Viewsonic VX2245wm
  • MANDACE87
    • Feb 2012
    • 11
    Viewsonic VX2245wm
    replaced ALL capacitors in monitor but now it won't power on at all....any suggestions?
  • jayoung
    • May 2011
    • 172
    Re: Viewsonic VX2245wm
    First things first:
    Pictures of the power supply / inverter board (and logic board while you're at it) - front and back from overhead without the flash, but with plenty of light. Do NOT post the pictures in line, attach them using manage attachments when posting through the 'Go Advanced' button.
    Also, what are the exact symptoms currently of the monitor? Any signs of power - power LED?, flash of the screen - then dark?, etc.
    Do you have a DMM and do you know how to use it?
    • selldoor
      Slow Learner
      • 7870
      @ Mandace - why do you start a new thread each time you come on?
      repost the pics and info from the other thread to this one. Dont start any more for the same monitor.
      Please update your profile with at least the country you live in.
      Also pics after the cap replacement. Where did you get the caps
      and what makes are they?. Check they are in the right way around although they normally pop if incorrect.
      • MANDACE87
        • Feb 2012
        • 11
        I do not have a DMM - should I buy one do you think? If I do need to buy one, will just any digital multimeter do, or do I need to look for a specific kind?
        I will get back with both of you on the rest of the questions after I take the monitor apart again. Won't be immediate, have to do a bunch of studying for school.
        Thanks for the responses
          by momaka
          03-15-2023, 10:17 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • Rick_1234
          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
          by Rick_1234
          Good evening, gentlemen.
          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
          https://drive.google.com/file/d/1L6S...ew?usp=sharing
          Things I tried
          - Bought a new AC adapter thinking that was the problem but the problem...
          06-22-2024, 04:44 PM
          Wise Wing F199 19'' LCD monitor - recapped
          by momaka
          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
          When I saw the Craigslist post, I wasn't...
          08-24-2020, 10:58 AM
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
