Dell E172fpb
  • UMD_EE
    • Apr 2007
    #121
    Re: Dell E172fpb
    Regarding my previous post... The attached schematic (from model DV172) does not completely reflect the E172fpb's circuitry. In comparison the F172fpb is similar to that of the DV model schematic referenced; however the short circuit protection, as well as the feedback loop, are VERY different (much more complex). I believe this is where the design flaw is at. When designing any switch mode power supply feedback and short circuit protection (SCP) are critical. If any components in this region are not optimized, changes due to temp, fault... may cause failures (i.e. shorted components).
    Switch mode power supplies are nothing like linear power supplies... they are very efficient, but dumb! They need constant feedback in order to maintain proper voltages on the secondary side. If a lamp shorts out, the primary needs to adjust for that, otherwise poof transistors blow... I am in the process of creating a PSPICE circuit identical to that in the dell monitor.
    However, I may just alter my circuit board to reflect the posted circuit (DV model) eliminating such a complex SCP and feedback circuit. As far as I can tell, there haven't been too many complaints on that model. I'll keep you posted.
    • jmain
      • May 2007
      #122
      Re: Dell E172fpb
      UMD_EE, Thanks for the schematics and the info. Although the sch is not for this model, but it's close enough.
      I myself am Electrical engineer, but have been dealing with digital electronics for last 15 years. Don't even remeber much about the analog side.
      dockarl, there is absolutely no way for a cold solder joint to cause the short. No matter how complex matrix of diodes or anything you have, COLD JOINT WILL NOT CASUE SHORT. Cold joint is just a no connect (usually at above room temp), it can cause open but not the short.
      The reason you found two bad transistors while testing in-circuit and found that one of them is good when you removed it from the circuit is because the transistors in question are in pair. There is a very good reason why you should remove the components from the circuit before testing them. These trannies can be tested for short circuit pair while remain in-circuit, but you won't be able to test for single short transistor and/or open and/or for proper diode drops in reverse polarity.
      • Gwentiv
        • Nov 2006
        • 5
        #123
        Re: Dell E172fpb
        Hi !
        After months fighting with that stupid dell monitor i still have the same pb: it works fine 5 mins and swithces off !
        I ve noticed that both Q759 and Q760 get very hot: much hotter than their counterparts. Someone knows what the reason could be ? and what to do ?
        • dilahk0
          • Jun 2007
          #124
          Re: Dell E172fpb
          Is the FU9024N same the IRFU9024N?
          thanks
          • dilahk0
            • Jun 2007
            #125
            Re: Dell E172fpb
            is the FU9024N same the IRFU9024N?
            thanks
            • UMD_EE
              • Apr 2007
              #126
              Re: Dell E172fpb
              Yes, FU9024N is the same as IRFU9024N... The "IR" merely indicates the company name (International Rectifier). I have found that Digikey (www.digikey.com) carries this component... there you will find IRFU9024NPbF (the PbF indicates that this is the Lead free version).
              • UMD_EE
                • Apr 2007
                #127
                Re: Dell E172fpb
                If Q759 and Q760 are getting very Hot; chances are that one of the switching transformer coils are shorted (T751 or T753). Also check (C754 C755) which lies across the collectors of Q759 and Q760. These caps dampen the voltage and current across the tranny's (V*I=P (Watts=heat)). I am under the assumption that Q759 and Q760 are not failing (have you removed, and metered them individually?).
                Resistance from Emitter to Collector (Ohm'd out in both directions) should be infinite. Also, to test the switching transformers you will need to perform a "Ringer" test using a special tester (which a TV repair shop or University would have). Be sure to check the primary and ALL (3) of the secondary terminal pairs.
                See the attached schematic which I made based on my inverter board. Keep note that this schematic is NOT complete. There are many other subsidiary circuits indicated by ">>". It does however show the critical aspects required for proper operation. Best of Luck!!!
                • NICKW
                  • Jun 2007
                  #128
                  Re: Dell E172fpb
                  Having been given one of these monitors by a fiend (sic) I first had a look on the net and found this wonderful site full of info on it. Having read everybody`s
                  input, I pulled mine apart and found Q759 and Q760 US, Also board a bit cooked
                  in that area, examined solder joints under a microscope and found circular fractures in solder joints round component leads, not dry joints but fractures in
                  in the surrounding solder, I found about 20 joints like this all in the cooked area.
                  none anywhere else on the board. Resoldered these joints, stuffed in 2 tip41c`s.
                  On powering up, monitor worked, but tip41`s ran hot, did a temp check on them, and they soon got to 75c. Remounted tips via flying leads on the inside of
                  the casing which covers and supports the main board. Powered up, monitor working ok, tip casing stabilised at 30c due to heat sink of casing. Left monitor
                  on for 10 hrs, working fine, still working.
                  Conclusion, madness to replace transistors with expensive replacements not
                  mounted on heatsink, I think they`ll go sooner or later as cause of the fault is elsewhere on the board, and not the transistors themselves, they are simply
                  being overdriven and cooking. Note to newbie electronic people who copy my
                  mod, the TIP41c`s or similar must be mounted via mica insulating washers and
                  plastic washer in the tip body hole to electrically isolate the metal body of the
                  transistor from the metal casing being used as a heat sink. My thanks to the
                  time you have all put into this which has saved me so much, also to "mousie"
                  and "dockarl" whoe`s work I have used, Hope this helps someone out there!
                  Will post if and when it blows up!
                  • jdaproduca
                    • Dec 2006
                    • 8
                    #129
                    Re: Dell E172fpb
                    I just picked one of the monitors up broken, has same symptoms tries to power on then over current in the smps kicks in. Turns out to be one of the transistors (2sc5707) which drives the high voltage transformer for one of the lamps was shorted. I also noticed some small cracks in the solder around the switching MOSFET FU9024N. This may have caused the problem that once the monitor was on for a while and the solder around the MOSFET began to come loose and make a poor connection killing the switching transistor. Will let you know what happens as soon as I get my replacement transistor, and run the monitor for a long period of time.
                    • printone2
                      • Jun 2007
                      • 102
                      #130
                      Re: Dell E172fpb
                      I have my E172fpb apart to check the transistors. One pair is shorted, so I went to Radio Shack to see about parts. Their part # TIP3055 seems to be what I wanted. The label on the transistor is actually MJE3055, like what Dockarl has used. They are priced at $1.79 each. I think that I will replace all four instead of just the pair that are shorted.
                      I also have an E171fpb with issues. It takes 5 minutes to turn on and then works fine, until it goes into sleep mode. If in sleep mode or if turned off, it will need 5 minutes to warm up. After it warms up it will turn off and turn on just fine, but have it off for 10 minutes or more and it needs some warm up time. Before it warms up, unlike the E172fpb which often has the green power light on, it does not have any lights showing. It does seem to flash like the E172fpb, but the power light does not shine until it warms up. Any clues on what causes this, or what are the first things to try?
                      • printone2
                        • Jun 2007
                        • 102
                        #131
                        Re: Dell E172fpb
                        I finally took the E171fpb apart and two very buldging caps are located at positions C703 and C707. They are Elite brand. This board is very different from the E172fpb. It does not have any of the problem transistors and is much easier to work on. This may be why very few of them have failed.
                        • 9Shenandoah
                          • May 2007
                          • 5
                          #132
                          Re: Dell E172fpb
                          Is this monitor really fixable? I am a pretty good DIYer. Howver after reading all this stuff from people much morecapable than me, i wonder if my minitor, which as ll the symptoms as those that you ahve described, is even worth spending all that time and money on. Should I just go get another one?
                          • 9Shenandoah
                            • May 2007
                            • 5
                            #133
                            Re: Dell E172fpb
                            1. Where is the Link to the alleged Repair Kit on Ebay or whatever?
                            2. How do you get the case gracefully open? Theer are just no screws which means you have to pry gracefully. I see the round symbol with the Unlocked Lock next to it with an open slot inside it. Does this play any role to some trick in opening the case?
                            3. Is this monitor fixable? I see some posts which say "bad solder", others which say "bad transistors", but no common theme.
                            4. When mine started to fail, I noticed by flexing the cord on the power supply connection at the back brought it back to Life. Once I stuffed a plastic shim back there which saved it for about two weeks. Then it finally died and now it has the infamous flashing green light problem. This leads me to believe that it indeed was solder problem
                            • printone2
                              • Jun 2007
                              • 102
                              #134
                              Re: Dell E172fpb
                              I sure would like some help on retrofitting the transistors on the shield as a heat sink or just mounting some heat sinks from another board. The ideas of flying leads to me would mean some solid core copper wire like maybe some 24AWG unshielded twisted pair (utp/regular ethernet premises cable, not a patch cable). Can I just solder that to the holes where the trannies were and bring them to an open area inside the protective metal case and solder them to the leads of the trannies. Then screw the trannies to standard heat sinks like the ones located elsewhere on the board. Like at D701 and D702? If I did this what issues do I need to overcome to isolate the heat sinks if any?
                              It would be great to see some pictures of the mods that Mousie and NickW have made. I am just not quite sure how to finish this up.
                              • printone2
                                • Jun 2007
                                • 102
                                #135
                                Re: Dell E172fpb
                                I put my E172fpb back together with the transistors off the board. Now when I turn on the power it gives me a flashing power light and it makes a pulsing squeak. It sounded like a bird to me. But sure enough when I turn the power off the bird stops squeaking. When I look at the transistor reading from my VOM, they are very different once the transistors on soldered on from how the transistors read out of the circuit. I do not know if this is normal or not.
                                My soldering is not that good, but I suspect some other issues are going on that I just cannot detect yet. Are the transformers shot? I do not have any way to test them.
                                Can anyone tell me about the squeaking sounds? What monster have I created?
                                My other LCD the E171fpb has been running just fine for over a day now. It just had some bad caps. I wish I had two of them instead of one of these E171fpb.
                                • 9Shenandoah
                                  • May 2007
                                  • 5
                                  #136
                                  Re: Dell E172fpb
                                  I know what its like to be technically inclined. I have a mSEE but I am not a good electronics tech. My car has never been to a mechanic ever. I even rebuild engines and trannies. But all this effort for a $150 monitor? I guess its the technical challenge...
                                  • jumba
                                    • May 2006
                                    • 13
                                    #137
                                    Re: Dell E172fpb
                                    Thanx for the cct it confirms what I had traced 12 months ago. The higher beta transistors are the way to go. 3055 transistors are lower and may have not enough gain to startup. If the transistors are cooking the problem is shorted turn or a faulty cap in the o/p cct. My unit is still going strong since the repair but when it's not in use turn off the power! If the unit goes faulty in standby with shorted transistors the transformer cooks. The clue is the yellowish discolouring around the fluro cct.
                                    • drdavidge
                                      • Jun 2007
                                      • 11
                                      #138
                                      Re: Dell E172fpb
                                      So with the help of this forum and the site http://www.lcdrepair.us/Installation.html I was able to replace those 4 transistors and repair my monitor. It has been on for only 5 minutes, but I am hoping it lasts. Thank you for the help here - only cost me $12 for the 4 transistors plus I bought a desoldering sucker tool for $8. $20 is way better than a new $170 monitor.
                                      • kmkbeni
                                        • Jun 2007
                                        #139
                                        Re: Dell E172fpb
                                        I have a non-functioning E172fpb inverter/power board (version with 2 lamp connectors) that I would be happy to send to anyone willing to pay the postage.
                                        To repair my monitor, I replaced the entire board because I didn't have the time or patience to test the various board components, so I can't say which parts are good and which are bad.
                                        If interested, send me an e-mail to the address shown in my profile.
                                        • drdavidge
                                          • Jun 2007
                                          • 11
                                          #140
                                          Re: Dell E172fpb
                                          Damn, spoke too soon. It has been working for 3-4 days now, but now the green light just blinks. Here is what has happened so far: Monitor died and would only turn on for a second or two before going black. Green light would stay on. I replaced those 4 transistors, put it back together and it worked fine for a few days. Woke up this morning and turned it on and the green light is blinking with no picture on the screen. What is the next step I should take?
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                            Dell Thunderbolt Firmware
                                            by SMDFlea
                                            Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                            Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                            The SKU is in brackets (****)
                                            EDIT: NVM65...
                                            01-26-2025, 06:22 AM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
