Dell 2408WFP Vertical Lines
  • blau
    The problem is a grouping of vertical lines about two inches from the right side of my monitor. They go away after 15-20 minutes of warming up. At first they were only 1-2 pixels in width and were magenta colored, but now its probably 6-7 pixels in width and are black.
    Google search pulls up a few people who have the same issue as me, but no resolution. Im not optimistic, but any info would be appreciated!
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Dell 2408WFP Vertical Lines
    Sounds like a bad connection from the column drivers to the panel ITO for those few pixels. Not easily fixable but since it's temperature-sensitive (expansion) applying pressure might help.
    • pavithra_uk
      • Nov 2010
      • 44
      may be Column drive flex cable has bad connection with panel glass (this is stick with glass & conductive lines)
      Check that area flex cable with pressed with finger as soon as cold start display (have to dissasemble panel from base)
      it problem gone.., try to glue that area might help
      • blau
        I tried applying some pressure to the lines and a few actually disappeared, but the black ones remained. Not sure I have the expertise to take it apart and glue anything.
        • tr3mor
          • Nov 2011
          it this any similar to the situation you guys were having? if so did you find any solutions, as that is my goal right now.
          thanks
          p.s. obviously in this image the monitor is upside down..
          • sebr
            • Oct 2010
            • 79
            Now I have a friends screen with same symptoms here for repair: vertical lines and ghosting images. So far many people run into this issue as you can see form various posts throughout the web. Only suggestion was to get it replaced under warranty. Has anybody here fixed this issue? I think if it's really the connection between the flex cable and the substrate there isn't a permanent way to fix this - unfortunately.
            • gavs
              • Oct 2012
              • Russia
              As I remember, 2408WFP use SAMSUNG LTM240CS05 LCD-panel. If discussed defects are look very much like following photo:
              http://www.picshare.ru/view/727582/
              (this is a photo of one of previous 24" SAMSUNG panels defect)
              it's frequent SAMSUNG LCD-panels defect - fault of T-CON (timing controller) PCB, which is a part of LCD-panel. The T-CON PCB of DELL 2408WFPB is marked as LTM240CS05FFCC4LV0.4 and can be found in free market. I had restored one of same PCBs replaced memory chip.
              • Stanley1843
                Screen Display Vertical Multicolor Lines
                by Stanley1843
                Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                06-29-2024, 11:54 AM
              • atticus_
                Dell U2518D strobing/flashing with vertical lines
                by atticus_
                I dumpster dived a 1440p Dell U2518D screen the other day and figured I'd take a crack at fixing whatever issues it may have. I powered it up to find that even with no signal input the screen flashes rapidly when turned on and has vertical lines across it. I disassembled the monitor and took pictures of the 3 circuit boards inside it along the way.
                The three circuit boards are labeled "power board l6256-1m", "LED Driver BD L6257-1". and "Interface Board L6127-1". if anyone has schematics for any of them it would be much appreciated...
                06-16-2022, 02:49 PM
              • gpo23
                Sony KDL-40V3000 - Vertical lines
                by gpo23
                i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                With the new t-con the color are good but there are vertical lines on all the screen :
                I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                Is there a way to fix the vertical lines on the new t-con ?
                Thank you for your help
                gpo23...
                10-04-2023, 09:11 AM
              • Firentiosi
                1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                by Firentiosi
                Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                The issues are as follows: the...
                11-27-2024, 12:33 AM
              • viking509
                vizio e65 e3 LED tv color vertical lines center tv only
                by viking509
                I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                03-21-2023, 12:48 AM
