Syncmaster 2253lw inverter "not turning on"
  • nickt1862
    • Apr 2012
    • 23
    Re: Syncmaster 2253lw inverter "not turning on"
    Originally posted by retiredcaps
    See my fellow Canadian's 5 minute tutorial
    http://www.youtube.com/watch?v=bF3OyQ3HwfU
    For each value above, go to digikey.com type the following into the search field.
    10uf 50v fr
    If no stock, try
    10uf 50v fm
    If no stock, finally try
    10uf 50v fc
    FR and FM are the preferred choice. If neither are available choose, FC. All are made by Panasonic and are good quality low ESR caps.
    Will do! Can't thank you enough!
    • nickt1862
      • Apr 2012
      • 23
      Okay, today I received the caps and multimeter.
      Replaced remaining caps and STILL doesn't work. All I get still is the solid blue power light.
      However if I tested the fuses correctly using the multimeter one of them is no good.
      The "button" fuse I tested its continuity and ohms checks out at "0" - it dropped to that.
      The "longer green" fuse (125v F4 0AL) by the inverters has no continuity and the ohm number keeps on going up and up and up.
      The diodes are fine for continuity in the one direction as it should.
      So am I correct if testing a fuse on ohms if the number keeps on increasing means the that fuse is no good? Please correct me if I'm mistaken, but in my research think I'm correct. If that fuse is bad I hope it's easy to acquire as I never ordered such.
      • retiredcaps
        • Apr 2010
        • 9271
        A good fuse should measure less than 1.0 ohms. If the ohms reading keeps increasing, then that fuse is bad.
        --- begin sig file ---
        --- end sig file ---
        • retiredcaps
          • Apr 2010
          • 9271
          45 cents at digikey.com
          http://search.digikey.com/us/en/prod...1018-ND/614953
          • retiredcaps
            • Apr 2010
            • 9271
            Sometimes fuses die due to fatigue. Sometimes not.
            Post a clear focused picture of the backside of the power board. Usually there are some mosfets. If they are shorted, they may have taken out of the fuse.
            See section on mosfets for how to test
            https://www.badcaps.net/forum/showpo...4&postcount=19
            • nickt1862
              • Apr 2012
              • 23
              I know that the photo above is "lousy", but if you see that "long" green fuse by the cap on the right by the inverter in that photo is the one that failed.
              Now where to get one - can't find it as maybe I'm searching wrong.
              Can you please give me a suggestion?
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                See posts #24 and #25.
                • nickt1862
                  • Apr 2012
                  • 23
                  Thanks, we both must have posted at the same time so I missed them.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    I should have mentioned that since the fuses are only 45 cents, you might as well get 2 or 3 in case it blows again.
                    • nickt1862
                      • Apr 2012
                      • 23
                      Good idea for sure.
                      Well I have a donor one (that I just realized I had laying around) that I'll use to see what happens from an old power board of a crappy monitor which same rated fuse checks out.
                      If it works I'll await my next cap order to order these and with me finding things that will be soon.
                      Just today I repaired a 20" Samsung monitor by replacing all the caps - of course that now works fine and which I won't personally use but the 22" (2253lw) that I want to work for me doesn't - lol!
                      • nickt1862
                        • Apr 2012
                        • 23
                        I replaced the fuse and now it's totally dead even though the fuse checks out before and after the installation.
                        Sounds like this monitor doesn't want to work for me.
                        Time for mosfet check.
                        EDIT: Okay tested the mosfets and one is shorted - fun fun fun! lol!
                        What would I do without a multimeter? I know, I would've given up already.
                        • nickt1862
                          • Apr 2012
                          • 23
                          After back and forth for a couple of weeks the repair of this monitor is dead! I screwed up taking out a mosfet that it took the trace of a leg off the PCB.
                          I'm so ticked off!
                          Thanks for the help till this point - I really do appreciate it.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Post a clear picture of the back. It might be possible to bridge the pins if depending on what you lifted OR you can install a jumper wire to another component.
                            What is the part number of the mosfet?
                            http://www.circuitrework.com/guides/6-1.shtml
                            • Jasgriff
                              • Feb 2012
                              • 578
                              Yeah definitely don't give up on it as its unlikely that it cannot be repaired.
                              As retiredcaps says we need as nice clear picture.
                              Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
                              How to resize your pictures guide click HERE
                              Retiredcaps Ideal post example click HERE
                              • nickt1862
                                • Apr 2012
                                • 23
                                Thanks guys, that power supply board is not worth repairing as I found that also out one of the inverters is bad as well = comes out to too much $$ and effort and just makes no sense to me.
                                Cheaper for me to find a used or new working power board as eBay has some for $2x.xx shipped.
                                • x_orange90_x
                                  by x_orange90_x
                                  01-29-2025, 09:24 PM
                                • Gentian
                                  APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                  by Gentian
                                  I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                  It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                  03-06-2023, 07:07 AM
                                • valvashon
                                  Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                  by valvashon
                                  For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                  History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                  01-04-2024, 01:44 PM
                                • eccerr0r
                                  A modified sine wave inverter + a grid tie inverter?
                                  by eccerr0r
                                  If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                  Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                  08-31-2023, 09:14 PM
                                • caseyjay_48
                                  Sony KDL-46BX450 Inverter Troubleshoot Logic
                                  by caseyjay_48
                                  I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                  I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                  09-23-2022, 08:08 PM
