BenQ FP71G+ inverter problem (possibly).
  • diretouch
    • May 2016
    • 4
    • Bulgaria
    Re: BenQ FP71G+ inverter problem (possibly).
    Hi there. I am new here. I want to view the values of the electrolytic capacitors of FP71G Main board >
    48.L8302.A30
    Thanks in advance
    • valvashon
      Insignia NS-LCD19-09 (PS OK, Inverter problem?)
      by valvashon
      For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
      History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
      01-04-2024, 01:44 PM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
    • stomanata
      Problem with power inverter emc18aecn1 of washing machine AEG L6FBA674
      by stomanata
      on my previous post with help from this forum i found short circuit GIF5CH60TS-X
      I replace it but again give me error for current over 16A.
      I measure again and found short circuit between #15 and #16 (Cin and GND).
      On PCB i remove R121 to check in which direction is short circuit. But this pin goed
      to big copper piece on back side.
      So i try to measure over every resistor and capacitor
      But i can`t find any short circuit,
      On example circuit of GIF5CH60TS-X is labaled that Cin can goes to GND in some cases:
      1. Through CSF (i don`t know...
      09-15-2024, 02:06 AM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
