Viewsonic VA1918wm Problem
    My default setting for the brightness is 100 before. Now it just black out the power led is turned blue, but when i lowered the brightness to around 80% it the display shows and does not go black. If I set the brightness again to 100% I can hear a click sound and then black out. What seem to be a the problem? Thanks in advance for any reply.
    Re: Viewsonic VA1918wm Problem
    The standard procedure here is to post clear focused pictures of all your boards using the manage attachments functions so the pictures are attached to this forum. Please do not post inline because it slows down the loading of pages.
    After you have posted the pictures using manage attachments, we can suggest test points or see if the caps are known bad series.
    --- begin sig file ---
    --- end sig file ---
      sorry for that finally have the guts to disassemble the unit here is the power board
        You have one obviously bulging capacitor right next to that heatsink in the middle. What does it say on it?
        Also please update your profile with your location so we can suggest a parts distributor in your area.
        A working TV? How boring!
          My guess from the pics is a Samxon GF which is a problematic series.
            Mine too... but let's wait for confirmation.
              Sorry for the late reply, it says 1000μF25V GK(M) SAMXON. Any suggestion for replacement
                This.
                  thank you very much, hope i can find this in Saudi Arabia
                    Finally my unit is alive again . Thank you for all your help. Even though i don't have background in electronics, i manage to fix my Monitor.
                      hi, darkbyte23.... kindly can you guide my how did you dismantle your monitor. thanks
                        Pry it apart similar to this video.
                        http://www.youtube.com/watch?v=Ul5LhuCT1y8
                          very nice..... .... thanks a lot. i have got it open.
                            after 1 1/2 year i have problem again with my monitor. I have to recap the marked one.
                            680uF 25V 105 Degree 1 pc
                            470uF 25V 105 Degree 2 pcs
                            1000uF 25V 105 Degree 1 pc
                            Hope i can relive it again
                              Hmm that is why we usually recommend changing all caps - if one has gone others follow
                              hopefully you havent caused damage/weakness to other components by leaving them.
                              Please update profile with country and voltage
                                  is the lcd panel for this monitor has 55pins?
                                    Hi there! Can someone here post the body marking of R812 and R807 located at the bottom of the PCB? thanks in advance!
