Hy! I bought a 223BW monitor, used, and borken
When I dissasembled it, I found out that somebody replaced the original capps with some Rubycon non standard value capps. There is no output voltage from the inverter, and the output voltage to the other pcb is 14.5V instead of the nominal 13.5V (with no 5V output on "B-dim" pin on the CN2 connector)
The monitor, when plugged in, turnes the blue power key on, but it can't be turned on, or exactly, there is no display picture.
One other thing I think, that is worth mentioning is a squeaking noise from the transformator.
My question is, can ti be, that the inverter doesnt work because of the wrong capps, or the 5V output?
I'm new in this sort of electronics, and my english is really bad, as you can see, but I will apriciate any help with this psu problem
Shot at 2012-02-23
Shot at 2012-02-23
Shot at 2012-02-23
Shot at 2012-02-23
Shot at 2012-02-23
Shot at 2012-02-23
