Veiwsonic VA912B issue.
  • JDW
    • May 2011
    Hi im new to this forum.
    Ok first if i plug in the moniters A/C cable it works fine but when the VGA cord is plugged in the screen goes black and the power light flashes and is GREEN. I had to get the old crt out just to write this so any help would be appreciated.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Veiwsonic VA912B issue.
    Open the lcd up and post pictures of your boards following the instructions in my sig file below.
    You will also need a multimeter for troubleshooting.
    --- begin sig file ---
    --- end sig file ---
    • JDW
      • May 2011
      Ive decided to just scrap it. i thought it would be something simpler to fix but i don't have the necessary tools
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        Well if you have decided you don't want to fix it, it might be a good idea to at least put it on craigslist or kijiji. There's always other people who would like to fix it and use it. You may even fetch $10 or more for it, depending on the area you live in .
        • cajoeg
          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
          by cajoeg
          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
          02-10-2025, 04:01 PM
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          🛠 Original Issue
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ugamazing
          by ugamazing
          12-17-2024, 07:05 PM
        • elmark
          HP 15-cw1002ua strange keyboard issue
          by elmark
          HP Pavilion 15-CW1002UA
          S/N 5CD0251CBC
          P/N 7KE54EA
          Hello guys!
          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
          It powers on OK and has no other issues except the following:
          • CAPS LOCK does not work at all
          • Fn button toggles Flight Mode
          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
          • (with SHIFT pressed: 't%' and 'y^' respectively)
          I initially thought it was a keyboard malfunction (internal short, etc.),
          but when I press and hold...
          06-27-2025, 01:10 AM
        • Simone Vergani
          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
          by Simone Vergani
          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
          To assist with troubleshooting, I'm attaching two power circuit schematics:
          • Power
          03-05-2025, 02:25 PM
