245BW, can't find problem. No 24 or 6.3V, standby is good.
+ More Options
Posts
  • Toasty
    • Jul 2007
    • 4171
    #81
    Re: 245BW, can't find problem. No 24 or 6.3V, standby is good.
    Originally posted by Yaaman
    Good shot. I didn't find it because it is not in caps category. Thanks.
    Hopefully I won't need it and the new RT852 will sort it out.
    No. The problem is likely in the Zener's and possibly QT851. Lift that 24v jumper and see if 24v comes back.
    <<Oh yes RT852 shows 168R>> ??
    What does that mean? Its marking or the value you read with a meter?
    Closest value I've at home is 1.4R 5W. Do you think it would be ok just for tests?
    Tough to say. Don't know what its original value was.
    Originally posted by selldoor
    @Toasty If he needed to replace the Long Blue cap could he use one of these?
    http://www.ebay.co.uk/itm/PANASONIC-...=e100084.m1843
    Yes, that should be fine.
    T
    veritas odium parit
    • Yaaman
      • Jan 2014
      • 30
      • United Kingdom
      #82
      I powered it uup with this large resistor I had. Unfortunately nothing changed.
      I checked voltage on this large blue cap. Should it fluctuate from 300V to 330V-ish? Up and down all the time.
      Same unstable voltage on QM802 as per pic attached.
      • Yaaman
        • Jan 2014
        • 30
        • United Kingdom
        #83
        T
        Sorry I mean read value is 168R
        Oryginal value of RM801 is 0.22R 1W.
        • Yaaman
          • Jan 2014
          • 30
          • United Kingdom
          #84
          I lifted the jumper. Still cant see 24V.
          • Yaaman
            • Jan 2014
            • 30
            • United Kingdom
            #85
            I will order and replace all four BZX84C22 and two LMBD2838LT1G.
            • Yaaman
              • Jan 2014
              • 30
              • United Kingdom
              #86
              That was stupid what I've just done. I replaced blue cap with 100nF mkp and power resistor with 1.5R 5W one and powerd up. Resistor blow up loudly and two QM802 and QM802 are dead.
              I go to sleep...
              • Toasty
                • Jul 2007
                • 4171
                #87
                Hmmmm.....
                Could you have a bad mains cap?
                T
                veritas odium parit
                • Yaaman
                  • Jan 2014
                  • 30
                  • United Kingdom
                  #88
                  I checked CX801S, CX802S and CP802S (circled). I only have multimeter with capacitance test. I read CX801S - 312nf, CX802S - 315nF and CP802S - 480nF. That look fine to me.
                  • Yaaman
                    • Jan 2014
                    • 30
                    • United Kingdom
                    #89
                    I'm doing a shopping list. What else possibly could blown? I'm ordering some parts from Farnell so I can get everything in one go. I'll get the zeners, 100ohm smd resistor (RT852), mains caps, 22nF cap, 0.22ohm resistor. What else?
                    • Toasty
                      • Jul 2007
                      • 4171
                      #90
                      With no load and it blew, I'd be looking carefully at prior work.
                      In the future, use the "lamp-in-series" trick to prevent these types of surprises:
                      https://www.badcaps.net/forum/showpo...2&postcount=23
                      Make sure to use a real incandescent lamp, not any other type (no CFL or LED).
                      Don't need those white caps. I re-read your list, and now with the pics, I saw you already replaced the mains cap with a KXG.
                      Assume you have the missing heatsink. ( Why is it off? )
                      What zener values did you choose? DZT852 and...? (just to be sure)
                      How did you determine?
                      Order more than 1 of the 100Ω. Usually a strip of 5 or 10 is minimum...?
                      Same with the 0.22Ω a couple-three won't hurt.
                      Check QT851. ( 1P type )
                      Both FETs, correct? Did you do ~exact~ replacements in the first go or subs?
                      Double check RB801S, the other power resistor.
                      T
                      veritas odium parit
                      • Yaaman
                        • Jan 2014
                        • 30
                        • United Kingdom
                        #91
                        Yes I read about lamp trick, I'll try it. The heatsink is missing because 24V jumper I lifted was underneath.
                        I am away from my pc so I don't know the zener values but I've got schematic and I go by it.
                        Every part I order now is always more than I need so I have a spare.
                        First FETs I ordered were exacly the same but now I'm thinking to get replacement as per Fairchild Semicon the original are not being made.
                        • Yaaman
                          • Jan 2014
                          • 30
                          • United Kingdom
                          #92
                          Hello
                          I finally received all replacement parts. I also used the lamp in series trick. Looks like it saved me a lots of trouble.
                          When I switch power on bulb comes on then after 2-3 seconds starts pulsing at almost full brightness. When I touch on/off button led comes down as well as the bulb. Stand-by is working, that for sure
                          I've no idea what's wrong. Could it be MC33067 (ICM801)?
                            Did you check that red rectangular cap next the 24V transformer? I believe it is 18nF 630V it is one of the commonly fail cap, verify that it is still 0.18uF.
                            • Yaaman
                              • Jan 2014
                              • 30
                              • United Kingdom
                              #94
                              Yes. It's brand new and it's 22nF 630V.
                              • Yaaman
                                • Jan 2014
                                • 30
                                • United Kingdom
                                #95
                                Ok that's weird one. When I let it cool down for a few minutes, after first power up the bulb comes on, then power off and on and the bulb only flash once and stays off and I have the 24V!
                                Unfortunately only until next power off/on. Then the bulb comes and stays on until I let the system cool down again.
                                • Yaaman
                                  • Jan 2014
                                  • 30
                                  • United Kingdom
                                  #96
                                  Then the bulb comes on and pulsing the 24V slowly coming down, 1V every 2s.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #97
                                    Whilst you are saying what you are seeing I am not so it would help if you could
                                    differentiate between bulbs? May be just me
                                    That is please say "Dim Light test Bulb" "Power led" or "ccfl" as against "bulb"
                                    • Yaaman
                                      • Jan 2014
                                      • 30
                                      • United Kingdom
                                      #98
                                      I had 24V jumper lifted. When I soldered it back on the 24V gone. Now I need to switch off/on many times more to get the bulb come off, and event then I have no 24V.
                                      • Yaaman
                                        • Jan 2014
                                        • 30
                                        • United Kingdom
                                        #99
                                        When I say the bulb i refer to "in series bulb trick" bulb. Inverter is not even connected so I didn't mean ccfl. LED is the led on the front panel.
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #100
                                          Have you tried with the ccfls connected - with them not connected may shut down as
                                          being faulty?
                                          • temyth
                                            Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
                                            by temyth
                                            Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
                                            The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
                                            01-07-2024, 04:50 PM
                                          • gugutm
                                            a1989 820-00850 stuck at 5v 0.041a Help
                                            by gugutm
                                            I'm new to the forum,sorry english is not my first language too, i got a basic plus knowledge, but now i am in this situation where i need some help , i spend good few days reading forums , here and outside , to help my problem solve, with no luck
                                            long story short, i bought macbook pro a1989 820-00850, clean no water damage which was stuck on 5v 0.200/300a i read a lot of forums what that could be , it indicated to faulty corrupted t2 rom
                                            of course before jumping to conclusion and connected to DFU , i believe i done basic checks...
                                            01-04-2025, 09:35 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • dicky96
                                            Air Con PCB repair : some general question
                                            by dicky96
                                            Hi guys
                                            I've been getting more air con controller boards of various brands for repair - mainly the ones from the outdoor compressor unit and I realise I have a lot of gaps in my specific knowledge, while being pretty good at electronic repair in general.
                                            Does anyone know of any good resources for information on this sort of repair? I'm hoping here there will be some guys who are experienced in this. I'd specifically like more info on how the controller PCB works, because I expect they are all pretty much the same, and especially how it communicates with the indoor unit (protocols,...
                                            11-22-2024, 04:40 AM
