Samsung Syncmaster 931BW - No Power
Re: Samsung Syncmaster 931BW - No Power
If it's a cap it would have to be on the logic board.From what i can tell the power supply is working correctly.
I don't know if this the correct name for it but,I would suspect a problem with the the user eprom on the logic board.
Someone else will have to answer if it is serviceable or not.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
2 more thing I tried.
1. I went to the troubleshooting no video step (analogical one) and skipped the tests required an oscilloscope to the step checking the voltage on CN400 (the connector that goes from the logic board to the LCD), and there was no 5V on pin 1,2 and 3. Following that I tested the PANEL_EN and BL_EN signal (they should High and Low for ON), and both of them were Low (the PANEL_EN one was 0.6V).
I also tried testing the digital troubleshooting part, since it revers to the same 1,2,3 pins for 5V, but couldn't find the resistances they claim.
2. The computer seems to recognize the monitor though. I don't have a second monitor to test, but I unplugged the signal cable while the monitor was plugged in, and I got that windows sound of disconnected device. When I plugged the signal cable back in the reconnected device sound played.
Any suggestions where I can go from here?Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by repair-itI am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.Yesterday, 11:00 AM
by hill01Samsung UE75MU7009TXZG Endless Power Cycle
Hi everyone and thanks in advance for any help I might get here
My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
Since a few days, the TV won't turn... - Loading...
