Samsung 940b - classic nod backlight problem
  • bocca
    • Mar 2012
    • 107
    • Serbia
    Hi peole My first post here, although I've been following unregistered for months now
    So, i have two Samsungs 940b with identical problem from the topic title. opened one up and found of course 3 bulged capacitors. Those are the infamous 820uf 25v. I replaced them with 2x1000uf + 1x470uf. Plugged everything back, but tough luck.
    So consulting posts from another topic about 740n ( https://www.badcaps.net/forum/showth...?t=5136&page=6 )
    i looked for the F301 red fuse. Seems like it's ok.
    So now i'm lost basicly
    My motherboard model is: IP-35135B
    Capacitors were capxcon, replaced them with Jamicon.
    Oh and one last thing, before anyone answers. I'm from Serbia, and we don't have a lot of options on buying here. Ebay or any other online store is not an option.
    Current here is 230v, 50/60hz
    So I'm posting pics now
    http://imgur.com/a/sRb0f
    if you need anything else just tell me. it would mean a bunch if i fixed these two bad boys
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung 940b - classic nod backlight problem
    For many reasons, I will NOT look at pictures hosted offsite. Follow my sig file below EXACTLY to upload your pictures here. Do not post pictures inline as well.
    --- begin sig file ---
    --- end sig file ---
    • Jasgriff
      • Feb 2012
      • 578
      When you say there is no back light do you mean it comes on then goes off or there is no back light at all?
      Does the power light come on at all?
      If there is power have your tried the flash light method?
      The pics are good quality you might get a better response if you add them here using the manage attachment button. Could really do with a nice clear one of the bottom of the board not on an angle so we can see what's going on.
      Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
      How to resize your pictures guide click HERE
      Retiredcaps Ideal post example click HERE
      • bocca
        • Mar 2012
        • 107
        • Serbia
        @retiredcaps. I posted photo offsite for two very good reasons:
        1. Not to garbae your database. I administrate 3 forums and it is not desirable to post anything through forum
        2. Max size is 2000x2000. My photos are bigger so there's much more details to see for those with poor eyesight, or just those who want a detailed look.
        If you still want me to post pictures here I will do it, but I'll leave the link for those who don;t mind external links if you don;t mind.
        @Jasgriff:
        1. When they ended their life about two years a go, behavior was, very very brief flash, 1/10 sec and then off. If you look carefully you see the picture but no backlight so it's very dim of course.
        Now, nothing flashes, no backlight at all, and there is a repeating sound. I don't know how to describe it in english, but it's like a clock mechanism being stuck. Repeating "tak tak tak tak" sound, pretty faint. However I can't seem to find it's source
        2. Power button is lit (blue).
        • Jasgriff
          • Feb 2012
          • 578
          If they are hosted on here then they will remain here forever to help other people out in the future. If they are hosted externally then they might vanish.
          Here is an example of some pics hosted on here and they are fine.
          https://www.badcaps.net/forum/showpo...91&postcount=1
          Do you own a Digital multimeter and have you read retiredcaps post below?
          https://www.badcaps.net/forum/showthread.php?t=10419
          Could the clicking noise be like and electric arc noise?
          • bocca
            • Mar 2012
            • 107
            • Serbia
            Jasgriff, did you want some angle photographed different? I did not quite understand that last thingy in your post
            • Jasgriff
              • Feb 2012
              • 578
              A good picture of the bottom of the board. Similar to your first picture.
              • bocca
                • Mar 2012
                • 107
                • Serbia
                Jasgriff, yes I do own a multimeter. It's Mastech MAS830.
                Also i'm pretty good at soldering. yes I read his post a while a go, will read it again tonight
                Well, it could be electric arc noise now that you mention it
                EDIT: Here's the bottom of the board and a detail on the soldered capacitors and resoldered 301 fuse
                • Jasgriff
                  • Feb 2012
                  • 578
                  It could be a number of things.
                  We could do with knowing if it is just the backlight that isn't being powered up. can you see your desktop very faint when it is connected to your computer? if you shine a flash light on the screen this will help to identify if you can see your desktop.
                  • bocca
                    • Mar 2012
                    • 107
                    • Serbia
                    i can't see my desktop. all it says on the screen is " check the signal cable". Tried it on other monitor and computer is showing picture of course.
                    • Jasgriff
                      • Feb 2012
                      • 578
                      Your other monitor might be set to a higher resolution which would give you that message the key thing is you can see it in the background very faintly.
                      See those 3 chips on pic 4. Can you read the labels on them?
                      • bocca
                        • Mar 2012
                        • 107
                        • Serbia
                        Yup. two smaller ones are "4502c AA5VD"
                        and the bigger one is very hard to read but i'll give it a shot
                        B1131 G
                        FF984 7528
                        might not be right thou
                        oh and other monitor is the same resolution as this one, 1280x1024, so it should show the picture
                        • Jasgriff
                          • Feb 2012
                          • 578
                          Before we check those chips can you use your multimeter to confirm the labels and voltages at CN2? the connector with the on/off label.
                          • bocca
                            • Mar 2012
                            • 107
                            • Serbia
                            i'll have to do that tomorrow because my multimeter is at my home, and all this stuff i'm doing at work, so I be replying tomorrow (approx 18 hours from now) when I get back to work.
                            Thanks for the help so far!
                            • Jasgriff
                              • Feb 2012
                              • 578
                              That's fine I am sure that with the help on here you will find out what's going on with them.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Check U202 and U203 (mosfets) for shorts. Instructions on how to check for shorts in my troubleshooting guide.
                                • bocca
                                  • Mar 2012
                                  • 107
                                  • Serbia
                                  @Jasgriff:
                                  I just checked microfuse F301 (right by the bulged capacitors that i changed) and it's resistance is infinite, which i guess means it's blown. Only thing that confuses me is that it looks ok, but i've never seen blown fuse thats not ceramic or glass so someone more experienced will judge.
                                  OK, how do I test the on/off switch? I'm not particulary good with multimetre so i'll need some help there, if you don't mind.
                                  @retiredcaps
                                  OK, mosfet testing results are:
                                  left mosfet
                                  S1 G1 - multimeter briefly flashes ~153.23 and returns to default 1
                                  S1 D1 - nothing happens
                                  S2 G2 - 01.3
                                  S2 D2 - multimeter briefly flashes something between 190 and 64 and returns to 1
                                  right mosfet
                                  S1 G1 - multimeter briefly flashes ~162.33 and returns to default 1
                                  S2 G2 - 01.0
                                  i found the data sheet for this mosfet 4502c
                                  https://cdn.badcaps-static.com/pdfs/...8330ca5905.pdf
                                  and I worked in accordance to it and your troubleshooting guide
                                  • Jasgriff
                                    • Feb 2012
                                    • 578
                                    If that fuse is showing as infinite resistance then its definitely blown. You will need need to read the small writing on the fuse so that you can order a replacement.
                                    You can check to see if the Logic board is telling the Power supply to turn on the back light by setting your DMM to measure DC voltage then negative probe on the GND pin and the positive probe on the ON/OFF pin. Make sure that you don't touch anything else with the probes.
                                    • bocca
                                      • Mar 2012
                                      • 107
                                      • Serbia
                                      well multimeter stays at default 1. Absolutley no movement at all, so i guess that's infinity and it's blown.
                                      i'm going to buy few of these fuses cause the store will close in half an hour, and i'll have to wait till monday to get'em
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        left mosfet
                                        S2 G2 - 01.3
                                        right mosfet
                                        S2 G2 - 01.0
                                        Both mosfets above are bad. Desolder both and retest S2-G2 out of circuit to verify that read around 1.0 ohms. If still shorted, then replacements are available on ebay. 8 for $4.80 + free shipping.
                                        • fanaticgames
                                          Samsung UE32D4010 Backlight problem, led ok
                                          by fanaticgames
                                          hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                          02-22-2023, 09:46 AM
                                          09-07-2024, 05:50 AM
                                        • sandinemail@hotmail.com
                                          Samsung BN44-00284A Backlight problem
                                          by sandinemail@hotmail.com
                                          Samsung BN44-00284A in a Samsung LE40B755 TV bought 2009.
                                          In November 2020 the TV didn“t turn on only flashing red diod on front off TV.
                                          I then opened up the TV and found bulged capacitors on the inverter/powerboard.
                                          I changed all capacitors except the main two 450V 100uf capacitors.
                                          The TV has worked pefectly since.
                                          But this week it started to turn off the backlight. Audio on TV still works.
                                          Sometimes it turn off the backlight after 10 seconds but sometimes it works for hours.
                                          Any suggestions on what might...
                                          02-15-2023, 05:10 AM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
