Dell E207WFPc Vertical Lines
+ More Options
Posts
  • chuckup
    • Apr 2012
    • 15
    Hello All,
    First post great forum!!
    Please see attached. I have two of these Dell E207WFPc's that are doing the same thing. I have searched this forum for related symptoms with no luck. Was hoping someone can look at picture and point me in the right direction. Have all test equipment at my disposal if needed.
    Thanks,
    Update: All voltages from the power supply look normal. Verified all voltages on regulators of the video board. Not sure what the voltages are supposed to be leaving the video board to the panel. Removed and re-soldered inverter transformers. Saw a post somewhere about bad solder joints at these transformers. Lines are present with or without input connected. Lines also present on OSD.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell E207WFPc Vertical Lines
    1) Post clear focused top down pictures following my sig file below exactly.
    2) List your power supply voltages and list the part numbers for the voltage regulators and their measured voltages so we can verify.
    3) Include a picture of the panel board. This board is at the top of your lcd and runs the entire length of the lcd. It might be behind a metal shield.
    --- begin sig file ---
    --- end sig file ---
    • Jasgriff
      • Feb 2012
      • 578
      Welcome to the forum,
      The voltage regulators will have a model written on them. This will have a number in there which will correspond to the voltage that you should be getting out from it. Some voltage regulators are adjustable so they will have a model number be we will have to work out what the correc:-) t voyages should be.
      If you let us know what is written on each of the voltage regulators then we can tell you what you should be getting out of them.
      As retired caps mentions above we need pics. Its very difficult advising from a distance and even more difficult when we can't see what your looking at.
      Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
      How to resize your pictures guide click HERE
      Retiredcaps Ideal post example click HERE
      • chuckup
        • Apr 2012
        • 15
        Thanks,
        Voltages exiting power supply
        N/F - 3.07v
        N/C - 0
        Dim - .384v
        +14 - 14.27v
        +14 - 14.33v
        +5 - 5.66v
        +5 - 5.05v
        Gnd - 0v
        Gnd - 0v
        U601 on Video Board - No part number covered with heat sink.
        Pin 1 - 0v
        Pin 2 - 3.38v
        Pin 3 - 5.09v
        Q401 on Video Board - AZ1117D1.8E1
        Pin 1 - 0v
        Pin 2 - 3.30v
        Pin 3 - 1.83v
        U402 on video Board - 691D6
        Pin 1 - 0v
        Pin 2 - 3.03v
        Pin 3 - 4.97v
        No voltage measurements have been taken on the Panel Board yet.
        • chuckup
          • Apr 2012
          • 15
          Measured both regulators on the Panel board.
          J293 9177-18
          Pin 1 - 0
          Pin 2 - 1.81
          Pin 3 - 3.28
          J293 9177-33
          Pin 1 - 0
          Pin 2 - 3.29
          Pin 3 - 4.77
          Just do not know enough about panel boards at this time to know what else to look for.
          Thanks,
          Chuck
          • retiredcaps
            • Apr 2010
            • 9271
            Pin 1 - 0v
            Pin 2 - 3.03v
            Pin 3 - 4.97v
            From what I can see, U402 is a 8 pin IC on the video board?
            Please circle the 3 pin voltage regulator that you are referring to and double check the voltage on pin 2.
            • chuckup
              • Apr 2012
              • 15
              Sorry typo on my part..it's u302. I was verifying voltages as per post from PlainBill below.
              https://www.badcaps.net/forum/showth...207wfpc&page=4
              Not sure which pin is which but
              Top left is 3.03v
              Top Right is 0v
              Bottom is 4.97v
              The number on the IC is 691D6. Not having any luck identifying it.
              Thanks,
              • selldoor
                Slow Learner
                • 7870
                These pictures are marvellous - you wouldnt believe some of them we see, or rather dont see.
                I dont know if it is relevant but in Pic 1 (Panel Board) there is a fuse F5 just to the left of U1 As you get pics and OSD on screen I dont think it can have gone but always worth checking.
                Also I am wondering if your unidentified 691D6 and Killian6pk's unidentified 6910P could be a G910 -Retiredcaps might advise.
                • Tiberian
                  • May 2016
                  I know I know I know this is a very very old thread and thread necromancy is generally frowned upon at pretty much every forum online but...
                  I just got one of these monitors and it's exhibiting the same symptoms. It works great, but obviously those vertical disruptions are somewhat irritating - does anyone know if there was ever a specific diagnosis found and a specific fix, whatever it might happen to be? Hate to just toss out the display because of something that might potentially be fixed with something simple but I don't have a clue myself, just learning from others.
                  If anyone has any info I'd greatly appreciate it, thanks.
                  Note: if an Admin or Mod determines this post needs to go then so be it, it seems to be the only thread with any relevant info at all so I decided to make this post in the hopes of finding a solution.
                  • Stanley1843
                    by Stanley1843
                    06-29-2024, 11:54 AM
                  • atticus_
                    Dell U2518D strobing/flashing with vertical lines
                    by atticus_
                    I dumpster dived a 1440p Dell U2518D screen the other day and figured I'd take a crack at fixing whatever issues it may have. I powered it up to find that even with no signal input the screen flashes rapidly when turned on and has vertical lines across it. I disassembled the monitor and took pictures of the 3 circuit boards inside it along the way.
                    The three circuit boards are labeled "power board l6256-1m", "LED Driver BD L6257-1". and "Interface Board L6127-1". if anyone has schematics for any of them it would be much appreciated...
                    06-16-2022, 02:49 PM
                  • gpo23
                    Sony KDL-40V3000 - Vertical lines
                    by gpo23
                    i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                    With the new t-con the color are good but there are vertical lines on all the screen :
                    I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                    Is there a way to fix the vertical lines on the new t-con ?
                    Thank you for your help
                    gpo23...
                    10-04-2023, 09:11 AM
                  • Firentiosi
                    1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                    by Firentiosi
                    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                    The issues are as follows: the...
                    11-27-2024, 12:33 AM
                  • viking509
                    vizio e65 e3 LED tv color vertical lines center tv only
                    by viking509
                    I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                    03-21-2023, 12:48 AM
