Dell E172fpb
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Dell E172fpb
    Just repaired one of these e172fpb monitors. Just replaced the 6 trannies and away we went. Bought a repair kit from eBay for around $25... just had the 6 trannies, some solder, some desoldering braid, and the instructions. I'd still say it's worth it, though.
    I'll test it as my main display for a week or so, then unload it at a 100% profit
    Ludicrous gibs!
    • RAMPIGNON
      • Dec 2006
      #102
      Re: Dell E172fpb
      Hi dood, i live in FRANCE and i need some instructions for repair my dell E172fpb, picture on during 1 sec and the power led on/off green. Do you know which components i need? Rgds
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Re: Dell E172fpb
        You need four transistors, model 2SC5707, and two transistors model FU9024N
        You should be able to pick up a repair kit, as I did, from eBay.
        Ludicrous gibs!
        • ant3202
          • Jun 2006
          • 275
          • Singapore
          #104
          Re: Dell E172fpb
          Hi! Ladies & Gentlemen ..Pro Brothers,
          Good day =)
          my friend LCD minitor was also finally down ... Dell too..
          their experience ... they had a burnt smell when using a time, after that .. black out.
          I had check it out that its coming from transformer T751..
          may i know what is the part number on it?
          caps I'm gonna replace it
          thank you very much =)
          • gary1960
            • Feb 2007
            #105
            Re: Dell E172fpb
            Does anyone have schematics for the power supply / inverter board?
            Gary
            • sjbso2000
              • Jul 2006
              • 7
              #106
              Re: Dell E172fpb
              Could anybody tell me if these leads are plugged in the the right way round?
              Thanks,
              Scott
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                #107
                Re: Dell E172fpb
                you have 4 ccfl lamp connectors there? i believe there is no polarity on ccfl lamp (if someone can please confirm)
                • gonzo0815
                  • Feb 2006
                  • 1600
                  #108
                  Re: Dell E172fpb
                  Gas tubes are always unipolar, thus i think as long as the conectors fit into the socket, it should be fine.
                  • TOMARRO
                    • Jan 2007
                    • 10
                    #109
                    Re: Dell E172fpb
                    Here you are how to connect the 4 CCFL's
                    • sjbso2000
                      • Jul 2006
                      • 7
                      #110
                      Re: Dell E172fpb
                      I'd love to say that table helps..... but it doesn't.
                      I haven't re-wired. These connectors are as they came out of the factory. Plus, there's no blue wire. Only Black, pink and white.
                      • LuGonz2
                        • Feb 2007
                        #111
                        Re: Dell E172fpb
                        Hi, I have a LCD E172FPb.
                        First, The LCD isn't working because I turn on LCD and its not turn on, the ligth of the buttom is orange color and blinking. I test Q740 and Q739 because are o short. I put out two C5707 transistor (Q740 and Q739) on the same output (CN753), the other two transistor be OK. Then, it have same problem (I turn on and 2 seconds later the monitor turn off). . I turn on the LCD a present same effect (Turn On 2 seconds and later turn off). Excuse me, my English is verry bad.
                        • TOMARRO
                          • Jan 2007
                          • 10
                          #112
                          Re: Dell E172fpb
                          Check/replace ( PF 751 ) marked ( MS 3A ) in board.
                          • TOMARRO
                            • Jan 2007
                            • 10
                            #113
                            Re: Dell E172fpb
                            Sorry, marked (PF 751) in Board, and (MS 3A) in component.
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              #114
                              Re: Dell E172fpb
                              not really relevant for installation...ccfl is unipolar like gonzo says and ac powered
                              • esoterikest
                                • Feb 2007
                                #115
                                Re: Dell E172fpb
                                if the replacement transistors are of the curved type, what way should they face. is the curved side to face the metallic side of the bad transistors or what?
                                I went to radioshack, got a 15-pack of some 2N2222 transistors that match closely the requirements of the ones needed. the bottom lights on the monitor flicker on and off. the top bulbs dont light at all. which should i replace first? im thinking the top trannys q759 and q760.
                                • eddie47
                                  • Mar 2007
                                  #116
                                  Re: Dell E172fpb
                                  Allied Electronics is a good source. They have a web page, sell in any quantity, and have reasonable shipping. I just bought 4 EA MJE3055 and 2 EA FU9024N for about $5.35 total.
                                  I'll post back when I get them soldered in, or find a part number for the transformers
                                  • Gwentiv
                                    • Nov 2006
                                    • 5
                                    #117
                                    Re: Dell E172fpb
                                    Hello !
                                    I posted a couple of question last year about this pb with the Dell/Benq inverter and there is one more to come:
                                    I replaced the transistors with some BD911 whose Hfe is between 40and 250 at 0.5A. But the original SC5707 have a value between 200 and 560.
                                    Is that a Pb ?
                                    It seems the 3055 has an HfE situated between 20 and 100...
                                    The sc5707 are more expensive too ...
                                    Now I am a total noob in Electronics, but couldnt that be a reason why these get sooo hot ?
                                    My BD 911 get really hot too, and after some time, the monitor turns off...
                                    • Lucky Phill
                                      • Mar 2007
                                      #118
                                      Re: Dell E172fpb
                                      If any body would like a circuit of this monitor I have attached a copy of a similar model which if you look closely is exactly the same boards but the casing is different. The one I have is a Diamond LCD. It is complete Manual.
                                      Enjoy
                                      • Rafph
                                        • Mar 2007
                                        #119
                                        Re: Dell E172fpb
                                        Enjoy
                                        Circuit diagrams would be great, Phill, but I don't seem to be able to find anything 'attached'.
                                        • UMD_EE
                                          • Apr 2007
                                          #120
                                          Re: Dell E172fpb
                                          I am an Electrical Engineering student and purchased this monitor broken because I'm cheap… and well, I'm learning how to design these things. I have curiously been following this thread and finally decided to contribute. Hopefully this may shed some light on thing or two… or possibly confuse some. READ the attached pdf files. I've also included a schematic from a very similar Benq Inverter board... Enjoy
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
