Acer AL1916 monitor PSU repair (DM0565R blown)
  • Radio Fox
    • Jan 2010
    • 281
    I'm repairing an Acer AL1916 monitor PSU at the moment. The 400v high voltage smoothing capacitor C114 is measuring completely O/C. The case of U101 has blown apart. Fuse F101 has blown. ZD121 reads 6 Ohms in both directions & ZD120 reads 99 Ohms in both directions. While looking at the data sheet of U101 (DM0565R), I noticed that the absolute maximum voltage for Vcc is 20v. However, the zener diode across the Vcc pin to GND is a 1N4748A (22v).
    Now, whether that zener is used to constantly regulate the voltage, or whether its's used to protect the Vcc voltage from rising too high, I can't understand why 22v was chosen, given that the absolute maximum voltage for that pin is 20v? Wouldn't a 20v or 18v zener have been more appropriate?
    Until the replacement components arrive, I dont know what voltage the auxiliary transformer winding is supplying to the Vcc pin of the DM0565R.​
    https://dalincom.ru/datasheet/FSDM0565R.pdf
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    NO! You'll screw up the OVP using the 18V zener. Read the data sheet! Also the 20Vcc is NOT the maximum. It's more like when the IC goes into OVP. 22V zener is correct. The normal running voltage is more than 12V for the IC to start switching.
    The 22V zener limits the Vcc for OVP condition only. It’s there to protect the IC instead of blowing it up. Under normal conditions, the zener does nothing.
    • Radio Fox
      • Jan 2010
      • 281
      Thanks for reply.
      Yeah, I hadn't read further down the data sheet to read how the OVP works. I can see now that an 18v zener can't be used on that pin.
      However, the data sheet still clearly states that the absolute maximum voltage for Vcc pin is 20v. There's nothing in the table to say that it's the absolute maximum voltage that trips the OVP. That's why it's confusing. That Vcc pin must have a maximum voltage that would break it, so what is it? All we can tell is that it must be greater than 22v, as that's the value of the zener.
      It's obviously correct anyway, as the PSU has been OK for many, many years without problems.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        20v + 10% = 22v
        my data sheet sez 20v but not absolute.
        • Radio Fox
          • Jan 2010
          • 281
          Oh right. The only 2 data sheets for that part that I can find are Fairchild Rev 1.0.5 dated 2005 (that I linked to), or an earlier Rev 1.0.4. Both say absolute.
          Can you upload or link to the datasheet you have for comparison?
          Cheers.
            by momaka
            03-15-2023, 10:17 PM
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
          • keepread
            Dell monitor PSU vs Dell laptop PSU
            by keepread
            Hi there!
            Someone gave me their old monitor, it's Dell S2715ht.
            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
            10-30-2025, 04:45 PM
          • Dvsr
            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
            by Dvsr
            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
            After replacing the caps I started testing out the speaker. It seemed...
            09-10-2025, 10:20 AM
          • wattage
            by wattage
            Hello Badcaps Community,
            07-13-2025, 04:41 PM
