DAC-19M009 dead?
Re: DAC-19M009 dead?
Datasheet is here
http://pdf1.alldatasheet.com/datashe...B20200FCT.html
findchips.com or ebay cannot find this part so it looks like you will need an equivalent.
Searching for "20A DUAL SCHOTTKY BARRIER RECTIFIER" in digikey shows 5 results.
Unfortunately, I don't know enough about which parameters are critical to the proper operation.
I will have to defer again to PlainBill or others to fill in. I feel like a pitcher who can go 7 innings, but need the bullpen and closer to finish the game! (Since PlainBill was just watching the baseball game).Last edited by retiredcaps; 06-18-2011, 11:02 PM.--- begin sig file ---
--- end sig file ---Comment
This looks like it may do the trick. VF40100C-E3/4W It's only rated for 100 volts reverse, but I will allow older, wiser heads to verify that.
PlainBillLast edited by PlainBill; 06-19-2011, 12:13 AM.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Would this be OK?
http://au.element14.com/taiwan-semic...50v/dp/1453402
It has the same max voltage rating as the existing one, and the other parameters seem similar as wellComment
Pardon me for cutting in, I believe this would be another suitable drop-in replacement:
http://au.element14.com/multicomp/mb...0ab/dp/1857516Comment
Would this be OK?
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Whoops, my bad, missed that the packaging needs to be TO-220AB-FP for full plastic packaging. If full plastic packaging configuration is not available, insulation kits such as this should be fine:
http://au.element14.com/multicomp/mk...-220/dp/520214
I couldn't find full plastic packaging at the rated 20A 200V schottkys either at element14 or rs-components.Comment
Well everyone, the diode arrived, I fitted it with the insulation kit, and everything seems to work fine! Been using the monitor for a couple of hours nowHopefully all the components were correct and nothing else gets damaged
Thank you to everyone who helped out, especially retiredcaps for the exhaustive initial tests to narrow down the fault, and to PlainBill for somehow incredibly tracking it down to that one diode! You guys are legendsComment
PLEASE!!! A Legend is a figure from the past. As retiredcaps will confirm, we are very much alive and darn well want to keep it that way!!!
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
by whirlpoolHello everyone
IMac model 2017 intel i5 Completely died after updating the operating system , no lights are on the board. I changed the power supply before just to gain experience, but again the problem has not been solved .. I have done a lot of research about it ...
I checked the SMC U5000 and pp3v3 pp5v. If you look at the schematic, the first light is called le0301 with the abbreviation in pp3v3 S5 circuit. before this I get 12 volts, 5 volts and 3 volts in U7600 well. but after U7600 and before reaching LED1_S5 everything is cut off . I reflowed the u5000 with a temperature... -
by BetonHi guys!
I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
I have a bench PSU and if I try to inject voltage the voltage... -
Hello everyone hope all doing well!
I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...3 Photos -
Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)... - Loading...
