Chimei 221D, very faint screen image.
  • slothzen
    • Apr 2012
    Hi, first post here. Just want to say this looks like a kick-ass community, thanks for existing!
    On to my issue...
    I have a desktop Chimei CMV 221D monitor here that's giving me problems.
    Here are its symptoms: When turning on it blinks grey for a moment before displaying a very very dark and faint image of my desktop. If I try to turn it on and off for some time, ~20 minutes, eventually it'll display a perfectly fine picture, incrimentaly getting brighter until it does.
    Any ideas?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Chimei 221D, very faint screen image.
    Welcome to the forum- Please update the mains voltage in your profile.
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Example
    https://www.badcaps.net/forum/attach...1&d=1290283049
    It will be useful if you can say a bit about yourself - skills tools etc.
    It sounds like it could be failing capacitors- they often work a bit better when they are warm. Once you get it to bits one test you can do is to heat some of the capacitors with hair dryer. However it could be other problems
    - the pictures will help.
    Did you read this https://www.badcaps.net/forum/showthread.php?t=9734 starts off virtually the same as yours.
    • FIXITNOW
      • Jun 2008
      • 128
      replace these caps use only low esr versions
      1 x 22uF - 50V Brown 5mm x 12mm x 2mm
      3 x 220uF - 25V Black 8mm x 12.5mm x 3.5mm
      1 x 330uF - 25V Green 8mm x 14.75mm x 3.5mm
      1 x 1000uF - 10V Green 10mm x 16.5mm x 5mm
      2 x 1000uF - 25V Black 10mm x 21mm x 5mm
      1 x 2200uF - 10V Black 13mm x 20mm x 5mm
      • ss45
        Nintendo switch faint image black screen
        by ss45
        Hi folks
        Like the title says, Initially the device didn't have image, turned it was a backlight connector problem. I shone light into the LCD there was clear image, only dark
        After soldering new BL connector, the backlight works perfectly. Here is the big F up. During plugging lcd connector, I bent some pins unknowingly.
        Put it back together, turned it on, surprised, backlight is on but there is no image now. Well, sort off. I i see carefully there is faint image resembling normal one, but only on right part on the screen albeit really hard to make it out....
        03-05-2022, 09:06 AM
      • dicky96
        HP Elitebook Screen blank - backlights but no image
        by dicky96
        Hi guys
        I'm trying to fix this laptop screen
        Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
        OK so I have the original screen which works but has lines across the bottom quarter of the screen
        I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
        04-28-2021, 07:30 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • speedtime07
        i life zed air cx5 no image on screen
        by speedtime07
        hi everyone ,
        There is an image on the external computer screen ,
        flexi cable test ok - screen test ok -
        What alternative should I look for?
        thank you for your support​
        04-10-2025, 06:24 AM
