Metro LCD with crispy cap.. 2 sec to black issue
  • Solder Boy
    • Nov 2006
    • 178
    Hello all.. this is an offbrand LCD monitor made by Metro. Original symptom is 2sec to black issue. You can see the WIndows XP screen no problem before it goes away.
    Opened it up and I could smell something burnt.. this is a first for me! One of the little blue capacitors had burnt to a crisp. It's neighbour is a 12J 3KV capacitor.
    Looking for input here.. what would cause this cap to go poof? Bad transformer or bad CCFL? I probably have a replacement somewhere in my pile of boards.
    Thanks!
    www.bcrelectronics.ca
  • PlainBill
    • Feb 2009
    • 7034
    Re: Metro LCD with crispy cap.. 2 sec to black issue
    The caps in this position have been known to fail. The first step would be to replace it and let the monitor run for a few hours before buttoning it up and giving it an extended run.
    PlainBill
    • Solder Boy
      • Nov 2006
      • 178
      Thanks Bill.. I have plenty of 3KV caps from other boards... will solder in another one and see what happens as you say.
      I will report back when I've had a chance to do it.. too many other things on the go this week.
      • PlainBill
        • Feb 2009
        • 7034
        Make sure you match the capacitance (12pF).
        PlainBill
        • Solder Boy
          • Nov 2006
          • 178
          Hi Bill.. well I got the 2 second to black issue solved.. I found an identical blue cap on another board. However I think the effort turned out to be a partial waste.
          Fired it up and got these two white lines on the screen with a bit of black in the lower corner.
          Took it apart again.. found 2 caps on the video board that were really bad so I replaced them.. fired it up same result.
          Bad screen now?
          • PlainBill
            • Feb 2009
            • 7034
            Bad screen now?
            Yes. That is a bad panel.
            PlainBill
            • Solder Boy
              • Nov 2006
              • 178
              Well I kinda figured the screen was toast.. just wanted confirmation.
              Working on this thing wasn't a total waste.. learned something new working on this thing!
              • jetadm123
                • 2169
                You can always part the monitor out and sell the power supply and video board to help compensate for your time spent doing the repair.
                • Solder Boy
                  • Nov 2006
                  • 178
                  Normally I would agree with you however this is really an oddball of a LCD monitor.. it's a Metro and the PS board inside is pretty well propietary to this thing.. it's got oddball CCFL connectors.
                  I will likely gut it and put the working parts in static bags and keep them in stock for future reference.
                  • alexanna
                    • Mar 2010
                    • 1346
                    I just ran into one of these where one of the Blue caps next to the inverter transformer was burnt.
                    After replacing the cap the monitor worked, but after I powered the monitor down the inverter transformer where the failed cap was noticeably hotter than the other transformer.
                    It turned out to have the Hot wire at the CCFL barely making connection.
                    To check your work after your done either use a Temp. gun or your feeling of touch to see if the transformers are about the same temptaure. Oddly the blue cap was staying cool.
                    IF YOU USE THE TOUCH METHOD PLEASE UNPLUG THE POWER FROM THE MONITOR.
                    So to avoid a repeated failure, IF one transformer is noticeably warmer I would suspect wiring to the CCFL.
                    • Solder Boy
                      • Nov 2006
                      • 178
                      Thanks for the additional info will file that away for future reference. If someone hadn't have smacked the screen and damaged it I would have done more investigation.
                      • wizard13
                        Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                        by wizard13
                        I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                        I have checked the forum and the available documentation but could not find a solution specific to my issue.
                        • Brand & Model: Dynabook Satellite Pro C50D-B-100
                        • Part Number (P/N): PYU13E-00C00PFR
                        • Serial Number (S/N): 22028896H
                        • System Configuration (SC): A1PYU13E1127
                        • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                        • Power Input: DC 19V –
                        02-28-2025, 02:43 AM
                      • Ancient1
                        Strange LG TV issue : Image vertical lines in black screen
                        by Ancient1
                        Hi
                        Asking for a friend.
                        I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                        but here its the opposite !
                        TV has new T-con = same issue
                        A missing panel voltage would have global effect
                        So , what should one do ? how can I find where the fault is ?
                        Thanks !...
                        02-05-2025, 03:37 PM
                      • ChIck3n
                        Dell u2311h 20000 seconds to black issue
                        by ChIck3n
                        So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                        09-09-2024, 11:44 AM
                      • Stephen
                        MacBook Pro 13" 2017 A1708 Black screen issue (not flexgate)
                        by Stephen
                        This is not a flexgate issue.
                        The lcd turns on and functions fully and fine. When installing or even attempting to install an OS the screen goes black and doesn't turn on. We swapped the LCD with a testing LCD (that works) and it too is also black. After the computer cools down it turns back on and show the screen again and then it goes black when it gets hot. Sounds like a CPU issue to me (since these do not have their own dedicated GPU) but I may be wrong. Has anyone experienced this with this model? Battery is good btw. also I disconnected the battery and it still does the...
                        06-10-2021, 09:09 AM
                      • sgcampion
                        Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
                        by sgcampion
                        My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
                        In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
                        10-24-2023, 09:39 AM
