Viewsonic VX2255WMB Grey Screen
  • tieny
    • Feb 2012
    • 478
    Re: Viewsonic VX2255WMB Grey Screen
    If you scroll up youll see the results, they were reported to be working properly.
    • selldoor
      Slow Learner
      • 7870
      It may be me but I dont see them?
      Retiredcaps and I are talking about the connector pins between the power board and the logic board - 4 pins I think CE102?.
      You will need it powered up for this. I also notice that in the pics the boards appear to on the metal frame of the monitor? Do not have it touching like that when powered up and do not put down on metal for at least five minutes after its been powered up (Preferably not at all)
      • tieny
        • Feb 2012
        • 478
        There are actually 8 pins from the power connectors
        pin1: -0.0005V pin2: -0.0005V
        pin3: -0.0005V pin4: 5.12V
        pin5: 5.12V pin6: 5.12V
        pin7: -0.0005 pin8: 3.24V
        For the Transformer the combination of pins 1, 4, 5, 8 gave no readings.
        combinations of pins 2, 3, 6, 7 gave all readings from 0.4, 0.5, and 0.6
        • retiredcaps
          • Apr 2010
          • 9271
          1) The inverter section typically uses 12V or more. Without this voltage the backlight will never come on.
          2) I circled the 2 output diodes. One will be 5V and the other should be 12V or more.
          3) Put your multimeter on DC volts (20V if manual). Plug in the lcd and power it on. Put your black probe on a ground screw. Put your red probe on the middle pin of each red circled diode. Report the readings and see if they are stable or not.
          4) Indicate in the diagram which diode is 5V so we know which is which.
          --- begin sig file ---
          --- end sig file ---
          • retiredcaps
            • Apr 2010
            • 9271
            5) See if these two mosfets (yellow) are shorted or not. My 2 seconds to black guide has the procedures for testing shorted mosfets.
            6) On the back of the pcb, there is a smd fuse marked "P" (just below the 16 multipin IC). See if it is open. It is probably okay, but let's get confirmation. Refer to guide again.
            • tieny
              • Feb 2012
              • 478
              I tested both diodes and got readings of 20.3V and 5.12V
              • tieny
                • Feb 2012
                • 478
                I'm getting the same values for each of the mosfets.
                measuring pins 1 and 2, won't give me a reading no matter how high i raise the range
                measuring pins 1 and 3, gives me 0.823 on the 2K range
                measuring pins 2 and 3 gives me 0.302 on the 2K range
                The P smd fuse had a reading of 0.4 ohms so its still working.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Recheck your readings on those 8 pins. At least one of them should be close to 19 or 20V.
                  • tieny
                    • Feb 2012
                    • 478
                    nope, I rechecked and still have the same values.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      I spy with my little eyes, F101 (SMD "Y") on the backside of the pcb just below those 8 connectors. See if it is open.
                      PS. This is why clear focused photos are so important.
                      • tieny
                        • Feb 2012
                        • 478
                        Doesn't seem to be open, I got a reading of 0.4 ohms
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Okay, for all the components circled in green, measure the DC voltage of each. For caps, put red probe to positive and black probe to negative. Report all the voltages.
                          • tieny
                            • Feb 2012
                            • 478
                            And this should be done while plugged off correct?
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              For voltage readings, the lcd is plugged in and turned on.
                              Resistance measurements are always done with power off and lcd unplugged.
                              If you have to flip the board over to make voltage measurement, use a piece of cardboard as an insulator.
                              • tieny
                                • Feb 2012
                                • 478
                                The ones circled in Red I got voltages of 20.3V and the ones in Blue I got voltages of 5.12V
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  edit: I did find a schematic at
                                  page 59 shows CN801 and the pinouts. It doesn't show the inverter voltages on the CN801 so it must be right then?
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    1) Take a look at this diagram.
                                    http://lcdparts.net/TransformerDetai...ProductID=3359
                                    2) Set your multimeter to 2000 ohm scale if it manual.
                                    3) Measure the resistance (power off, lcd unplugged) between S1 and S2. Do the same for S3 and S4.
                                    4) Regarding the "no readings". A multimeter always gives a reading. If it shows "1" on the left hand side, it is telling you that the value is out of range or infinity for your chosen ohm setting.
                                    5) BTW, this is unlikely to be your problem as PlainBill gave more plausible reasons. I just wanted to make sure you understand how to properly test this transformer.
                                    6) For the tcon panel, you will have to post a picture of it. It is the board that is near the top of your lcd probably underneath a metal shield.
                                    7) The tcon usually has a SMD fuse. It could be open and causing your white/grey screen.
                                    8) Reseat and clean the tcon connection as well.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #38
                                      @retiredcaps. Hi - You've lost me there- what must be right?
                                      Also the schematic shows a different Power board- is that relevant? see pic. On Page 57 it says something about changed values for caps and resistors on Panel Enable circuit which I thought might apply but as I dont really understand schematics thought i'd ask see pic
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        I was thrown off by the negative voltages reported on the connector in post #23. Some of the questions regarding multimeter usage also led me to think that the negative readings were incorrect.
                                        That led to all those voltage measurements on the caps and diodes to verify that the voltage for the inverter section was actually stable and existed.
                                        Reading and understanding schematics is still something I'm learning so I don't know why the changed values. Maybe they found that the original specifications were failing under load?
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #40
                                          Thanks - got it now.
