I had the green LED flashing when on. Found the 5v line shorted to 1.4 ohms. When I unhook the ribbon cable, I have 5v on it. 1.4 ohms to ground on the display board. I lift the component B5 and I get my 5 volts on the board. have no idea what B5 is. I'm in the process of searching the web for the board M190EG01 V0. Anybody know what B5 is?
HP LP1965 shorted 5v on display board
Re: HP LP1965 shorted 5v on display board
Some clear focused pictures of the board will help.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company. -
Judging by the color it appears to be an inductor. It's puzzling though - there's no reason to put an inductor across a DC voltage rail, there's likely something downstream of it that is shorted, the inductor simply passes thru power to that area. I see a fuse there labeled F5. Is that fuse good? Also check the two voltage regulators.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Yeah, the fuse is good. An inductor would be labeled with L and not B wouldn't you think. I measured across B5 and get a short. It appears that there is something on down the line loading the 5 volts. The regulators seem to be OK showing only the one leg tied to the 5 volt line at 1.5 ohms to ground. I hate surface mount stuff with no ID as to what value they are let along what they are. And it's a bitch lifting them out of the circuit.Comment
"B" can mean bead, as in ferrite bead. The colour also matches the common grey seen on a SMD ferrite bead. The ferrite bead essentially attenuates high frequency noise, and cannot short out anything, because it is always in series with a load. I would check to see if the short appears on both sides of B5.Yeah, the fuse is good. An inductor would be labeled with L and not B wouldn't you think. I measured across B5 and get a short. It appears that there is something on down the line loading the 5 volts. The regulators seem to be OK showing only the one leg tied to the 5 volt line at 1.5 ohms to ground. I hate surface mount stuff with no ID as to what value they are let along what they are. And it's a bitch lifting them out of the circuit.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Many semiconductors don't fail dead short, but do fail "shorted". 1.5 ohms is typical. I've seen a power MOSFET fail at 20 ohms. Doesn't sound like much (only 250mA @ 5V), but on the primary side of a power supply with a 330V bus, that makes a sizeable explosion (Not pretty!!)
1.5 ohms sounds abnormal. It's possible there's a load drawing a lot of current, but I wouldn't expect that at the low voltage used by a multimeter (about 0.3V.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
If memory serves me correctly, there have been some cases of a shorted SMD cap on the panel board.
Have you checked any of these?
You still may have to lift it off the board if there is a resistor parallel in the circuit.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!
Yeah, I have had some SMD's short on me in the past. I've had schematics in those cases and was easy to trace stuff out. I'll play around with it for another day lifting a few things but if I don't find something soon, to the recycle bin it goes so I can cut my costs. If I find a shorted cap, I'm not going to know what value it was anyway. Don't really need to waste too much time on a $200 LCD monitor.Comment
Well I would hope if you decide to recycle the monitor you save some of the partsYeah, I have had some SMD's short on me in the past. I've had schematics in those cases and was easy to trace stuff out. I'll play around with it for another day lifting a few things but if I don't find something soon, to the recycle bin it goes so I can cut my costs. If I find a shorted cap, I'm not going to know what value it was anyway. Don't really need to waste too much time on a $200 LCD monitor.
CCFLs come in handy for testing, A lot of the mains fuses are of the same spec, Power MOSFETS and Dual diodes are nice to have around.You just never know what you may need.
If you plan to repair another monitor in the future some of these things come in handyWhatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!
There are a several techniques you can use to identify the short. The first MIGHT not work. Work your way along the 5V rail, checking the resistance. You MIGHT be able to see the resistance decrease as you approach the short. The limitation is the accuracy of your DMM at low ranges - typically that aren't very good.Yeah, I have had some SMD's short on me in the past. I've had schematics in those cases and was easy to trace stuff out. I'll play around with it for another day lifting a few things but if I don't find something soon, to the recycle bin it goes so I can cut my costs. If I find a shorted cap, I'm not going to know what value it was anyway. Don't really need to waste too much time on a $200 LCD monitor.
The second is simpler. Set you DMM to the lowest voltage range possible, hold the red probe at the +5V input, and work your way down the 5V rail with the black probe, looking for increasing voltage drops. At the point where the voltage no longer increases, you have located the shorted component.
The third requires extra equipment. Hook a high current 5V supply to the 5V rail. CAREFULLY probe for a hot spot. A 1.5 ohm load on a 5V supply will pass 3A, for a total dissipation of 15 watts!! If it is a shorted SMD cap, you won't have to look to hard, it'll desolder itself!
The high current supply doesn't have to be too expensive - 3 D cells in series will do it. Just observe polarity.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by modtoolHi to all,
the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by ledbylightHi all!
This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more
, and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
11-04-2024, 06:36 PM - Loading...
