Another 2 seconds to black issue...
  • metinjsh
    • Jul 2011
    Hallo! I carefully check all the tips. At first there were bad transistors C5707 I chaged them, but after few hours problem repeated. I changed all capacitors and resolder transformer solder. And changed transistors again, but two of them all the time "blow".
    Fuse is ok.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Another 2 seconds to black issue...
    Moved as per the OP's and Plainbill's request
    sigpic
    (Insert witty quote here)
    • retiredcaps
      • Apr 2010
      • 9271
      1) Please list the make and model number of your lcd.
      2) Post top down view pictures of your board (top and bottom) following the instructions below exactly.
      --- begin sig file ---
      --- end sig file ---
      • PlainBill
        • Feb 2009
        • 7034
        Thanks, Ratdude.
        Since you have resoldered the transformers and replaced the electrolytic caps, let's dig deeper. Another common cause of this failure is the timing cap in the Royer oscillator. When you post a picture of the board it will be easy to point it out. Also, there is a diode that has been implicated, that may take longer to identify.
        PlainBill
        • ChIck3n
          Dell u2311h 20000 seconds to black issue
          by ChIck3n
          So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
          09-09-2024, 11:44 AM
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • wizard13
          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
          by wizard13
          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
          I have checked the forum and the available documentation but could not find a solution specific to my issue.
          • Brand & Model: Dynabook Satellite Pro C50D-B-100
          • Part Number (P/N): PYU13E-00C00PFR
          • Serial Number (S/N): 22028896H
          • System Configuration (SC): A1PYU13E1127
          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
          • Power Input: DC 19V –
          02-28-2025, 02:43 AM
        • Ancient1
          Strange LG TV issue : Image vertical lines in black screen
          by Ancient1
          Hi
          Asking for a friend.
          I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
          but here its the opposite !
          TV has new T-con = same issue
          A missing panel voltage would have global effect
          So , what should one do ? how can I find where the fault is ?
          Thanks !...
          02-05-2025, 03:37 PM
        • sgcampion
          Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
          by sgcampion
          My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
          In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
          10-24-2023, 09:39 AM
