Dell SP2008WFPt no picture
Re: Dell SP2008WFPt no picture
You can try tracing the input and output pins of the reg to see where they lead. It's been my experience that these voltage regs are always powered on.Comment
Did some more investigating.
See attached picture.
Point 1 has 5.27V, point 2 has 5.07V, point 3 has 0V.
Point 3 then goes to a fuse (blue box) and to a test point.
It then goes into a capacitor and into the input of the big regulator.
The output of the regulator is connected to the other side of the capacitor and to the ground.
The small box on top (with point 1, 2 and 3) is too small for me to read the text on top, but is labelled Q308 on the board.Attached Filesif you find these attachements useful please consider making a small donation to the site
I would like to make a suggestion.Did some more investigating.
It would be a good idea to verify you have a ground on the regulator. What voltage reading do you get with the red lead on pin 1 and the black lead on pin 3?Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!
Those pins are in reference to my picture above right?
I get 5.23V between pin 1 and pin 3 (the configuration you asked for) and 5.04V between pin 2 and pin 3.Comment
FYI- the "F" and "FB" designators mean two different things: The "F" designates a fuse as mentioned earlier. "FB" designates a Ferrite Bead, which is not a fuse, but a bead of ferrite over a piece of wire.
As for Q308, it's some type of transistor. Since you can't read the part number, I'll take a WAG and using your numbering scheme for the legs and with power off, try measuring for shorts across legs 1-3, 2-3 and 1-2.Comment
I looked at your photo a little more closely. From your drawing you stated that the the output of the regulator is connected to one side of the capacitor and to ground. How can the output be connected to ground?
It would make more sense if the output of the reg is connected to the "+" side of the cap and the ground leg of the reg is connected to ground, but not connected to the output leg of the reg.Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
by timelessHi,
I've been troubleshooting a Dell U2518 that produces no picture yet the backlight is turned on, the PSU produces 19v, It is detected over HDM and its firmware could be upgraded over USB. So to me the controller board and PSU seems (somewhat) functional.
There is however a ticking noise from the T-Con board to the left side of the RT6811 chip when power on (not when off). Also the RT6811 chip gets quite hot (cannot be touched for long) otherwise there is no physical sign of damage and everything around the board is neatly covered with plastics and does not show any...2 Photos-
by SMDFleaDell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
Some models have a choice of 2 different firmwares, it depends on the dell SKU.
The SKU is in brackets (****)
EDIT: NVM65...-
- Loading...
