Need Help Identifying a blown Part SVA VR17S
  • ZappedAgain
    • Mar 2011
    • 49
    I am working on an SVA VR17s monitor. Upon testing the monitor I found that the screen displayed a white screen with no video regardless of input.
    Monitor uses an external 12v 4a power supply which tests good.
    Upon opening the monitor I found a blown component near the power connector.
    Part is approximately 1/8" by 1/4" with 1 lead on one side and three on the other.
    Part numbers I can read are
    First Row 23 HM
    Second 772
    Not sure what if anything is missing in the part # Center of the chip is burnt.
    Need help identifying a replacement.
    Picture is attached
  • selldoor
    Slow Learner
    • 7870
    Re: Need Help Identifying a blown Part SVA VR17S
    Hi not a clue, however if its the one I think you mean can you remove it
    as underneath I think it has the symbol for a Diode?. That may help. Also the silkscreen may say D6 or D8 next to it?
    Does the board have any part numbers on it? If you or we can find a schematic or a data sheet for the board it may indicate the value of the item.
    I have also seen elsewhere that sometimes the "burn" can be rubbed off with isopropyl alcohol and may reveal more digits.
    • jetadm123
      • 2169
      I think that ZappedAgain is talking about U41. If U41 is connected to the 8-pin chip to the left of it, then looking up the datasheet for the 8-pin chip may yield an applications schematic, which might shed some light on the mystery part.
      • ZappedAgain
        • Mar 2011
        • 49
        I have searched all over the net for a schematic but let just say SVA is not a real popular brand and I haven't been able to find it.
        I do however think I may have identified the part. Did several searches on the internet and this looks like it.
        Next problem is trying to find one. I have searched digikey and ebay and google and can't seem to find one. Where else would you suggest.
        Ken
        • jetadm123
          • 2169
          It appear that Fairchild makes the equiv. KSB772. It's a different case style, but looks to be electrically the same. Mouser has them.
          • selldoor
            Slow Learner
            • 7870
            Just a thought before you replace it
            If that has blown does it mean that the cap at C208 is not working?
            • PlainBill
              • Feb 2009
              • 7034
              Ken
              You don't need the exact part. It is very likely you have identified the part used - a 40V, 3A PNP transistor in a SOT-89 package. There should be a number of them available from various manufacturers.
              Before buying a new transistor, follow jetadm123's advice. What is the IC next to U41? This appears to be a bucking regulator, and it should be possible to get a better ID on the part.
              PlainBill
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                The PCB itself may be used in a lot of different brands.
                You might learn something useful by searching for the PCB part number instead of the screen model number.
                Mann-Made Global Warming.
                - Dr Seuss
                • PlainBill
                  • Feb 2009
                  • 7034
                  After a little research, it appears NPX PBSS5330X,115, available from Digi-Key as their stock number 568-7318-1-ND could be a suitable replacement at $.53 each. The NPX PBSS4032PX,115 and the Zetex ZXTP2008ZTA are also candidates.
                  PlainBill
                  • ZappedAgain
                    • Mar 2011
                    • 49
                    Wow, once again i am amazed at the response I get on this forum. Thank You
                    Jetadm123 - The IC next to U41 is part # SS88066 and is labeled U3
                    Plainbill - Thanks for the research on a replacement. Just ordered from Digikey but looks like I will be placing a second order.
                    PCBONEZ - The main part number on the board is LCD1701 i have searched but all that comes up is an NEC LCD1701 can't find a picture of the inside of one to see if it uses the same card. Ebay also showed nothing.
                    One Note: I was informed by the person I got it from that he plugged in the wrong power adapter and heard a pop.
                    Just to confirm the blown part is U41. I have attached a picture of the entire board to see if someone recognizes it.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Yup, that's a good way to pop a transistor....
                      At least it's not a mystery cause...
                      If you get it fixed it will probably stay fixed..
                      Make sure you check for blown fuses too.
                      Sometimes they don't look like fuses. [Go by board markings]
                      - Dr Seuss
                      • ibo
                        MSI GS75 10SF-227 Stealth identifying Blown part
                        by ibo
                        Hi guys,
                        Hope someone can help me out here. i have this laptop and it wont Boot.
                        now i found this blown part from motherboard but i dont know what it is and what the model nr is to order a new one. i didnt found schematics or boardview for this model. I think PU33 is the same chip....
                        03-02-2023, 02:06 PM
                      • SendyCatKiller
                        KOORUI 24E4 monitor with HKC HKM238Fj01 panel I need help with identifying TCON ic.
                        by SendyCatKiller
                        Hello! I am looking for help with identifying this tcon chip on KOORUI 24E4 monitor.
                        Driver board number: pn238ct01-3-xc-2
                        Other IC on the driver board: NT71265MFG-001
                        Today, 01:01 PM
                      • Radio Fox
                        Acer AL1916 monitor PSU repair (DM0565R blown)
                        by Radio Fox
                        I'm repairing an Acer AL1916 monitor PSU at the moment. The 400v high voltage smoothing capacitor C114 is measuring completely O/C. The case of U101 has blown apart. Fuse F101 has blown. ZD121 reads 6 Ohms in both directions & ZD120 reads 99 Ohms in both directions. While looking at the data sheet of U101 (DM0565R), I noticed that the absolute maximum voltage for Vcc is 20v. However, the zener diode across the Vcc pin to GND is a 1N4748A (22v).
                        Now, whether that zener is used to constantly regulate the voltage, or whether its's used to protect the Vcc voltage from rising too high,...
                        04-13-2024, 06:32 AM
                      • artvandalai
                        Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
                        by artvandalai
                        This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
                        The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
                        11-05-2024, 07:38 AM
                      • wattage
                        AOC AG493UCX 49-inch monitor - Firmware request
                        by wattage
                        Hello Badcaps Community,
                        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                        07-13-2025, 04:41 PM
