Dell U2518D strobing/flashing with vertical lines
  • atticus_
    • Jun 2022
    I dumpster dived a 1440p Dell U2518D screen the other day and figured I'd take a crack at fixing whatever issues it may have. I powered it up to find that even with no signal input the screen flashes rapidly when turned on and has vertical lines across it. I disassembled the monitor and took pictures of the 3 circuit boards inside it along the way.
    The three circuit boards are labeled "power board l6256-1m", "LED Driver BD L6257-1". and "Interface Board L6127-1". if anyone has schematics for any of them it would be much appreciated if that could lead to knowing what voltages should be where.
    I couldn't find any obvious visual signs of damage (anything burned or brown, bulging capacitors) when inspecting the components on the board, but took many pictures of the boards in case anyone could see something I couldn't.
    STROBING LIGHT WARNING:
    I made an album on google photos, as well as a video of the problematic behavior of the monitor. - if you have any issues with strobing images or flashing, be aware that the problem displayed in the video is quite striking.
    I have a multimeter and a soldering iron, and am willing to test voltages and such, but not sure where to start with that. Please let me know if you have any suggestions of what the issue might be, or if you need any additional photos of any particular area.
    I have attached a few of the pictures. The rest, and the video (which I was unable to upload here directly), are in the linked album at full resolution.
    Apologies if the link goes against forum policy - I wasn't sure how else to show the video.
  • mikey5791
    • 521
    • Malaysia
    Re: Dell U2518D strobing/flashing with vertical lines
    Could be some component failure from your power board.
    1.Have you checked all your diodes are not shorted, esp those at PD301 to PD304.
    2. Also see what sort of component is hiding under the two heat sink. Check to see if those are shorted.
    3. Use your multimeter to detect any dc output from CN501.
    4. After power on about 10 minutes use your finger test to feel for any heated component. (Be aware not to touch anything on the primary hot side- you might get electric shock!)
    • Stanley1843
      by Stanley1843
      06-29-2024, 11:54 AM
    • HTR-Informatique
      by HTR-Informatique
      02-09-2025, 06:51 AM
    • Falki
      Colorful LCD Vertical Lines on Samsung ue55es8090
      by Falki
      Hello there, ive recently found an older 55inch Samsung SmartTV.
      A similar issue has been posted as well but also with no actual response ...
      08-12-2025, 04:19 AM
    • visionbluedemon
      Help. Sony kd-65x85dj vertical lines
      by visionbluedemon
      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
      tried blocking LC lines too, but same results
      is it lcd panel issue or tcon board issue?...
      07-25-2025, 04:56 AM
    • YellowJacket
      DELL Latitude 5410 - dead; pwrbtn flashing
      by YellowJacket
      Hi folks,
      DELL Latitude 5410, board number FDZ41 LA-J371P Rev: 1.0 (A00), schematic uploaded in different post, here is the link --> https://www.badcaps.net/filedata/fetch?id=3484415
      When I connect it to a power ( DELL round charger, or USB-C ), LED on the power button starts flashing white, and the laptop doesn't do anything ( flashing slows for a very brief time in time when I press it, but it continues again ). Battery is not charging. While the charger is connected, I have few voltages present, but some of them are fluctuating, see attached pictures.
      All I was able...
      04-26-2025, 07:05 AM
