Ever seen an LCD do this?
  • el3ctroded
    • Nov 2008
    • 198
    I've not seen these fading vertical white lines before, and want to know if I write off the LCD as bad or what?
    Thanks!
  • Spitz
    • Oct 2010
    • 95
    Re: Ever seen an LCD do this?
    Thanks!
    You can consider that screen bad, but a lot of new replacement lcd are less than $100 on ebay.
    • pr0cess0r
      • Jan 2011
      • 110
      look like an HP i think i have a used one if you can give me the exact model
      • el3ctroded
        • Nov 2008
        • 198
        Laptop LCD model number
        LTD154EX0V
        or
        LTN154X1-L02
        I say Or because I have 2 identical laptops, both have bad screens, and these are the two models of screen in them.
        I found a used LTN154X1-L03 for $45 shipped, so I would really like to know if it's fully compatible...
        Thx
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          Yesterday, 08:49 AM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • Syseng
          Lenovo P14s Gen 5 SVP unlock
          by Syseng
          This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
          The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
          06-22-2025, 07:44 AM
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • Andriod
          LG 47LN577 with black fading horizontal evenly spaced lines
          by Andriod
          So, I have searched the internet for long, high and low and ended up here.
          As the title suggests; there are static repeating black-ish horizontal lines that start from the left and fades away at around 65% toward the right, meaning its length is more than half the screen. The lines are from top to bottom evenly spaced. I can see the lines on the test image, and on chromecast input.
          This is my first time investigating TV errors at this level, and my initial googling led me to believe it was the T-CON board, considering that it has a left-ish problem. But googling even...
          12-30-2020, 03:38 PM
