Veiwsonic VA912B issue.
  • JDW
    • May 2011
    Hi im new to this forum.
    Ok first if i plug in the moniters A/C cable it works fine but when the VGA cord is plugged in the screen goes black and the power light flashes and is GREEN. I had to get the old crt out just to write this so any help would be appreciated.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Veiwsonic VA912B issue.
    Open the lcd up and post pictures of your boards following the instructions in my sig file below.
    You will also need a multimeter for troubleshooting.
    --- begin sig file ---
    --- end sig file ---
    • JDW
      • May 2011
      Ive decided to just scrap it. i thought it would be something simpler to fix but i don't have the necessary tools
        master hoarder
        • May 2008
        • 12175
        Well if you have decided you don't want to fix it, it might be a good idea to at least put it on craigslist or kijiji. There's always other people who would like to fix it and use it. You may even fetch $10 or more for it, depending on the area you live in .
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
          🛠 Original Issue
          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ugamazing
          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
          by ugamazing
          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
          12-17-2024, 07:05 PM
        • ahmarzo
          Acer laptop battery draining issue
          by ahmarzo
          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
          08-02-2025, 06:39 AM
        • elmark
          HP 15-cw1002ua strange keyboard issue
          by elmark
          HP Pavilion 15-CW1002UA
          S/N 5CD0251CBC
          P/N 7KE54EA
          Hello guys!
          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
          It powers on OK and has no other issues except the following:
          • CAPS LOCK does not work at all
          • Fn button toggles Flight Mode
          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
          • (with SHIFT pressed: 't%' and 'y^' respectively)
          I initially thought it was a keyboard malfunction (internal short, etc.),
          but when I press and hold...
          06-27-2025, 01:10 AM
        • Simone Vergani
          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
          by Simone Vergani
          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
          To assist with troubleshooting, I'm attaching two power circuit schematics:
          • Power
          03-05-2025, 02:25 PM
