Another 2 seconds to black issue...
    Hallo! I carefully check all the tips. At first there were bad transistors C5707 I chaged them, but after few hours problem repeated. I changed all capacitors and resolder transformer solder. And changed transistors again, but two of them all the time "blow".
    Fuse is ok.
    Re: Another 2 seconds to black issue...
    Moved as per the OP's and Plainbill's request
    sigpic
    (Insert witty quote here)
      1) Please list the make and model number of your lcd.
      2) Post top down view pictures of your board (top and bottom) following the instructions below exactly.
      --- begin sig file ---
      --- end sig file ---
        Thanks, Ratdude.
        Since you have resoldered the transformers and replaced the electrolytic caps, let's dig deeper. Another common cause of this failure is the timing cap in the Royer oscillator. When you post a picture of the board it will be easy to point it out. Also, there is a diode that has been implicated, that may take longer to identify.
        PlainBill
