Dell E172fpb
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Dell E172fpb
    Originally posted by davmax
    Wrong data sheet!!! However I know this controller chip and have data sheet.
    Here is the datasheet for the inverter Dual PWM for people in the future.
    • davmax
      • Dec 2005
      • 899
      #202
      Re: Dell E172fpb
      Thanks Krankshaft. I have data sheet.
      This chip is the same as in the Benq monitor I modified (Benq FP737s thread). I suspect that there is the same weakness that blows transistors ie a rapid OFF then ON of video signal bypasses the soft start timing.
      It is amazing that the monitor in question worked with a subtitute N channel MOSFET. I ponder how it did work!!!!
      160Gb WD SATAII Server grade
      Nvidia 8500GT 256Mb
      Samsung 18x DVD writer
      33 way card reader
      Windows XP Pro SP3
      17" Benq FP737s LCD monitor
      • Krankshaft
        • Jan 2007
        • 2328
        Re: Dell E172fpb
        I am pondering that too I would think that it would have overheated and self destructed in short order.
        Maybe it survived because its breakdown voltage was overkill and was able to bear the strain?
        Installing the proper N or P channel FET is as elementary as making sure that the components pin out is correct.
        They couldn't even get that right so comparing their electrical characteristics was way out of the question.
        But after what I've seen so far I think this guy should be flipping hamburgers rather then working with electronics.
        That fact that the component was replaced tells me like on my monitor when the driver transistor went it shorted out the FET in its circuit by destroying the fragile gate.
        • HOODLAM
          • Dec 2007
          • 20
          #204
          Re: Dell E172fpb
          Hi Guys. The Screen Went To A Company Called Vr Eletronics Who Are The So Called Benq Repair Agents Locally. Well, Something Tells Me They Aren't To Sharp There. I Just Hope I Can Repair What They Have Messed Up. Is There Anything Else I Can Check?
          Intel Core 2 Duo E6750 2.66Mhz 1333FSB
          4 x 1Gb DDR800 Kingston
          Geforce 8600GT 256Mb G/Card
          1 x 320Gb Seagate SATAII
          1 X 500Gb Seagate SATAII
          • davmax
            • Dec 2005
            • 899
            #205
            Re: Dell E172fpb
            The MOSFETs, fuse and 2SC5707s are the major components that are likely to be affected. The Dual controller chip should survive OK being isolated from each MOSFET by a current limiting resistor. However you should check out the two MOSFET driver transistors they are under the board with three legs. Check for shorts. You should be able to compare the transistor reading in the two driver circuits, naturally they should be the same unless one is faulty.
            I am surprised to hear that that Benq agent did so badly, possibly put the apprentice on the job.
            Nvidia 8500GT 256Mb
            33 way card reader
            Windows XP Pro SP3
            • davmax
              • Dec 2005
              • 899
              #206
              Re: Dell E172fpb
              When you replace the transistors make absolutely sure they are replaced with the same orientation ie correctly connected. Watch out for lifting PCB track, making sure to detect any track break.
              When you get the monitor going a good insurance is to switch off the monitor before you start the computer. This will make it certain that the monitor will not experience the soft start bypass that can occur and stress the 2SC5707 transistors. Turn ON the monitor late in boot or at completion.
              Nvidia 8500GT 256Mb
              33 way card reader
              Windows XP Pro SP3
              • Krankshaft
                • Jan 2007
                • 2328
                Re: Dell E172fpb
                Installing the new driver transistors in the right orientation is easy on the PCB you will see a white line silkscreened on the board.
                The metal side of the new driver transistor should face this white line.
                • dbsoundman
                  • Jan 2008
                  #208
                  Re: Dell E172fpb
                  I have a somewhat different issue than others here...
                  I was using this monitor with my desktop computer, and everything was fine for about 4 months or so. Then one day my desktop tower would not turn on. I finally got around to troubleshooting today, and found it will turn on only if the monitor is not connected. So, I assumed that the monitor had issues. I tried the monitor out on my laptop, and it worked, but about 10 seconds later smoke started coming from where the monitor was plugged in on the laptop! I didn't have the cable actually screwed onto the laptop so I just yanked it out fast, but I'm guessing I have some sort of issue where the monitor is sending voltage back to the computer. Any guesses as to what is going on? I will go try to get the back off and see what I can see...
                  Thanks!
                  -Dan
                  • dbsoundman
                    • Jan 2008
                    #209
                    Re: Dell E172fpb
                    I just got the thing open. Everything inside looks perfect...so no direct suspects there, and I saw some of the components seem to be decent quality (nichicon). I did also notice that mine is the E172fpt and not fpb. I also did not see any markings indicating it was made by Benq.
                    Also considering the other side of the coin here...could it be that the PC tower's video card has the issue, and my laptop issue was some sort of fluke? I'm curious to hear what you all think. I'll see if I can borrow a CRT or something sometime soon to see if the PC will fire up with one of those attached...
                    -Dan
                    • HOODLAM
                      • Dec 2007
                      • 20
                      #210
                      Re: Dell E172fpb
                      HI GUYS, JUST THOUGHT I WOULD KEEP YOU UP TO DATE WITH THE PROGRESS REPAIRS ON MY HP L1955, WELL... STILL NO PARTS YET!!! HOPEFULLY STILL SOMETIME THIS WEEK!!!
                      • charlesrg
                        • Dec 2007
                        • 6
                        #211
                        Re: Dell E172fpb
                        Originally posted by charlesrg
                        It's still working good. No problems at all. No smoke either.
                        Today the transistors failed again, monitor is having the same symptoms.
                        I just bought 4 from this ebay for $7 bucks.
                        If it fails again I will just order the whole board for 40 bucks. It should fix the problem.
                        I will post more info when the components arrive.
                        Also about the RadioShack components, yes, they are bigger and I had to do a little cut on the case to make them fit.
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          Re: Dell E172fpb
                          Have you been keeping the monitor shut down during the POST?
                          If you have been leaving the monitor on during the CMOS check then the soft start circuits are being bypassed stressing the driver transistors you replaced.
                          If so thats the reason why they kicked the bucket again.
                          • HOODLAM
                            • Dec 2007
                            • 20
                            #213
                            Re: Dell E172fpb
                            Update Time!! Some Of The Parts Arrived Today! Just Waiting For The 9024n's Which Should Be Here In A Weeks Time. Will Continue Installing The Components!
                            • peterrr
                              • Nov 2007
                              #214
                              Re: Dell E172fpb
                              Hi everybody..
                              Short description: I replaced 9024 & 5707 but after 2 minutes they burn again (one 9024).. I decided that one working ccfl will be enough.. My plan is to desolder failed 9024 - this will disconnect faulty circuit for second ccfl.. Whats happened: LCD working fine but backlight is getting off after 2 seconds.. I think i need to put feedback1 (IC751) from working circuit to disconnected circuit feedback2 to cheat IC751..
                              What you think?anybody
                              • Monitor Doctor
                                • Nov 2007
                                #215
                                Re: Dell E172fpb
                                To peterrr and Hoodlam,
                                That other site that charges $20 shipping that is nuts man. You can get those parts 2SC5707 and the FU9024N and shippin just $6.95 anywhere in the world from lcdrepairparts. They also claim to provide the some real simple solution to prevent them from blowing out again. The web address is http://lcdrepairparts.com
                                peace!
                                • davmax
                                  • Dec 2005
                                  • 899
                                  #216
                                  Re: Dell E172fpb
                                  peace!
                                  Hi Monitor Doctor. Are you part of lcdrepairs? Your name appears on the web site.
                                  I would be very interested in the detail of the simple repair that prevents future blowing of the 2SC5707.
                                  I will give you the benefit my experience with the Benq FP737s monitor. Fortunately I was able to get a schematic that identified that the 2SC5707 transistors were not well protected, in fact this particular design has a useless circuit for transistor protection. I therefore designed and installed a 10uS response over current protection that really protects. Having installed this protection that actually trips off the power to the inverters I was able to witness the cause of transistor failure. Failure can occur if a computer removes the video signal and rapidly returns it. This causes a bypass of the inverter slow ramp up and excessive transistor current has been seen to occur, presumably due to inverter transformer saturation. The trip circuit provides absolute protection and as said already allows witnessing of excess current conditions.
                                  Another protection method that does not provide absolute protection of all over current conditions is to install a small monstable circuit that monitors and controls the video control signal to the inverter power. This circuit ensures that once the control signal is removed that it cannot return for 1 second or more thus allowing the ramp circuit a recovery time.
                                  Hope you find this helpful
                                  Nvidia 8500GT 256Mb
                                  33 way card reader
                                  Windows XP Pro SP3
                                  • Krankshaft
                                    • Jan 2007
                                    • 2328
                                    Re: Dell E172fpb
                                    Originally posted by peterrr
                                    Hi everybody..
                                    One of your High Voltage transformers is fried causing the transistors to blow.
                                    • peterrr
                                      • Nov 2007
                                      #218
                                      Re: Dell E172fpb
                                      Thanks for answer. But i dont understand why is backlight getting off after 2 seconds in working ccfl circuit..? failed circuit is disconnected.
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        #219
                                        Re: Dell E172fpb
                                        the controller senses the failed lamp didnt strike so it shuts down.
                                        does not matter if the lamp or inverter is bad.
                                        • peterrr
                                          • Nov 2007
                                          #220
                                          Re: Dell E172fpb
                                          Then what is solution? i need to do something with controller?
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • OntarioTL
                                            Dell 5410 greyed out BT
                                            by OntarioTL
                                            Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                                            If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                                            Dell Lattitude 5410
                                            Service Tag...
                                            07-25-2025, 01:28 PM
