LG W2242S with burnt out inverter transformer
  • StevieBoy1912
    • Jun 2014
    • 5
    • Somewhere
    Re: LG W2242S with burnt out inverter transformer
    I was thinking the other transformer because a few weeks before it died it was making a hissing sound then the clicking started and then one day the picture just slowly faded and the monitor just died I will check the power MOSFETS now is there any thing else you would recommend checking and thanks for the help.
    Steve
      Originally posted by StevieBoy1912
      hi I tested the rectifier diodes again to double check they are bouncing around from .1 to .5
      Those numbers do not mean anything to me. Is it in Ohms, Volt, Amp. etc?
      Measured with power still applied to the board? Measured with the components still connected to the board or out off the board?
      • StevieBoy1912
        • Jun 2014
        • 5
        • Somewhere
        rectifier diodes are bouncing around from .1 to .5 Ohms when power is on I have no standby light, and the 450v cap when the board is on dose not hold more than 100v
        • jetadm123
          • 2169
          You should never measure resistance with power on. It can damage your meter.
            +1. I think he needs to learn how to properly use the meter first, otherwise we are doing the goose chase with the wrong data.
              "and the 450v cap when the board is on dose not hold more than 100V" Where did you put your meter probes?
              • StevieBoy1912
                • Jun 2014
                • 5
                • Somewhere
                #27
                Hi sorry for the unreliable data am new to this and I still have a lot to learn as you can tell when I tested the rectifier diodes I had the power supply plugged into the board, so there was power running through the board but I couldn't fully power the board on as it was unresponsive is that still bad to do with the meter or is it just as long as the board isn't fully powered on, I changed the LAF0001 chip and now the monitor seems to be working fine at the moment but it hasn't been on that long so fingers crossed.
                • electomech-fixer
                  First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                  by electomech-fixer
                  I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                  I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                  09-15-2025, 01:42 AM
                • ohren
                  Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                  by ohren
                  Hello!
                  I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                  Measured voltages with no load:
                  After rectifier diodes
                  12V: 6.17 V
                  5V: 5.67 V
                  Secondary transformer pins AC measurement (really don't know if this says anything)
                  12V: 2-2.5 V
                  5V: 1.04 V
                  I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                  03-18-2023, 10:33 AM
                • mikey5791
                  Is it possible for transformer substitution?
                  by mikey5791
                  Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                  Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                  My questions are
                  1. How do i test to see if the transformer is in good working condition?
                  2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                  Hope you guys understand what i was asking. My intention is...
                  11-03-2022, 02:11 AM
                • x_orange90_x
                  Vizio E55-E1 bad backlights or bad inverter?
                  by x_orange90_x
                  I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                  I don't know how exactly to test the inverter itself. Is it...
                  01-29-2025, 09:24 PM
                • lookimback
                  Magnavox 42PFL3603D Burnt up inverter transformer.
                  by lookimback
                  I found this TV last week and when I plugged it in, it momentarily came on, I was able to see the OSD, and then smoke began pouring out of the back. To most people, that would seem bad, but to me that means an easy job troubleshooting. It turned out to be the inverter transformer, and as you can see from the pictures, it's toasted. I looked on eBay and found the power supplies to be about $100. That's way more than I'm willing to spend. I also noticed that tvdoctorsalesandservice, a reputable seller that I've bought several boards from over the years, had a defective board listed for $55. ShopJimmy...
                  07-11-2018, 10:14 PM
