Imac model 2017 is complely dead No light-12v is ok-ps is changed
  • whirlpool
    • Feb 2021
    • 8
    • belgrade
    Hello everyone
    IMac model 2017 intel i5 Completely died after updating the operating system , no lights are on the board. I changed the power supply before just to gain experience, but again the problem has not been solved .. I have done a lot of research about it ...
    I checked the SMC U5000 and pp3v3 pp5v. If you look at the schematic, the first light is called le0301 with the abbreviation in pp3v3 S5 circuit. before this I get 12 volts, 5 volts and 3 volts in U7600 well. but after U7600 and before reaching LED1_S5 everything is cut off . I reflowed the u5000 with a temperature of 405 degrees and I do not think the problem is with the SMC.
    first i need voltage in to LE0301 .i dont know how can i do that?
    Please help me.Thank you very much
  • mon2
    • 14449
    Re: Imac model 2017 is complely dead No light-12v is ok-ps is changed
    What is the logic board number for your box? It should 820-xxxx format.
    Also can you link the schematics if they are posted on this forum? If not posted, can you post them in the schematics section?
    • whirlpool
      • Feb 2021
      • 8
      • belgrade
      hi thanks for reply
      i use schematic for pcb 820-00597 imac 2017 intel i5 8g ram 4k
      • reformatt
        • Feb 2020
        • 1433
        Basic troubleshooting is essential! Try the simple stuff first, like CMOS battery, physical inspection, disconnecting non-essential connectors, measuring resistance/voltage of rails. Reflowing a SMC is usually the last resort, not the first. You can introduce faults into a device by doing random stuff like that.
        My experience thus far with iMacs is usually a very minor fault, like a shorted cap from corrosion can cause a dead board. So physical inspection under a microscope before you do anything is essential. Examine closely the areas under where the bottom of the LCD is, as chemical cleaners used to clean the screen often seep in through there. I've had shorted caps on the back of the board (facing the LCD), and on the headphone jack cause dead systems.
        Also check for dislodged or moved components under the microscope. As the iMac motherboard sits upright at an angle, it's easy to drop a tool on it while removing the screws for it. I've had a sensor issue (fan run at full speed) caused by a resistor knocked off by a dropped tool for example.
        For that first LED to light up, you need to check that all S5 voltages are present (pg 116) and power good signals for each are valid. Do the simple stuff first and work your way up.
        • whirlpool
          • Feb 2021
          • 8
          • belgrade
          Thank you very much for your answer. I did some basic checks before opening the motherboard, such as checking the battery or USB socket and other connections. And any chemicals, etc. have been checked on the board. Unfortunately, my schematic is only 87 pages and I do not know what you are using. Please upload that schematic for me here ... I am also a schematic of iMac. I uploaded myself in the previous post .... Thanks anyway
          • reformatt
            • Feb 2020
            • 1433
            Refer to pg 116 and check the G3H and S5 rails first. Since you have no LED's lit, this means that either the PP3V3_S5 or the S5_PWRGD is missing. If you have 12V to the board, but no G3H rails, this is where your troubleshooting should start.
            • tommy97
              iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
              by tommy97
              we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
              Any ideas what might've...
              04-20-2024, 04:48 AM
            • 944longdrift
              Help Identifying board components - iMac 2017 21.5
              by 944longdrift
              2017 iMac (Mid 2017) A1418
              I'm not quite sure how this happened but a couple of components got ripped off the board when removing from the Logic Board from the iMac.
              Can anyone help identify them?
              I'll have to do the trace repair on the board before soldering on replacements but would prefer to order the components rather than get a whole scrap logic board off eBay.
              Thank u
              03-14-2024, 11:53 AM
            • mon2
              In search of T2 rom dump for iMAC 2017 A1862
              by mon2
              Hello all. Have an imac that is not able to create PP1v8_S5 and there are no shorts on the rail. Unable to DFU due to USB not working. Suspecting corruption of the T2 firmware.
              Welcome all suggestions. Thanks.
              08-13-2024, 08:13 PM
            • iZakre
              HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
              by iZakre
              Hello everybody!
              To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
              The thing is that I had installed TeamViewer and could log into the computer...
              02-19-2023, 02:27 PM
            • iMuhtaseb
              iMac 21.5 2017 4K no image on internal screen
              by iMuhtaseb
              820-00597
              iMac 21.5" A1418 2017 4K is not showing an image properly.. It shows an image externally without issues but to the internal screen it's intermittent.
              Another screen results the same thing, it's a main logic board issue.
              I had doubts about the LVDS connector so I replaced it, still the same issue..
              The main logic board diagnostics LEDs are 5.. #1, #2, #3 works OK but #4 is half on and #5 is off.. I don't know what #4 means while it's not completely off or completely on..
              Anybody having an idea or seen this...
              09-19-2022, 07:11 AM
