CIBOX C1905 Mod.: LW1922C dead
  • Chyenne
    • May 2011
    • 14
    Hi all, I got hold of a 2006 CIBOX C1905 Model LW1922C to play with. No reaction at all when turning on.
    After opening it I found F801 blown. With my untrained eye I cannot find anything obviously bad except maybe the discoloration underneath T502.
    Caps are from Su`scon and TEAPO and look fine top and bottom. C803 (above F801) is a TEAPO XG-HS.
    There is another thread here that dealt with this model very shortly but unfortunately died.
    https://www.badcaps.net/forum/showth...hlight=LW1922C
    Please disregard the staining around F801.
    It is the result of a little ... mishap, when I was trying something that involved a small smd fuse and a few beers.
    It didn't work.
    Since I only have a multimeter to test components and no idea of what the next step should be, I thought I would ask you wizards, who helped me revive a few LCDs already by just monitoring this board.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: CIBOX C1905 Mod.: LW1922C dead
    Good clear focused pics. It helps a lot.
    I would check the bridge rectifier just underneath the largest cap for shorts. You can test pins 1-2, 1-3, 1-4, 2-3, 2-4, 3-4 "in circuit". Any resistance reading under 30 ohms suggests a short and warrants removing the bridge rectifier to retest "out of circuit".
    --- begin sig file ---
    --- end sig file ---
    • Chyenne
      • May 2011
      • 14
      OK, I removed the bridge rectifier and pins 3-4 (if counting from - to +) read 0.5 ohm.
      Would replacing this and the fuse be the first things to do?
      Is it more likely that the component failed by itself or that it was shorted by another faulty component?
      Would you recommend replacing the caps anyway? (Since they are on your bad capacitor list.)
      Thank you
      • retiredcaps
        • Apr 2010
        • 9271
        That is shorted and will have to be replaced.
        You can also check Q804 (the power mosfet?) for shorts. Test pin 1-2, 1-3, and 2-3 for resistance readings. Again anything under 30 ohms suggests it is shorted. You can test it "in circuit" first (without removing it). If you get a reading under 30 ohms, then remove it and retest.
        I would change the fuse and bridge rectifier first. If it works, then change the caps.
        • Rtech
          • Jul 2010
          • 1095
          If the mosfet is blown, then I would also check all resistors and Diodes around the Mosfet and Transformer, as there is usually a low value resistor in the Mosfet circuitry,and if the Mosfet has gone short cct, then the chance are that resistor is also blown.
          • Chyenne
            • May 2011
            • 14
            Another one fixed.
            The mosfet checked out fine. Replaced the bridge rectifier and fuse and it has been working for a few hours now. Will replace the caps when I'm bored.
            Thank you two for the fast and clear advice. I love this board.
            • double_DD
              How can I be sure that my EC chip is dead?
              by double_DD
              As the title suggests, how can I be sure that my EC chip is really dead?
              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
              03-12-2025, 07:47 AM
            • iMic
              IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
              by iMic
              Hi folks,
              I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
              The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
              11-29-2023, 06:44 AM
            • disorder
              ps5 edm-033 dead after hdmi/usb ports destroyed
              by disorder
              hello guys,
              i need help to repair a edm-033 ps2
              history : as always hdmi port and usb ports destroyed after unplugged
              after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
              so i changed it
              now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
              but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
              i don't see any projection of liquid metal on pcb.
              01-14-2025, 12:48 PM
            • Beton
              Finding a dead short component
              by Beton
              Hi guys!
              I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
              So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
              I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
              I have a bench PSU and if I try to inject voltage the voltage...
              12-10-2021, 01:05 PM
            • zunasthegreat
              Chieftec GPS-450-AA with dead 20N60C3
              by zunasthegreat
              Hello everyone hope all doing well!
              I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
              09-01-2024, 07:12 PM
