HP lcd L1502 15"
  • leov
    • Mar 2011
    • 45
    HP lcd L1502 15"
    Hi guys. I am very new to this, but was hoping you would help me fix my lcd. Originally, the screen started to turn itself off randomly. I was able to restart it, but after few days it shut down and I was not able to bring it back to life. I replaced all 25V 470 uF caps on this board. They were not blown, but looked like they were starting to "inflate". (sorry, i am not sure what the proper terminology is to describe it). That did not fix the problem though. When I connect the power cable I can hear a clicking noise coming from the parts that I circled on the picture. They turn really hot if the power cable is connected. Would someone please tell me what I should do next? How do I go about testing the other components on the board? Thank you.
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    Re: HP lcd L1502 15"
    Hi did you test the transistors that you have arrowed (probably 5707 or 5706 markings on them )
    Also did you resolder the 4 x transformers
    If you check threads that deal with Dell 172 monitors they have the same type of board and have the same symptoms
    • PlainBill
      • Feb 2009
      • 7034
      This is a classic example of the problems with these monitors. As sabre504 said, replace both transistors (2SC5707). Also resolder all pins on the 4 inverter transformers. Just for luck, I'd also replace the cap that was clicking.
      What brand and series capacitors did you use as replacements for the bulging caps?
      PlainBill
      • leov
        • Mar 2011
        • 45
        Hi sabre, Thank you for replying to my post. I appreciate your help. The transistors are 5707. How do I go about testing them? I have very limited understanding of these things. I did not resolder the transformers.
        • leov
          • Mar 2011
          • 45
          Hi PlainBill,
          Thanx for taking time to look into this for me. I used united chemi-con caps from Digi-key.
          Also, I found out that the problem occurs when I connect little circuit board that has VGA connector on it. If its not connected, there is no clicking heard on the big board.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            That's the logic board. It's kinda obvious that it won't do it without the logic board connected, since the logic is what instructs the inverter to turn on.
            A working TV? How boring!
            • leov
              • Mar 2011
              • 45
              So i guess it would be safe to assume that the logic board is working fine.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Yes. Your problem is in the inverter area. For now, take out the 5707 transistors and measure them with your multimeter set to 200 ohm scale. If any leg combinations read 0 ohms the transistors are bad and need to be replaced.
                • leov
                  • Mar 2011
                  • 45
                  Thank you, I will try doing that as soon as i get a chance.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    I usually test components "in circuit". If the readings are suspicious, then I desolder and measure "out of circuit".
                    --- begin sig file ---
                    --- end sig file ---
                    • leov
                      • Mar 2011
                      • 45
                      Hi Retiredcaps,
                      I've read that you do that, but I don't know how to test it. I am going to read about it and try testing it right now.
                      Thanx for advice. I appreciate it.
                      • leov
                        • Mar 2011
                        • 45
                        So here is the pic of the transistors i need to test. How do I go about testing them? I tried setting my meter to 200 ohms. When i connect positive lead to B and negative to E or C i get random readings that stabilize around 0.9-8. If I test from E to B and from C to E i just get random readings that do not stabilize. I am not sure if I am doing this right. Thank you for putting up with me. Any help would be appreciated.
                        leo
                        • PlainBill
                          • Feb 2009
                          • 7034
                          leo
                          Are you testing with the monitor unplugged?
                          Please attach a picture of your meter with the function switch set in the position you are using, and with the probes plugged in..
                          PlainBill
                          • leov
                            • Mar 2011
                            • 45
                            PlainBill
                            monitor is not plugged in. I will attach the picture in a bit.
                            OK here are the pics of my meter:
                            • PlainBill
                              • Feb 2009
                              • 7034
                              You definitely have the meter set to the correct range, and the leads plugged in correctly for resistance measurements. The display shows a typical display for a resistance greater than 200 ohms.
                              I can't explain the strange behavior. Ordinarily I would expect to see this display between any two legs of a transistor. A jitter of the last digit isn't unusual. What reading do you get when you try to measure the resistance between two points on the circuit board that are obviously connected, for example, the emitter of the two transistors in post 12?
                              PlainBill
                              • alexanna
                                • Mar 2010
                                • 1346
                                leo
                                The readings your getting with your ohmmeter, the jumping and taking time to settle down makes me wonder if you may have a problem with your DMM leads?What reading do you get on the 200 ohm scale with the leads of your meter hooked together?
                                Don't forget to read PlainBill's above post.
                                • leov
                                  • Mar 2011
                                  • 45
                                  it reads 00.1, 00.3. The last digit is flirting between .4 and .1 and if i understand it correctly, Bill said that its ok if that happens. I am going to post a pic of the readings that I got when i tested another set of C5707 on the board.
                                  • leov
                                    • Mar 2011
                                    • 45
                                    PlainBill
                                    Bill, here is what i did. I think that I found the bad transistors. Please see the picture. Th3 has pointed me to those before, but with everyone's help and a little of reading here on the forum i think i got it. Please confirm my findings.
                                    Thank you for your help guys.
                                    leo
                                    • steve2
                                      • 121
                                      When they read bad in circuit, you need to remove them from the board and recheck them. You may be reading transformers windings to get a reading that low or something else.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        leo
                                        You can verify the readings by removing them from the board, but they are almost certainly bad. This circuit is what is known as a Royer Oscillator. In it the two bases are tied together by a transformer winding and the two collectors are tied to the 12V supply through transformer windings. There should be no direct Collector-Emitter short.
                                        PlainBill
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • mikelu53
                                          Samsung UN60D8000YF Clicking BN44-0432A
                                          by mikelu53
                                          I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
                                          The set was working then not,then started clicking.
                                          Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
                                          Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
                                          A schematic or suggestion would be great.
                                          01-21-2023, 03:14 PM
                                        • bffargo
                                          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                          by bffargo
                                          LG 60PB66550 NOV 2014
                                          PSU: EAY63168603
                                          PCB: EAX65359531 2013.11.01 Rev:1.0
                                          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                          Symptom:
                                          While watching, just went black and started clicking relay every few seconds.
                                          Initial diagnosis:
                                          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                          Deeper diagnosis:
                                          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                          09-09-2022, 07:34 PM
