DELL 2007wfp - 2 Secs to black w/flickering
  • Armandorf
    • Mar 2012
    • 27
    • Argentina
    Hi,i bought this monitor in late 2009, used,its from 2007.
    im a happy owner since then.
    lt has never been too bright, so i used the brightness at 66-100
    doing that result in a whine(high frecuency sound). so i tried to use it at 50, just for precaution.
    for 2 years no problems
    A week ago, after using mi monitor for a couple of hours,i moved it to my desk(it was in a chair) and get out.
    several hours later i power on and the image lasted 1 minute. then no backlight(but stayed gren light on)
    if i unplugged it and waited a bit, it lasts 30-40 secs
    if i try to re power on its 2 secs to black.
    so i decided to take a look,and see if i could do something.
    my first thought: PSU related problem
    so i changed al the electrolytics. except the huge one
    tested diodes, the mosfet(sk3548), resolded critical sectors.
    all seemed okay, no bulging capacitor or cold joints of solder.
    tested and it was the same.. first time lasted 30 secs then it was 2 secs to black.
    when it lasted 30 secs, i saw a flickering every 3 or 4 seconds.
    so i looked further into the inverter, changed all the electrolytics an resoldered transformers.
    no changes.
    i also tried to power on the monitor with 1 or two of the 4 ccfl conectors, nothing
    i have dissasembled the LCD panel now and have access to the tubes.(photos)
    should i recap all the boards?? i have crappy Trec `s capacitors, but they are new
    what should i do?
    Many thanks in advance, sorry for grammar errors(tell me so i can correct them)
    cheers from argentina
    PD,
    1 i have done most of the 2 sects to black excellent tutorial, except th tranformer part.
    2 im sorry if its to large i can resume it and put spoilers.
  • Armandorf
    • Mar 2012
    • 27
    • Argentina
    Re: DELL 2007wfp - 2 Secs to black w/flickering
    tubes photos,
    i have another monitor, LG with a broken panel, so i have a test inveersor and tubes,no?
    its a 19 screen, its compatible to test dell tubes with the LG?.
    here i found a lot of infomation, great forum, keep it up
    • retiredcaps
      • Apr 2010
      • 9271
      The inverter PWM will shutdown all the ccfls if one or more of them are not connected. Either all the ccfls work or none at all.
      Your written English is better than most who are native speakers.
      Measure the resistance between pins 1-8 and 4-5 for all 3 transformers. You should have 6 readings. Post your results. They should be within 3% of each other. I expect readings in the 1023 ohm range.
      PS. Those are excellent photos.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        Yes, you can use these ccfls as "known good" to test with your Dell despite the size difference.
        • Armandorf
          • Mar 2012
          • 27
          • Argentina
          transformers readings, pins numbered as described in attachment.
          with the tranformers mounted in the board.( no need for desoldering?)
          DMM set in the closest scale, in this case 2K ohm
          1rst transf.-
          average resistance 1.062K-
          1%= 10.62 ohms
          1-8 resistance: 1.061 K (deviation -0.16%)
          4-5 resistance: 1.063 K (deviation +0.16%)
          2nd transf
          average 1.0665K
          1%=10.66 ohms
          1-8 resistance: 1.064 K( - 0.21%)
          4-5 resistance: 1.069 K(+ 0.25%)
          3rd transf
          1-8 resistance: 1.040 K
          4-5 resistance: 52.3 K(200K scale)
          with a transformer replacement should work? can i emulate this tranformer to see if i have another problem?
          i will read the components relationed with these pins
          thanks
          • retiredcaps
            • Apr 2010
            • 9271
            3rd transf
            Transformer #3 is bad. It has an open winding.
            See the following for a replacement. They are available on ebay.
            https://www.badcaps.net/forum/showthread.php?t=17945
            http://www.ebay.com/sch/i.html?_from...All-Categories
            It is highly unlikely that another replacement transformer will work. The number of turns is very specific to each board.
            • Armandorf
              • Mar 2012
              • 27
              • Argentina
              thanks for the information,
              what about the tubes, theres a slight blackness in the ends, should they work a couple of years more?
              im desoldering the transformer to see it from the other side, luckili it can be open near the pin.
              im a bit nervous about shopping from ebay to argentina, i will research.
              also tested other components all readings qhere equal with the other pair of transformers. did the same for mosfets on usb board
              in the logic board, i find the caps slightly bulged, its better leave them as it is, or replace all of them?
              i want to make a whole service to the monitor, i love this monitor,thats why i want to leave it as new as possible. here is difficult to find non TN panels monitors
              • retiredcaps
                • Apr 2010
                • 9271
                They look okay, but sometimes the return wire (the thinner guage) can become disconnected/charred/frayed. You can't see it because it is inside of the silicon cap end. Replace the transformer first and retest. I expect it will work fine and the caps and the transformers were the only bad things.
                My experience with China based sellers have been mainly positive. They are quick to correct mistakes.
                Any cap that is slightly bulged is automatically bad. We recommend the standard advice (regulars may skip)
                https://www.badcaps.net/forum/showpo...84&postcount=3
                edit: If you are talking about the green Lelon caps by the connector on the logic board they look completely flat to me in one angled picture. The caps on the logic board don't undergo the same stress as those on the power board.
                Last edited by retiredcaps; 03-15-2012, 04:33 PM. Reason: took another look at the pics
                • Armandorf
                  • Mar 2012
                  • 27
                  • Argentina
                  sorry i abandoned this thread for a long long time, thanks for the help, and i hope that this photos and information to be helpful in the future.
                  i had many issues with my mailing from china ebay, hopefully in 3 weeks will be arriving the little transformer.
                  if anyone needs a photo of some board of the
                  monitor i can post it.
                  • Armandorf
                    • Mar 2012
                    • 27
                    • Argentina
                    yesterday arrived the transformer. it had SMD pins, so i put short wires(ends of used caps or resistences), soldered and mounted the transformer on the inverter.
                    i tested
                    but i still have the same problem; it flashes very quickly and i can see the [ No signal OSD] for a fraction of a second
                    i re checked the 6 ccfl´s with an inverter from a Lg 19'' and they flash once,1 second off, and lit on again, this time with an increasing brightness during the first 3 seconds .finally they still hang on with no noticeable problems.
                      You are saying that this replacement transformer has surface mounted pins instead of the through hole pins. Does it have the same part number as the original and did you take any resistance reading to see if it is the same as the original good transformer?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Did you measure the resistance of the new transformer before installing it? If no, what is the measurement?
                        edit: budm beat me by 2 minutes.
                        • Armandorf
                          • Mar 2012
                          • 27
                          • Argentina
                          yes, the readings were 1.054K and 1.055K, and the readings in this transformer are equal to the other two.
                          looking the power supply, i searched for bad diodes or smd transistor shorted(continuity test)
                          and found something
                          i have 19.2v dc
                          an other 3 pins with 3.3v, 0,8v , 0v(it seems 2,5 mV with the tester in 200mV scale)
                          the last pin has no voltage but it doesnt seem grounded(continuity test with chassis marks open)
                          posted an edited pic of the solder layer for the voltages in the power supply
                          where i cand find a diagram for this power supply?
                          i will be looking for dead voltage regulators in the other boards, i read thats quite common.
                            Your power supply is OK, it is only a single output supply, 19VDC, this 19V is coverted down to lower volltage to run the logic board, the inverter runs off the 19V directly. Your problem is more likely to be in the Inverter board. Does the new transformer 4 middle pins of the transformer all have low Ohm reading?
                            • Armandorf
                              • Mar 2012
                              • 27
                              • Argentina
                              what do you mean with low ohm readings? in which pins I should measure?
                              in the pcb the 2 central pins of each side are joined
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Budm is asking you to measure P1 to P2 and P3 to P4. See diagram below. It is not a 4001R, but the 4001K is "close enough".
                                http://www.lcdparts.net/TransformerD...ProductID=2725
                                  Thanks retiredcaps for clarifying my question. This transformer has two Primary windings and two secondary high voltage windings. Just want to make sure the new transformer has the same windings as the original one.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    PS. It would also help if you posted a picture of your new transformer and jumper leads.
                                    • Armandorf
                                      • Mar 2012
                                      • 27
                                      • Argentina
                                      i measured p1to p2 and p3 to p4. both readings marks open
                                      i read that the 4001 was the important part of the transformer, i have a wrong transformer? i cant find the exact model en ebay
                                        The board that I have here in front of me has two transformers with P/N 4001R702048, the middle transformer has P/N 4001R703038. When you told us the replacement was the surface mounted type, then I kind of suspect that it is not the same transformer as original.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Chivo77
                                          DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                                          by Chivo77
                                          hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                                          1- After receiving power SIO_SLP_S0# goes high and never changes.
                                          2-every...
                                          07-03-2025, 09:20 AM
                                        • Shobos
                                          Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
                                          by Shobos
                                          Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
                                          So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
                                          NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
                                          Any help is welcome. Thanks !
                                          07-29-2025, 03:53 PM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                        • diamon
                                          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                          by diamon
                                          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                          Pictures of these boards:
                                          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                          Dell...
                                          02-28-2024, 12:51 PM
