltage normally between 0.5 to 6v's so what could I do to get an accurate reading from the pins on U850?
    Could someone please confirm what Q850 does and how I might test this component?
    Many thanks
    Ps: I am aware that there is some excess flux which I didn't wipe off prior to taking the photo's.
    Fixed so far: GNR TS902W monitor, Sony Game Gear, Philips FCD565, Arcam Alpha 10, Memorex SA 404amp
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell E173fpf - No led coming on
    1) Is the 131V that you measured AC or DC? Either way, that is super low. Try measuring DC voltage across the legs of C854. Careful, this will be high DC voltage. If it is working properly, it should be mains x 1.414 DC volts.
    2) Ticking suggests
    a) bad startup cap (likely C857 - 47uF 50V cap?)
    b) bad SMPS IC U850
    c) shorted component like a diode (check D851, D852, and D853)
    3) Look for the Q850 datasheet. This is your SMPS IC. Once you find it, look for the "typical" VCC startup voltage. It might be something like 16V. C857 feeds the Q850 VCC pin. Measure the VCC pin on Q850 with respect to Q850's GND pin.
    4) See if Q850 VCC is shorted to GND.
    5) Measure the DC voltage across C857. It should be steady.
    6) Those are excellent clear focused photos. Easily in the top 5 best photos this year.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      Sorry for #3 and #4, I meant U850 (the 8 pin IC) is likley your SMPS IC.
      Q850 is your power mosfet (3 pin IC mounted on heatsink). You can see if the power mosfet is shorted by measuring the resistance between D-S, D-G, G-S.
      • quattro alex
        • Mar 2012
        • 92
        Retiredcaps - that to do list has really helped, here's what I've got:
        1) The 131v was DC on the primary cap. Measuring from the legs (solder side) I get 340v dc steady.
        2a) C857 is a 10uf 50v - tested at 0.87esr 9.72uf, live test has dc voltage fluctuating up and down between 13-19v
        b) diode / continuity test of U850 pins 1 to 7 gave a reading of 477 on the DMM - I am assuming this is ok?
        c) diode / continuity test : D851 - 494
        D852 - 472
        D853 - 498
        3) U850 has these part no's (used a DSLR sensor loupe for reading - very handy!!) on it SG6841S & KA126690501E I have located the datasheet and included some diagrams.
        datasheet specs:
        Min Typical Max
        U850 - startup threshold voltage 15 16 17
        - minimum operating voltage 9 10 11
        I tested the resistance on Q850. I get 94K between G&S but testing S-D or D-G the resistance keeps changing normally increasing past the 200k mark.
        What do you recommend next?
        • retiredcaps
          • Apr 2010
          • 9271
          That is why I write enumerated paragraphs.
          Assuming there is no PFC, 340V DC implies 240V AC mains.
          The ESR looks good when compared to a Panasonic FC (1.3 Ohm).
          Since I don't know what the 477 unit is, I would prefer to see a traditional resistance measurement versus a diode/continuity. Retest and report a resistance measurement.
          D852 - 472
          D853 - 498
          What is the measurement the other way? If it is out of range, then the diodes are good.
          Q850 is not shorted.
          • quattro alex
            • Mar 2012
            • 92
            Your correct I am on 240v ac
            The resistance goes from 30k increasing through to about 330k then it starts decreasing. This is for pins 1-7 (positive on pin 1)
            They are out of range when tested the other way.
            Thanks for confirming this.
            • retiredcaps
              • Apr 2010
              • 9271
              1) Okay, I have one more test that I can think right now.
              Measure the resistance between pin 1 (GND) and other pins. That is, 1-2, 1-3, 1-4, 1-5, 1-6 and 1-8. Report all readings.
              2) If none of them are shorted, my best *guess* is that SMPS IC is bad even though it is not shorted. If you search this forum for SG6841, you will see similiar cases where this IC is bad.
              If you have to order a new SMPS IC, I suggest replacing the startup cap with a Panasonic FC even though it tested fine with your ESR meter.
              SG6841 is available on ebay for $2.50 + $1.00 shipping.
              • retiredcaps
                • Apr 2010
                • 9271
                I could be wrong, but I don't think this monitor (due to its age?) uses PFC otherwise the DC voltage should be in the 390V DC range.
                • quattro alex
                  • Mar 2012
                  • 92
                  1-2 = 78.2K
                  1-3 = 30K-->130K+
                  1-4 = 26K
                  1-5 = open
                  1-6 = 41ohm
                  1-7 = 90ohm --> open
                  1-8 = 172ohm -->open
                  I think it was made in 2005 and even though the mains is probably closer to 230v I take this is outside the correct spec?
                    You may want to download one of these service manuals:
                    http://elektrotanya.com/?q=showresul...oria=&kat2=all
                      Please see the notes in the pictures, see what happen when you lift one end of the resistor and let us know what happen.
                      What I am trying to do is try to remove one load at a time to find out if the loads are causing the power supply to go into shutdown, or the power supply itself is having the problem.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        1-6 = 41ohm
                        I think this is shorted, but I can't be sure since I don't have this SMPS IC.
                        • quattro alex
                          • Mar 2012
                          • 92
                          Ok I lifted one end of the resistor at R870 ( and may have pulled part of the pad unfortunately at the same time) and the ticking still persists. I get no voltage at all when testing to the ground point or between the legs of L853.
                            OK, the shorted circuit is not in the logic circuits side, you will have to remove the round inductor and see if the problem goes away next, you have to use good 40watts or more with large tip (2.5~3mm wide tip) soldering tool to work on this double sided circuit board, otherwise you will be damaging the traces on the board.
                            • quattro alex
                              • Mar 2012
                              • 92
                              I have removed the inductor but the ticking is still there. Also primary cap DC voltage is fluctuating between 280 and 330volts.
                                That pin 6 of the IC should be connected to the resistor (R859)Source leg of the MOSFET through R861 (value as printed on the body?) Can you tell us the value of R861 that is connected to Pin6?
                                OK, I see that the R861 is 470 Ohms, so you are reading 41 Ohms, it must have an internal short inside the IC as retiredcaps has suspected. You can try lifting pin six and measure the resistance between PIN 6 and Pin 1 again.
                                • quattro alex
                                  • Mar 2012
                                  • 92
                                  Can you tell us the value of R861?
                                  470 is the value and when I test the resistance with the DMM on the 200 scale I get 47.0
                                    47 ohms is correct, I thought I saw 471 as printed but not sure if I was seeing it right.
                                    I do not belive you will be reading 41 Ohm between pin6 and Pin 1 if the resistor is 47 Ohms.
                                    • quattro alex
                                      • Mar 2012
                                      • 92
                                      Your correct - I've just measured again and the reading was 48.2 (-0.07 for leads resistance) = 47.5ohm
                                        OK pin 6 is good.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
                                        • nimbus2000
                                          Dell Optiplex 7040 MT ,saw smoke coming out
                                          by nimbus2000
                                          Dell Optiplex 7040 MT (Service Tag S/N DSNJ992)
                                          Built a PC on this used motherboard(DELL MIQ170R Swordfish DDR4 MT 14057-1). At first, when I plug in power cable(without even pushing start button) fans immediately start working at normal speed then after 4-5 seconds it starts working at full speed and stays that way until you manually turn it off by holding power button. While fans are working nothing shows up on screen.
                                          Also tried turning it on without CPU and RAM. Acts same. As soon as power cable is plugged in fans working at normal speed then goes to full speed after a while......
                                          02-23-2023, 10:52 PM
                                        • diamon
                                          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                          by diamon
                                          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                          Pictures of these boards:
                                          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                          Dell...
                                          02-28-2024, 12:51 PM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
