Dell WFP 2007 No image
+ More Options
Posts
  • Jasgriff
    • Feb 2012
    • 578
    Re: Dell WFP 2007 No image
    Retiredcaps is brilliant on the multimeter front. I am sure he can point you in the right direction.
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by noisepc
      I have uploaded more images at the top of this post, from the other side of the cards, please let me know if you need something specific.
      Thanks man!
      We need a picture of your panel board. Follow this cable in red and take a picture of that board. It might be behind a metal shield. As I mentioned, it will a long board at the top of the lcd running the entire length of the monitor.
      On this panel board might be a SMD fuse which might be marked F1. You will need a multimeter to see if it is good or bad. With power off and lcd unplugged, a good fuse should measure less than 1.0 ohms.
      If you don't have a multimeter and don't ever plan to repair any more electronics in the future, then borrow one from a friend. If you want to buy one, I don't know your local market, so you probably want to get something off ebay that provides free shipping? This usually implies buying something from Chinese vendor as they seem to ship worldwide. What is your budget in USA dollars?
      If you have a local electronics store that sells multimeters and they have a website, post the URL and I can take a look.
      --- begin sig file ---
      --- end sig file ---
      • noisepc
        • Apr 2012
        • 26
        • Argentina
        Where is the fuse?
        • Jasgriff
          • Feb 2012
          • 578
          bottom pic 4645 its the orange component om the bottom right of the multi coloured cable
          • selldoor
            Slow Learner
            • 7870
            That is one fuse - Think retiredcaps was meaning one at the other end of the lvds cable ie probably attached to the panel and probably behind a metal frame.
            @ noisepc
            Unfortunately your pictures are too blurry for us to see the details. Did you look at them on screen to see what they look like?
            Having said that in the pic attached I think the white item in the yellow box is a fuse - what I am saying about the quality of the pictures is that if it had been one of the items in the pink box we couldnt see it.
            None of these boards are the one retired caps asked for see above.
            • noisepc
              • Apr 2012
              • 26
              • Argentina
              #26
              So you are saying that It should be more boards near the panel? Should I keep dissembling the case?
              So far I have 4 boards, but as I'm not an expert, I don't how to named them. Please point me to the right one, and I'll take more pictures in detail.
              Thanks!
              • selldoor
                Slow Learner
                • 7870
                #27
                We cant see the board but yes you need to go in further.
                Here is an interesting video - set similar to yours - will help with the part names
                http://www.youtube.com/watch?v=Oh-7-6Yb0Oc
                He doesnt go in far enough but there is a board under the metal plate
                in the following picture taken from the video. This is the other end of the cable
                shown in the red box in retiredcaps picture.
                • noisepc
                  • Apr 2012
                  • 26
                  • Argentina
                  #28
                  This one?
                  Regarding the YT video, that guy told me to contact you guys
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    Hurrah! that's the one but the picture is no good - did you look at it since you posted it?
                    I can barely make out the main chip let alone a fuse that will be a few millimeters across.
                    Take pic in 3 sections overlapping - must be well lit and in focus so it can be enlarged.
                    • noisepc
                      • Apr 2012
                      • 26
                      • Argentina
                      #30
                      Hope this works!
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        Fuse F1 is on that tcon (2nd pic). You need a multimeter to see if it is good or bad.
                        • noisepc
                          • Apr 2012
                          • 26
                          • Argentina
                          #32
                          This one I marked in yellow?
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Yes.
                            • noisepc
                              • Apr 2012
                              • 26
                              • Argentina
                              #34
                              My friend multitester is broken, therefore I'm gonna have to buy one. Any recommendations?
                              I've found this one? Does it do the job?
                              http://articulo.mercadolibre.com.ar/...12-digitos-_JM
                              • Jasgriff
                                • Feb 2012
                                • 578
                                Thats looks ok I cannot work out how much it is though. Retiredcaps is great at finding good multimeters at good prices.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  It will work, but if you can pay a little bit more, this one has some decent reviews at
                                  http://articulo.mercadolibre.com.ar/...baw-ut-33d-_JM
                                  See
                                  http://www.eevblog.com/forum/product...wn-and-review/
                                  • noisepc
                                    • Apr 2012
                                    • 26
                                    • Argentina
                                    #37
                                    Ok, guys, I bought the multimeter but I was only able to get UT33C not D. Now what should I do? If someone has time to guide thru this via chat would be great! my msn address is nicolaslorda@hotmail.com
                                    Thanks in advance!!!
                                    • noisepc
                                      • Apr 2012
                                      • 26
                                      • Argentina
                                      #38
                                      I tested continuity on F1 but there is not continuity. Your thoughts?
                                      • noisepc
                                        • Apr 2012
                                        • 26
                                        • Argentina
                                        #39
                                        I was able to collect some data with the multimeter:
                                        LOGIC BOARD
                                        C128= 22,9
                                        C148= 22,8
                                        C155= 22,8
                                        C57 = 22,8
                                        C35 = 22,8
                                        C19 = 22,8
                                        C81 = 22,8
                                        C89 = 22,8
                                        C98 = 22,8
                                        C96 = 22,8
                                        C144= 22,8
                                        C58 = 17,6
                                        C24 = 17,6
                                        C61 = 17,5
                                        C34 = 17,5
                                        C142 = 19,8
                                        C153 = 03,2
                                        C152 = 03,2
                                        C158 = 03,2
                                        C64 = 03,2
                                        C90 = 03,2
                                        MEMORY BOARD
                                        C851 = 37,2
                                        C858 = 36,6
                                        C838 = 31,6
                                        C801 = 37,2
                                        C848 = 37,2
                                        POWER BOARD
                                        C713 = 06,2
                                        C711 = 06,2
                                        C712 = 06,1
                                        C611 = 25,7
                                        C606 = 23
                                        USB BOARD
                                        C35 = 24,8
                                        C43 = 24,6
                                        C59 = 24,1
                                        C49 = 24,2
                                        C33 = 18,9
                                        C50 = 07,8
                                        C60 = 02,2
                                        C44 = 02,9
                                        C4 = 02,2
                                        C8 = 02,2
                                        C5 = 02,2
                                        C9 = 02,2
                                        And also able to test continuity from F1 Fuse. Please see the picture below
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          1) Never use continuity to test a fuse, always use resistance. A good fuse should measure less than 1.0 ohms. Resistance is always tested with power off and device unplugged from the wall outlet.
                                          2) Put your multimeter on 200 ohms.
                                          3) Put your red probe on one side of F1. Put your black on the other side of F1.
                                          4) If the multimeter is showing "1" on the left hand side on the screen (like it does when the probes aren't touching), that tells you that the fuse is greater than 200 ohms. This means the fuse is blown or bad.
                                          Don't confuse "1" on the left hand side of this display with 1.0 on the right hand side. The first means out of range and the second means 1.0 unit of your measurement.
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • andrhouseolly
                                            Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                            by andrhouseolly
                                            Hi.
                                            I kindly ask you to help me solve the problem.
                                            Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                            The board turns on, there is no image.
                                            Read more. When the power supply is connected, the front panel indicators light up briefly.
                                            When you press the power button, the button indicator lights up. The board works
                                            there is no image, there is no matrix initialization, there is no image on HDMI.
                                            When turned on, the fans do not spin, but when they warm up they start spinning.
                                            When you turn off the button, the fans spin up to full speed for a short...
                                            05-11-2024, 03:14 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • DanPoka
                                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                            by DanPoka
                                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                            02-15-2025, 05:05 AM
