HP1940 backlight
  • retiredcaps
    • Apr 2010
    • 9271
    Re: HP1940 backlight
    Originally posted by timelessbeing
    OK, will do. Please pardon my ignorance, but how does the fuse blow anyway? Don't bad solder joints increase impedance and restrict current?
    One of my first repairs of these Benq style power/inverter boards, I did not resolder the inverter transformer pins and 24 hours after my repair, the picofuse blew again. So I have first hand observations.
    Here is a technical explanation ...
    https://www.badcaps.net/forum/showpo...&postcount=269
    --- begin sig file ---
    --- end sig file ---
    • osoduro
      • May 2011
      • 3
      hi guys, I need some anwers about( xplio xp19a) this monitor has a noise and the piloto light flashing,I open but I really don't know where is the problem if any one have anwers for please sanchez39@msn.com free to recive my name miguel
      • retiredcaps
        • Apr 2010
        • 9271
        1) Start a NEW thread for this monitor since this is a xplio monitor.
        2) In the new thread, attach (see my sig file below) clear focused pictures of your boards.
        3) Try to use some proper punctuation and write in full sentences. Twitter style, poor grammar, etc, is likely not to get you any help.
        • timelessbeing
          • May 2011
          • 32
          Thanks for the link.
          So the fuse was dead. You couldn't tell by looking at it. All the components are in now.
          I wasn't able to clean much of the charred material off. Hopefully that doesn't create a problem.
          Tomorrow is test day.
          • timelessbeing
            • May 2011
            • 32
            I have a working 19" monitor.
            Thanks for your help everyone. Especially retiredcaps.
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
            • DanPoka
              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
              by DanPoka
              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
              02-15-2025, 05:05 AM
            • repair-it
              TOSHIBA DLP 52HM95 How to reset timer module on bulb
              by repair-it
              I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
              Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
              10-11-2023, 07:18 PM
            • Comp_Pro
              No Backlight Macbook A1990 820-01041
              by Comp_Pro
              Hello all,
              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
              Tests performed:
              There is no backlight even with a good screen.
              Backlight IC is receiving the correct support voltages.
              Fuse F8400 ok
              Current sense resistor R8400 ok
              Backlight IC is receiving 3.3V on enable pin.
              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
              Backlight IC receiving 5V from PP5V_G3S
              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
              05-06-2024, 10:23 PM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
