Dell 2407WFPB
  • gobbler
    • Jun 2009
    • 55
    Dell 2407WFPB
    Hi
    My Dell has this problem, it keeps rebooting repeating the same pattern.
    I can see a blue line but it is not able to display the word DELL and then reboot again. It keeps repeating.
    Can anyone tell to to troubleshoot the power supply board or the inverter board? Thanks.
  • smason
    • 1652
    Re: Dell 2407WFPB
    What does the power light do while this is happening?
    Sounds like a power supply issue so far....
    • gobbler
      • Jun 2009
      • 55
      Re: Dell 2407WFPB
      The power light still in green and it also power off and on again in repeat cycle.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • siuras676
        Dell XPS Plus 9320 blue screen and rebooting
        by siuras676
        I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
        First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
        However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
        Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
        04-07-2025, 12:10 PM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
