Samsung Syncmaster 931BW - No Power
  • Glennjamin
    • Oct 2010
    • 16
    Re: Samsung Syncmaster 931BW - No Power
    The full part number is FSDM0465RB. Many times it is abbreviated to the numbers on the IC, DM0465R. There are several auctions in Great Britain. This auction also looks good, you get two, but shipping could take a while; I'm not sure about import duties. There are also several higher current variations, I don't think it is worthwhile to upgrade.
    PlainBill
    Hello again!
    I return having received my FPS and successfully replaced it on my powerboard. In doing so I rebuilt the monitor and turned it on...nothing again, no LED light around the power button.
    I took it apart once again and did the test you recommended before on the output connector - originally showing no values. I now get values of about 13-14V on the 15V connector and about 5V on the 5.1V connector. So the powerboard seems to be back to life but the monitor isn't. Any ideas?
    • jetadm123
      • 2169
      Originally posted by Glennjamin
      Hello again!
      Good job on getting the power back up and running. Since you're not even getting the power light, it would seem that you will now need to concentrate on the logic board. This is the board at the other end of the wiring harness from the power board. Please post some good photos of the entire logic board.
      • Glennjamin
        • Oct 2010
        • 16
        Thanks, it feels like some progress at least! I will do so in the morning when I have good natural light, I did already post one image which isn't too clear back on post #14 - https://www.badcaps.net/forum/showpo...9&postcount=14
        Probably not too much you can gain from that but it does seem a fairly unexciting logic board.
        • Glennjamin
          • Oct 2010
          • 16
          Logic board pictures -
          1. Full front
          2. Full back
          3 & 4. Close halves of front
          5 & 6. Close halves of back
          • jetadm123
            • 2169
            At this point, I would suggest measuring the output of the voltage regulators circled in yellow. Measure and report voltage at each leg and metal tab (at the top of each regulator). Also, please include the part number off of each regulator.
            • Glennjamin
              • Oct 2010
              • 16
              #26
              How would do that with my DMM, I'm still quite the novice 25 posts later this thread sorry! On 20VDC and the black & red probe on which points exactly? Thanks.
              • jetadm123
                • 2169
                #27
                20VDC setting is good. Neg (black) probe on one of the screws holding down the logic board. Pos (red) probe on each leg and tab as requested.
                • Glennjamin
                  • Oct 2010
                  • 16
                  #28
                  Thanks for clarifying, I've attached a picture illustrating the values of the two regulators and their part numbers above each.
                  • jetadm123
                    • 2169
                    #29
                    The outputs look good for both regulators. The input voltage for the right side regulator seems a bit odd at 3.8V. Not sure if there's a short somewhere dragging down that voltage. Try measuring the input voltage of the right side regulator again. This time place the neg probe on the left leg and the red probe on the right leg.
                    • Glennjamin
                      • Oct 2010
                      • 16
                      #30
                      OK doing that is still giving me a very consistent 3.8V with absolutely no fluctuation. Do you know what the output voltage should be for the connector to the front power button? I'm not sure if that is important in this case though.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        The connector appears to have 4 pins. If that is the case, one should be 0 volts, another either 3.3 or 5V, and the voltage on one will vary, depending on which button is pressed. The last will control the front LED.
                        PlainBill
                        • Glennjamin
                          • Oct 2010
                          • 16
                          #32
                          Hi again, I've been away for a week and unable to test. Update.
                          PlainBill
                          The output connector on the logic board does indeed have 4 pins and they test the following values:
                          Pin 1: 0 V
                          Pin 2: 1.8 V
                          Pin 3: 1.8 V
                          Pin 4: 2.1 V
                          I also own a Samsung 226BW which I pulled apart and borrowed the switch and connecting cable (which are the same). No surprises, no change...so the switch and cable are fine.
                          The two 1.8 readings shouldn't be that low should they?
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Pin 1: 0 V
                            Pin 2: 1.8 V
                            Pin 3: 1.8 V
                            Pin 4: 2.1 V
                            Unusual, but not unknown. There are three general designs for wiring the switches on a control panel.
                            One is very simple - each button is connected by a wire to an input of the processor. Pushing a button pulls that line low. For 5 buttons that requires 6 wires plus whatever is required for the LED.
                            The next is a little more complex. The switches will be wired in a grid, each button will connect a drive line to a sense line. For 5 buttons that requires 5 wires, plus whatever is required for the LED.
                            The latest version uses two wires, a sense line tied to a voltage source, and a ground line. One side of each button is tied to ground, the other is tied to the sense line through a unique value resistor. By measuring the voltage on the sense line, it is possible to determine which button (or even a combination of buttons) has been pressed.
                            PlainBill
                            • renard-ad
                              • Jul 2011
                              • 9
                              #34
                              Dear all,
                              I did a complete recap (except main 450V cap) and the symptoms remains the same.
                              As before, the backlight functions one second and then shuts down. It never switch on again (unless I push on / off button). So there is no retry after a timer.
                              Have you got any idea of what it could be ?
                              Thanks,
                              renArD
                              PS : Let me just correct something I said : there are no 30V bursts on the 15V line, it is my voltmeter failure (curious).
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Originally posted by renard-ad
                                Dear all,
                                Thanks,
                                renArD
                                I've marked up the picture you supplied of the power supply bottom. Note there are two pins circled in orange, and two circled in yellow.
                                Set your DMM on the 2000 (2K) Ohms range. Measure the resistance between the pins circle in orange. Report that. Measure the resistance between the two points circled in yellow. Report that. If the two numbers match to within 3%, the transformer is probably good.
                                PlainBill
                                • Panther
                                  • Jan 2010
                                  • 11
                                  #36
                                  I don't know if this will be of any help, but I recently repaired a Samsung 940N with the same board (from memory) as that shown by renard-ad.
                                  In my case the fault was caused by the inverter transformer. It's resistance between the two outputs was quite different. It was causing one CCFL to be very dim for the second or two before it shut down.
                                  I bought a replacement transformer on eBay from this shop.
                                  http://cgi.ebay.com.au/ws/eBayISAPI....m=350472418043
                                  Good luck.
                                  • renard-ad
                                    • Jul 2011
                                    • 9
                                    #37
                                    Thanks to both of you for your quick replies. It makes me eager to try / measure ! (unfortunately I work in a city I don't come from. I'll check as soon as possible : next week end).
                                    The link to ebay doesn't work due to country legal restrictions. I guess you meant this : http://cgi.ebay.fr/TMS92515CT-Invert...item2309d5fbeb
                                    As I was doing some research about this transformer, I saw it is quite "famous", so it may confirm it is the faulty part. Maybe the zzzz noise comes from it too. I can't wait next week-end
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Good luck.
                                      One of the fallacies beginners fall into is 'This fixed John's monitor, so it will fix mine, even though the problem is different.' A second is 'This fixed Joe's monitor and the symptoms are the same, so it will fix mine.' Neither are true.
                                      Looking at troubleshooting reports, failure of a transformer is the third most likely cause of 'two seconds to black'. It is also the easiest to test. Blindly replacing a transformer is foolish. Ignoring the possibility that a transformer is the cause is equally foolish.
                                      PlainBill
                                      • Panther
                                        • Jan 2010
                                        • 11
                                        #39
                                        PlainBill
                                        As I stated quite clearly (or so I thought), a faulty transformer was found to be the cause in my case. Never did I say it's going to be the cause of the problem with other monitors.
                                        Futhermore, I also stated the resistance readings from each secondary were quite different therefore indicating a transformer fault, so I didn't replace it blindly nor did I suggest that anyone should do so.
                                        I was just pointing out that a faulty transformer is a legitimate cause of these symptoms with this model of monitor and therefore worth checking. Then if found to be suspect a replacement is easy to obtain on eBay.
                                        • renard-ad
                                          • Jul 2011
                                          • 9
                                          #40
                                          Hello, I'm back with the measures
                                          According to the circles made by Plainbill, I name from "a" at the top left, to "d" at the top right pin. I'm sorry, I can't tell colours apart (I'm partly colour blind). I guess yellows on the left (Rab), and orange on the right (Rcd).
                                          Rab = 3.197k Ohm
                                          Rbc = 221,2k Ohm (parallel to the also noted "R31" on the board)
                                          Rcd = 1.136k Ohm
                                          I could also unsold the transformer if needed.
                                          Obviously, values don't match in the 3% range. So I guess the transformer is bad. I let your wise confirm it !
                                          If you could also explain me why the resistance can change (I would say it is either good or open circuit), I'm also interested in that
                                          Thanks,
                                          renArD
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • repair-it
                                            Need advice testing a samsung power supply board with scope
                                            by repair-it
                                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                            07-12-2025, 11:00 AM
                                          • hill01
                                            Samsung UE75MU7009TXZG Endless Power Cycle
                                            by hill01
                                            Hi everyone and thanks in advance for any help I might get here
                                            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                            Since a few days, the TV won't turn...
                                            11-17-2021, 02:52 PM
